[GeoNode-devel] GeoNode Backup and Restore ... any clue on DJango serialization?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Jan 22 08:26:15 PST 2016
Dear list,
working on the GeoNode Backup and Restore task I'm struggling with an issue
while trying to deserialize data.
Basically what I'm trying to do is dump the GeoNode fixtures as JSON files
and trying to load them later on an empty (prepared) GeoNode DB.
Now ... by playing a bit with the json outputs and load order I am able to
restore almost all the fixtures, but I have an issue with the Layers,
inherited from ResourceBases.
I am able to restore succesfully the ResourceBases but whenever I try to
deserialize a Layer I'm getting and error with the primary key.
Using the default JSON like this:
"pk": 1,
"model": "layers.layer",
"fields": {
"styles": [
1
"store": "datastore",
"name": "san_andres_y_providencia_administrative",
"service": null,
"charset": "UTF-8",
"title_en": "San Andres Y Providencia Administrative",
"abstract_en": "No abstract provided",
"regions": [],
"typename": "geonode:san_andres_y_providencia_administrative",
"default_style": null,
"purpose_en": null,
"workspace": "geonode",
"upload_session": 9,
"supplemental_information_en": "No information provided",
"data_quality_statement_en": null,
"storeType": "dataStore",
"distribution_description_en": null,
"constraints_other_en": null
I get an error message like: null violates constraint for "resource_id"
If I try to modify the JSON like this:
"*resourcebase_ptr_id*": 1,
"fields": {
"styles": [
1
"service": null,
"charset": "UTF-8",
"regions": [],
"purpose_en": null,
I get the following error:
ResourceBase matching query does not exist.
Any idea/help ?
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160122/cd6854c2/attachment.html>
More information about the geonode-devel
