[GeoNode-devel] [GeoNode-users] Notes and remarks on GeoServer 2.9.x upgrade
Daniel Berry
dberry at boundlessgeo.com
Tue Jul 12 10:10:10 PDT 2016
Great job!
On Tue, Jul 12, 2016 at 12:02 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> the update to GeoServer 2.9.x is ready and automatically deployed by the
> continuous builder with few remarks:
> The WARs and data directories can be found here
> http://build.geonode.org/geoserver/latest/
> *ATTENTION:* for the moment the default packages (geoserver.war and
> data.zip) are still based on the old GeoServer 2.7.4 version in order to
> avoid issues during GeoNode installations
> *THE NEW WARs/ZIPs* can be found on the same folder with the classifier
> *2.9.x*
> *ATTENTION: *GeoServer 2.9.x works **only** with Java 1.8+, so you need
> to upgrade your Tomcat instances too.
> *Summarizing:*
> (http://build.geonode.org/geoserver/latest/)
> *The following ones are related to GeoServer 2.9.x*
> * - data-2.9.x.zip - geonode-geoserver-ext-2.9.x-geoserver-plugin.zip -
> geoserver-2.9.x.war The following ones are related to GeoServer 2.7.4 -
> data.zip - geonode-geoserver-ext-2.7.4-geoserver-plugin.zip -
> geoserver.war *
> *NOTICE THAT: *The automatic installations from Ubuntu and paver, still
> use GeoServer 2.7.4
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
*Daniel Berry*
Senior Software Engineer | Boundless
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160712/406ee496/attachment.html>
More information about the geonode-devel
