[GeoNode-devel] geonode-devel Digest, Vol 18, Issue 22
Daniel Berry dberry at boundlessgeo.com
Wed Jul 13 14:16:19 PDT 2016
Until you are ready to test out dev or the upcoming beta GeoNode 2.5
release you could replace
https://github.com/GeoNode/geonode/blob/2.4.x/geonode/settings.py#L613 with
the following:
MAPBOX_ACCESS_TOKEN = 'ADD_TOKEN_HERE'
MAP_BASELAYERS = [{
    "source": {"ptype": "gxp_olsource"},
    "type": "OpenLayers.Layer",
    "args": ["No background"],
    "visibility": False,
    "fixed": True,
    "group":"background"
    "source": {"ptype": "gxp_osmsource"},
    "type": "OpenLayers.Layer.OSM",
    "name": "mapnik",
    "visibility": True,
    "fixed": True,
    "group": "background"
    "type": "OpenLayers.Layer.XYZ",
    "args": [
        'Mapbox Dark',
        ('https://api.mapbox.com/styles/v1/mapbox/streets-v9/tiles/256/${z}/
         '${x}/${y}?access_token=%s') % (MAPBOX_ACCESS_TOKEN),
            'transitionEffect': 'resize',
            'attribution': '© Mapbox © OpenStreetMap'
    "visibility": True,
    "fixed": True,
Available styles:
replace the styles name in the xyz url, adjust the name and attribution.
streets-v9
    - Name: Mapbox Streetmap
    - Attribution: © Mapbox © OpenStreetMap
outdoors-v9
    - Name: Mapbox Outdoors
dark-v9
    - Name: Mapbox Dark
light-v9
    - Name: Mapbox Light
satellite-v9
    - Name: Mapbox Satellite
    - Attribution: © Mapbox © DigitalGlobe
satellite-streets-v9
    - Name: Mapbox Satellite Streets
    - Attribution: © Mapbox © OpenStreetMap © DigitalGlobe
Hope that helps you out!
Dan
On Wed, Jul 13, 2016 at 2:24 PM, Thomas Gertin <tgertin at vt.edu> wrote:
> I'm having trouble switching the basemap to MapBox tiles.
> @ Daniel Berry If the ability to add MapBox tiles was committed in Master,
> does this mean it is available when I install GeoNode following the
> instructions on the main GeoNode site? (sudo add-apt-repository
> ppa:geonode/stable)
> If I already have GeoNode 2.4 installed, how can I get the new master
> version?
> I tried switching out the basemap before, but I could never get it to
> work; but now with MapQuest disappearing I really need to.
> Thanks,
> Tom
> On Tue, Jul 12, 2016 at 12:17 PM, <geonode-devel-request at lists.osgeo.org>
> wrote:
>> Send geonode-devel mailing list submissions to
>>         geonode-devel at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         geonode-devel-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of geonode-devel digest..."
>> Today's Topics:
>>    1. Re: MapQuest has discontinued direct tile access
>>       (Bart van den Eijnden)
>>    2. Re: MapQuest has discontinued direct tile access (Daniel Berry)
>> Message: 1
>> Date: Tue, 12 Jul 2016 17:34:06 +0200
>> From: Bart van den Eijnden <bartvde at boundlessgeo.com>
>> To: Dimitris Karakostis <karakostis.dimitris at gmail.com>
>> Cc: Eugenio Trumpy <frippe12573 at hotmail.com>, Simone Dalmasso
>>         <simone.dalmasso at gmail.com>, geonode-devel
>>         <geonode-devel at lists.osgeo.org>
>> Subject: Re: [GeoNode-devel] MapQuest has discontinued direct tile
>>         access
>> Message-ID: <AD3CEE09-EB4D-47E2-9E2E-5D647729E658 at boundlessgeo.com>
>> Content-Type: text/plain; charset="utf-8"
>> There is no apiKey param for MapBox sources in GXP, the MapBox source in
>> GXP uses TMS access but this will likely only work for unprotected content:
>> https://github.com/boundlessgeo/gxp/blob/master/src/script/plugins/MapBoxSource.js
>> Best regards,
>> Bart
>> > On 12 Jul 2016, at 17:31, Dimitris Karakostis <
>> karakostis.dimitris at gmail.com> wrote:
>> > I also followed the guidelines provided here:
>> http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/production.html#production
>> > and based on the solution provided in this issue:
>> https://github.com/MapStory/mapstory/issues/933 <
>> https://github.com/MapStory/mapstory/issues/933>
>> > I tried with no success to set MapBox with an APIKey.
