[GeoNode-devel] AuthenticationServiceException: Communication with GeoNode failed Caused by: java.net.SocketTimeoutException: Read timed out
Ken Abryl Eleazar Salanio
kasalanio at dream.upd.edu.ph
Tue Jan 26 01:07:41 PST 2016
I found this in the code snippet for the GeoNodeSecurityProvider.java
<https://github.com/GeoNode/geoserver-geonode-ext/blob/master/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java>
> protected GeoNodeSecurityClient configuredClient(String baseUrl) {
> HTTPClient httpClient = new *HTTPClient(10, 1000, 1000);*
> String securityClientDatabaseURL =
> GeoServerExtensions.getProperty("org.geonode.security.databaseSecurityClient.url");
> GeoNodeSecurityClient configured;
> String securityClient = "default";
> if (securityClientDatabaseURL == null) {
> DefaultSecurityClient defaultClient = new
> DefaultSecurityClient(baseUrl, httpClient);
> configured = defaultClient;
> } else {
> securityClient = "database";
> BasicDataSource dataSource = new BasicDataSource();
> dataSource.setDriverClassName("org.postgresql.Driver");
> dataSource.setUrl(securityClientDatabaseURL);
> configured = new DatabaseSecurityClient(dataSource, baseUrl,
> httpClient);
> Logging.getLogger(getClass()).log(Level.INFO, "using geonode {0}
> security client", securityClient);
> return configured;
Does this mean that the timeout is not configurable?
On Tue, Jan 26, 2016 at 5:05 PM, Ken Abryl Eleazar Salanio <
kasalanio at dream.upd.edu.ph> wrote:
> I found this in the code snippet for the GeoNodeSecurityProvider.java:
> On Tue, Jan 26, 2016 at 11:31 AM, Ken Abryl Eleazar Salanio <
>> Just a follow-up question on this. How can I adjust the timeout settings
>> on the HTTPclient used by GeoNodeSecurityClient java class? It seems that
>> the problem stems from the /layers/acls JSON being too large when GeoServer
>> asks for it from GeoNode. Adjusting the timeout on the Tomcat server.xml
>> doesn't seem to help. Thanks!
>> On Mon, Jan 18, 2016 at 5:40 PM, Ken Abryl Eleazar Salanio <
>>> OK, thanks! Will try looking for it then.
>>> On Mon, Jan 18, 2016 at 5:34 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Not as far as I know unless there is something on the server preventing
>>>> that.
>>>> 2016-01-18 10:09 GMT+01:00 Ken Abryl Eleazar Salanio <
>>>> kasalanio at dream.upd.edu.ph>:
>>>>> Yep, I've edited the config.xml to specify the geonode base location.
>>>>> If the location cannot be found, geoserver outputs a "Caused by:
>>>>> java.net.UnknownHostException: <hostname>". However in this case, it's a
>>>>> socket timeout. Geoserver sees the location, but cannot finish the
>>>>> authentication. Is it possible that apache or java blocks the connection
>>>>> until it times out?
>>>>> On Mon, Jan 18, 2016 at 4:48 PM, Simone Dalmasso <
>>>>>> Hi,
>>>>>> yes is in the geoserver data
>>>>>> dir/security/auth/geonodeAuthProvider/config.xml. There you have to put the
>>>>>> Regards
>>>>>> 2016-01-18 9:47 GMT+01:00 Ken Abryl Eleazar Salanio <
>>>>>>> WARN [geonode.security] - Error connecting to the GeoNode server for
>>>>>>>> authentication purposes
>>>>>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>>>>>> at
>>>>>>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:61)
>>>>>>>> at
>>>>>>>> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:57)
>>>>>>>> at
>>>>>>>> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
>>>>>>>> at
>>>>>>>> org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:63)
>>>>>>>> at
>>>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>>>>>> at
>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
>>>>>>>> at
>>>>>>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
>>>>>>>> at
>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
>>>>>>>> at
>>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>>>>>>>> at
>>>>>>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>>>>>> at
>>>>>>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>>>>>> at
>>>>>>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
>>>>>>>> at
>>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>>>>>> at
>>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>>>>>> at
>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>>>>>> at
>>>>>>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>>>>>> at
>>>>>>>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>>>>>> at
>>>>>>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>>>>>> at
>>>>>>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>>>>>> at
>>>>>>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>>>>>> at
>>>>>>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>>>>>> at
>>>>>>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>>>>>> at
>>>>>>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>>>>>> at
>>>>>>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>>>>>> at
>>>>>>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>>>>>>> at
>>>>>>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>>>>>> at
>>>>>>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>>>>>> at
>>>>>>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>>>>>> at
>>>>>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>>>>>> at java.lang.Thread.run(Thread.java:745)
>>>>>>>> at java.net.SocketInputStream.socketRead0(Native Method)
>>>>>>>> at java.net.SocketInputStream.read(SocketInputStream.java:152)
>>>>>>>> at java.net.SocketInputStream.read(SocketInputStream.java:122)
>>>>>>>> at
>>>>>>>> java.io.BufferedInputStream.fill(BufferedInputStream.java:235)
>>>>>>>> at
>>>>>>>> java.io.BufferedInputStream.read(BufferedInputStream.java:254)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpParser.readRawLine(HttpParser.java:78)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpParser.readLine(HttpParser.java:106)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpConnection.readLine(HttpConnection.java:1116)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.readLine(MultiThreadedHttpConnectionManager.java:1413)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpMethodBase.readStatusLine(HttpMethodBase.java:1973)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpMethodBase.readResponse(HttpMethodBase.java:1735)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1098)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
>>>>>>>> at
>>>>>>>> org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
>>>>>>>> at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:70)
>>>>>>>> at
>>>>>>>> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:152)
>>>>>>>> at
>>>>>>>> org.geonode.security.DefaultSecurityClient.authenticateAnonymous(DefaultSecurityClient.java:135)
>>>>>>>> at
>>>>>>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:48)
>>>>>>>> ... 47 more
>>>>>>> My question is, what geonode URI does geoserver use for
>>>>>>> authentication, so that I may check if it is being blocked somewhere?
>>>>>>> Thanks!
>>>>>>> On Mon, Jan 18, 2016 at 4:45 PM, Ken Abryl Eleazar Salanio <
>>>>>>>> Hi, I've installed a development version of geonode and i'm running
>>>>>>>> the geoserver using tomcat 7. It worked for quite a while but I've recently
>>>>>>>> encountered this error and can't seem to debug it:
>>>>>>>> Ken Abryl Eleazar S. Salanio
>>>>>>>> *Computer Programmer III*
>>>>>>>> *Data Archiving and Distribution Component*
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> Simone
>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160126/cfbd1ca6/attachment-0001.html>
More information about the geonode-devel
