[GeoNode-devel] Upgrade to GeoServer 2.9
Erik Merkle emerkle at boundlessgeo.com
Fri Jul 8 07:14:28 PDT 2016
Alessio,
The latest stable GeoGig jars are already being pushed to the Boundless
repo here:
https://repo.boundlessgeo.com/snapshot
The 1.0-SNAPSHOT version is stable and what the plugin is using (the plugin
for GS 2.8 uses 1.0-SNAPSHOT and 2.9 and master will use the same GeoGig
1.0-SNAPSHOT version as soon as I get the PRs merged). You can build
against the GeoGig jars by adding something like this to your POM:
    <dependency>
      <groupId>org.locationtech.geogig</groupId>
      <artifactId>geogig-web-api</artifactId>
      <version>1.0-SNAPSHOT</version>
    </dependency>
There is also a Release Candidate version in the Boundless Artifactory here:
https://repo.boundlessgeo.com/release
But the latest release is version 1.0-RC2, dated early April.
As for the plugin, I've got it all working for GS 2.9 and GS 2.10 (master),
just need to finish up a few functional tests and the PRs will be created.
​Regards,
Erik
On Fri, Jul 8, 2016 at 2:41 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Very good,
> thanks for your help.
> Is there a way to push the geogig jars on the boundless maven repo when
> ready too?
> Thenaks again and kind regards,
> -A.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Fri, Jul 8, 2016 at 3:46 AM, Erik Merkle <emerkle at boundlessgeo.com>
> wrote:
>> I think I have the plugin for GeoGig ported over to GeoServer 2.9 and
>> master (2.10). I'm finishing up some testing on them and as soon as I'm
>> finished, I'll submit the PRs. Getting the plugin into the master branch on
>> GeoServer should keep the plugin from causing issues with upgrading to
>> GeoNode to use GeoServer 2.10, when that time comes.
>> Erik Merkle
>> On Thu, Jul 7, 2016 at 11:40 AM, Erik Merkle <emerkle at boundlessgeo.com>
>> wrote:
>>> All,
>>> I've started to look at getting the plugin for GeoGig ported over from
>>> GeoServer 2.8.x to 2.9.x. Most of the issues are related to the Wicket
>>> version changes and seem to be fairly easy to address. I hope to have it
>>> ported over soon and I'll update the mailing list with my progress.
>>> ​Regards,​
>>> Erik Merkle
>>> On Thu, Jul 7, 2016 at 9:44 AM, Jeffrey Johnson <ortelius at gmail.com>
>>> wrote:
>>>> +1 on moving to 2.9 with just a PR and ensuring the build works
>>>> properly on build.geonode.org
>>>> +100 to boundless and geosolutions coordinating on these issues :)
>>>> +1000 on moving to a default geoserver build that doesnt require this
>>>> plugin
>>>> On Thu, Jul 7, 2016 at 7:40 AM, Alessio Fabiani <
>>>>> Hi Daniel,
>>>>> we can discuss when you are available during our both working hours I
>>>>> guess. My timezone is Rome - Italy one.
>>>>> Thanks for your support.
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> for the attention and use of the named addressee(s) and may be confidential
>>>>> or proprietary in nature or covered by the provisions of privacy act
>>>>> On Thu, Jul 7, 2016 at 4:09 PM, Daniel Berry <dberry at boundlessgeo.com>
>>>>> wrote:
>>>>>> Alessio,
>>>>>> I would think an issue and PR would be sufficient. We should add
>>>>>> what new features or changes are included though.
>>>>>> regarding the following
>>>>>> "*We need boundless to fix geogig 2.9.x version which is currently
>>>>>> broken. We need geogig JARs to be pushed on a public maven repository,
>>>>>> otherwise GeoServer won't compile. Is there someone from boundless which
>>>>>> can eventually help us with this task?"*
>>>>>> We sure can, Erik Merkle is currently researching the level of effort
>>>>>> for GeoGig 2.9.x extension. This would be great if we could include this in
>>>>>> the GeoNode 2.5 release. Would you like to schedule a time to discuss?
>>>>>> Respectfully,
>>>>>> Daniel Berry
>>>>>> On Thu, Jul 7, 2016 at 8:13 AM, Alessio Fabiani <
>>>>>>> Dear all,
>>>>>>> I managed to succesfully update the geoserver-genode-ext to the 2.9
>>>>>>> version, but there are still two things to discuss:
>>>>>>> 1. Everyone is ok with this GeoServer version? Should we go through
>>>>>>> a GNIP or an issue and PR are sufficient?
>>>>>>> 2. We need boulndless to fix geogig 2.9.x version which is currently
>>>>>>> broken. We need geogid JARs to be pushed on a public maven repository,
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> *Daniel Berry*
>>>>>> Senior Software Engineer | Boundless
>>>>>> 512-468-3946 (cell)
>>>>>> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/d96d2e96/attachment-0001.html>
More information about the geonode-devel mailing list
