[GeoNode-devel] Upgrade to GeoServer 2.9
Daniel Berry
dberry at boundlessgeo.com
Thu Jul 7 07:09:35 PDT 2016
Alessio,
I would think an issue and PR would be sufficient. We should add what new
features or changes are included though.
regarding the following
"*We need boundless to fix geogig 2.9.x version which is currently broken.
We need geogig JARs to be pushed on a public maven repository, otherwise
GeoServer won't compile. Is there someone from boundless which can
eventually help us with this task?"*
We sure can, Erik Merkle is currently researching the level of effort for
GeoGig 2.9.x extension. This would be great if we could include this in the
GeoNode 2.5 release. Would you like to schedule a time to discuss?
Respectfully,
Daniel Berry
On Thu, Jul 7, 2016 at 8:13 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> I managed to succesfully update the geoserver-genode-ext to the 2.9
> version, but there are still two things to discuss:
> 1. Everyone is ok with this GeoServer version? Should we go through a GNIP
> or an issue and PR are sufficient?
> 2. We need boulndless to fix geogig 2.9.x version which is currently
> broken. We need geogid JARs to be pushed on a public maven repository,
> otherwise GeoServer won't compile. Is there someone from boundless which
> can eventually help us with this task?
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
*Daniel Berry*
Senior Software Engineer | Boundless
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160707/5b642b17/attachment.html>
More information about the geonode-devel
