[GeoNode-devel] MapQuest has discontinued direct tile access
Dimitris Karakostis karakostis.dimitris at gmail.com
Tue Jul 12 23:59:25 PDT 2016
Thanks Daniel.
I will check this out.
Dimitris
On Tue, Jul 12, 2016 at 6:17 PM, Daniel Berry <dberry at boundlessgeo.com>
wrote:
> Dimitris,
> In GeoNode master Mapbox layer support has been added (XYZ). Mapbox layers
> can be added by setting the value here
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L623
> README  -
> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/api_basemaps/README.md
> Respectfully,
> Daniel Berry
> On Tue, Jul 12, 2016 at 10:31 AM, Dimitris Karakostis <
> karakostis.dimitris at gmail.com> wrote:
>> I also followed the guidelines provided here:
>> http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/production.html#production
>> and based on the solution provided in this issue:
>> https://github.com/MapStory/mapstory/issues/933
>> I tried with no success to set MapBox with an APIKey.
>> MAP_BOX_API_KEY = "my_api_key"
>> MAP_BASELAYERS = [...,{
>>     "source": {"ptype": "gxp_mapboxsource", "apiKey": MAP_BOX_API_KEY},
>>     'args': ['Satellite Imagery'],
>>     "name": "geography-class",
>>     "title": "Satellite MapBox",
>>     "fixed": True,
>>     "visibility": False,
>>     "group":"background"
>> Do I set some parameter wrong?
>> On Tue, Jul 12, 2016 at 4:49 PM, Bart van den Eijnden <
>> bartvde at boundlessgeo.com> wrote:
>>> This will not work. GXP would need to be modified as well, but there is
>>> no way to do so since MapQuest only supports using a (closed) Leaflet
>>> plugin. There doesn’t seem to be an open API.
>>> Best regards,
>>> Bart
>>> On 12 Jul 2016, at 16:46, Eugenio Trumpy <frippe12573 at hotmail.com>
>>> wrote:
>>> Hi,
>>> I tried to arrange (and test) the config file local_setting following
>>> the guide:
>>> after to have got the apikey from MapQuest.
>>> However, it doesn't work...
>>> Am I wrong in the local_setting?
>>> I modified as follow:
>>> MAPQUEST_API_KEY="my_apikey"
>>> MAP_BASELAYERS = [{
>>>     "source": {"ptype": "gxp_olsource"},
>>>     "type": "OpenLayers.Layer",
>>>     "args": ["No background"],
>>>     "fixed": True,
>>>     "source": {"ptype": "gxp_osmsource"},
>>>     "type": "OpenLayers.Layer.OSM",
>>>     "name": "mapnik",
>>>     "fixed": True,
>>>     "group": "background"
>>>    # "source": {
>>>    #      "ptype": "gxp_mapquestsource",
>>>    #      "apiKey":MAPQUEST_API_KEY
>>>    # "name": "osm",
>>>    # "group": "background",
>>>    # "visibility": True,
>>>    # "fixed":True
>>>    # "source": {
>>>    # "name": "naip",
>>>    # "visibility": False,
>>>    # "fixed":True
>>>     "source": {"ptype": "gxp_mapboxsource"},
>>> E.
>>> *Da:* Bart van den Eijnden <bartvde at boundlessgeo.com>
>>> *Inviato:* martedì 12 luglio 2016 11.55
>>> *A:* Simone Dalmasso
>>> *Cc:* Eugenio Trumpy; Dimitris Karakostis; geonode-devel
>>> *Oggetto:* Re: [GeoNode-devel] MapQuest has discontinued direct tile
>>> access
>>> It seems like that, unless MapQuest changes something but it doesn’t
>>> seem they have any intention to do so given our communication with them so
>>> far.
>>> Bart
>>> On 12 Jul 2016, at 11:50, Simone Dalmasso <simone.dalmasso at gmail.com>
>>> wrote:
>>> Thanks Bart,
>>> interesting, so our gxp based viewers are unable to show mapquest tiles
>>> anymore....
>>> 2016-07-12 11:47 GMT+02:00 Bart van den Eijnden <
>>> bartvde at boundlessgeo.com>:
>>>> Please note there doesn’t seem to be a legal way currently to do so,
>>>> only for Leaflet:
>>>> https://github.com/openlayers/ol3/issues/5484#issuecomment-231988134
>>>> Best regards,
>>>> Bart
>>>> On 12 Jul 2016, at 11:45, Simone Dalmasso <simone.dalmasso at gmail.com>
>>>> wrote:
>>>> Well everyone is still free to make their own mapquest purchase plans
>>>> and add it to geonode, like bing we would only comment out the code.
>>>> 2016-07-12 11:41 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>>>>> Hi, what about to use this workaround (at least temporary):
>>>>> to set apiKey after a registration to mapquest? They allow 15000
>>>>> transaction for free...
>>>>> actually I don't know if those are enough...
>>>>> E.
>>>>> *Da:* geonode-devel <geonode-devel-bounces at lists.osgeo.org> per conto
>>>>> di Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>> *Inviato:* martedì 12 luglio 2016 11.00
>>>>> *A:* Dimitris Karakostis
>>>>> *Cc:* geonode-devel
>>>>> access
>>>>> Hi, yes I think we have to remove those layers from base maps.
>>>>> 2016-07-12 10:49 GMT+02:00 Dimitris Karakostis <
>>>>> karakostis.dimitris at gmail.com>:
>>>>>> As of July 11 MapQuest has discontinued direct tile access.
>>>>>> More on the matter here:
>>>>>> http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
>>>>>> Example of broken baselayer in Geonode Demo page:
>>>>>> http://demo.geonode.org/layers/geonode%3Aentidad
>>>>>> Dimitris
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> Simone
>>>> Simone
>>> Simone
> *Daniel Berry*
> Senior Software Engineer | Boundless
> 512-468-3946 (cell)
> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160713/b183e010/attachment.html>
More information about the geonode-devel mailing list
