[GeoNode-devel] MapQuest has discontinued direct tile access
Dimitris Karakostis
karakostis.dimitris at gmail.com
Tue Jul 12 08:31:22 PDT 2016
I also followed the guidelines provided here:
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/production.html#production
and based on the solution provided in this issue:
https://github.com/MapStory/mapstory/issues/933
I tried with no success to set MapBox with an APIKey.
MAP_BOX_API_KEY = "my_api_key"
MAP_BASELAYERS = [...,{
"source": {"ptype": "gxp_mapboxsource", "apiKey": MAP_BOX_API_KEY},
'args': ['Satellite Imagery'],
"name": "geography-class",
"title": "Satellite MapBox",
"fixed": True,
"visibility": False,
"group":"background"
Do I set some parameter wrong?
On Tue, Jul 12, 2016 at 4:49 PM, Bart van den Eijnden <
bartvde at boundlessgeo.com> wrote:
> This will not work. GXP would need to be modified as well, but there is no
> way to do so since MapQuest only supports using a (closed) Leaflet plugin.
> There doesn’t seem to be an open API.
> Best regards,
> Bart
> On 12 Jul 2016, at 16:46, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> Hi,
> I tried to arrange (and test) the config file local_setting following the
> guide:
> after to have got the apikey from MapQuest.
> However, it doesn't work...
> Am I wrong in the local_setting?
> I modified as follow:
> MAPQUEST_API_KEY="my_apikey"
> MAP_BASELAYERS = [{
> "source": {"ptype": "gxp_olsource"},
> "type": "OpenLayers.Layer",
> "args": ["No background"],
> "fixed": True,
> "source": {"ptype": "gxp_osmsource"},
> "type": "OpenLayers.Layer.OSM",
> "name": "mapnik",
> "fixed": True,
> "group": "background"
> # "source": {
> # "ptype": "gxp_mapquestsource",
> # "apiKey":MAPQUEST_API_KEY
> # "name": "osm",
> # "group": "background",
> # "visibility": True,
> # "fixed":True
> # "source": {
> # "name": "naip",
> # "visibility": False,
> # "fixed":True
> "source": {"ptype": "gxp_mapboxsource"},
> E.
> *Da:* Bart van den Eijnden <bartvde at boundlessgeo.com>
> *Inviato:* martedì 12 luglio 2016 11.55
> *A:* Simone Dalmasso
> *Cc:* Eugenio Trumpy; Dimitris Karakostis; geonode-devel
> *Oggetto:* Re: [GeoNode-devel] MapQuest has discontinued direct tile
> access
> It seems like that, unless MapQuest changes something but it doesn’t seem
> they have any intention to do so given our communication with them so far.
> Bart
> On 12 Jul 2016, at 11:50, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
> Thanks Bart,
> interesting, so our gxp based viewers are unable to show mapquest tiles
> anymore....
> 2016-07-12 11:47 GMT+02:00 Bart van den Eijnden <bartvde at boundlessgeo.com>
>> Please note there doesn’t seem to be a legal way currently to do so, only
>> for Leaflet:
>> https://github.com/openlayers/ol3/issues/5484#issuecomment-231988134
>> Best regards,
>> Bart
>> On 12 Jul 2016, at 11:45, Simone Dalmasso <simone.dalmasso at gmail.com>
>> wrote:
>> Well everyone is still free to make their own mapquest purchase plans and
>> add it to geonode, like bing we would only comment out the code.
>> 2016-07-12 11:41 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>> Hi, what about to use this workaround (at least temporary):
>>> to set apiKey after a registration to mapquest? They allow 15000
>>> transaction for free...
>>> actually I don't know if those are enough...
>>> E.
>>> *Da:* geonode-devel <geonode-devel-bounces at lists.osgeo.org> per conto
>>> di Simone Dalmasso <simone.dalmasso at gmail.com>
>>> *Inviato:* martedì 12 luglio 2016 11.00
>>> *A:* Dimitris Karakostis
>>> *Cc:* geonode-devel
>>> access
>>> Hi, yes I think we have to remove those layers from base maps.
>>> 2016-07-12 10:49 GMT+02:00 Dimitris Karakostis <
>>> karakostis.dimitris at gmail.com>:
>>>> As of July 11 MapQuest has discontinued direct tile access.
>>>> More on the matter here:
>>>> http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
>>>> Example of broken baselayer in Geonode Demo page:
>>>> http://demo.geonode.org/layers/geonode%3Aentidad
>>>> Dimitris
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160712/b5622cbc/attachment-0001.html>
More information about the geonode-devel
