[GeoNode-devel] Fixing Geonode master syncdb
Jeffrey Johnson
ortelius at gmail.com
Thu Jul 7 08:02:35 PDT 2016
+1 on adding dan, alessio and sarah to be able to push on pypi
On Thu, Jul 7, 2016 at 7:58 AM, Daniel Berry <dberry at boundlessgeo.com>
wrote:
> We may want to open pypi up for others to push new updated versions,
> especially with the 2.5 and 2.6 releases coming up.
> Thoughts?
> Dan
> On Thu, Jul 7, 2016 at 8:06 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Dear all,
>> accordingly to this issue
>> https://github.com/GeoNode/geonode/issues/2488
>> the DJango migrations arebroken due to the old versions of GeoNode
>> components
>> geonode_dialogos-0.4
>> geonode_agon_ratings-0.3.4
>> geonode_user_accounts-1.0.10
>> geonode_avatar-2.1.4
>> geonode_announcements-1.0.7
>> geonode_user_messages-0.1.2
>> I see the associated Pull Requests from Emanuele Tajariol have been
>> merged, but this won't be sufficient in order to let GeoNode working again.
>> We need to update the components versions, push the new packages into
>> pypi and update the GeoNoser Seup.py file with the new versions.
>> How can we do this? Is there an administrator who can help us issue the
>> new releases?
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> *Daniel Berry*
> Senior Software Engineer | Boundless
> 512-468-3946 (cell)
> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160707/9cca3c37/attachment.html>
More information about the geonode-devel