>> > MAP_BOX_API_KEY = "my_api_key"
>> > MAP_BASELAYERS = [...,{
>> >     "source": {"ptype": "gxp_mapboxsource", "apiKey": MAP_BOX_API_KEY},
>> >     'args': ['Satellite Imagery'],
>> >     "name": "geography-class",
>> >     "title": "Satellite MapBox",
>> >     "fixed": True,
>> > Do I set some parameter wrong?
>> > On Tue, Jul 12, 2016 at 4:49 PM, Bart van den Eijnden <
>> bartvde at boundlessgeo.com <mailto:bartvde at boundlessgeo.com>> wrote:
>> > This will not work. GXP would need to be modified as well, but there is
>> no way to do so since MapQuest only supports using a (closed) Leaflet
>> plugin. There doesn’t seem to be an open API.
>> > Best regards,
>> > Bart
>> >> On 12 Jul 2016, at 16:46, Eugenio Trumpy <frippe12573 at hotmail.com
>> <mailto:frippe12573 at hotmail.com>> wrote:
>> >> Hi,
>> >> I tried to arrange (and test) the config file local_setting following
>> the guide:
>> >> after to have got the apikey from MapQuest.
>> >> However, it doesn't work...
>> >> Am I wrong in the local_setting?
>> >> I modified as follow:
>> >> MAPQUEST_API_KEY="my_apikey"
>> >> MAP_BASELAYERS = [{
>> >>     "fixed": True,
>> >>     "name": "mapnik",
>> >>     "fixed": True,
>> >>    # "source": {
>> >>    #      "ptype": "gxp_mapquestsource",
>> >>    #      "apiKey":MAPQUEST_API_KEY
>> >>    # "name": "osm",
>> >>    # "group": "background",
>> >>    # "visibility": True,
>> >>    # "fixed":True
>> >>    # "source": {
>> >>    # "name": "naip",
>> >>    # "visibility": False,
>> >>    # "fixed":True
>> >>     "source": {"ptype": "gxp_mapboxsource"},
>> >> E.
>> >> Da: Bart van den Eijnden <bartvde at boundlessgeo.com <mailto:
>> >> Inviato: martedì 12 luglio 2016 11.55
>> >> A: Simone Dalmasso
>> >> Cc: Eugenio Trumpy; Dimitris Karakostis; geonode-devel
>> >> Oggetto: Re: [GeoNode-devel] MapQuest has discontinued direct tile
>> access
>> >> It seems like that, unless MapQuest changes something but it doesn’t
>> seem they have any intention to do so given our communication with them so
>> far.
>> >> Bart
>> >>> On 12 Jul 2016, at 11:50, Simone Dalmasso <simone.dalmasso at gmail.com
>> <mailto:simone.dalmasso at gmail.com>> wrote:
>> >>> Thanks Bart,
>> >>> interesting, so our gxp based viewers are unable to show mapquest
>> tiles anymore....
>> >>> 2016-07-12 11:47 GMT+02:00 Bart van den Eijnden <
>> bartvde at boundlessgeo.com <mailto:bartvde at boundlessgeo.com>>:
>> >>> Please note there doesn’t seem to be a legal way currently to do so,
>> only for Leaflet:
>> >>> https://github.com/openlayers/ol3/issues/5484#issuecomment-231988134
>> <https://github.com/openlayers/ol3/issues/5484#issuecomment-231988134>
>> >>> Best regards,
>> >>> Bart
>> >>>> On 12 Jul 2016, at 11:45, Simone Dalmasso <simone.dalmasso at gmail.com
>> >>>> Well everyone is still free to make their own mapquest purchase
>> plans and add it to geonode, like bing we would only comment out the code.
>> >>>> 2016-07-12 11:41 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com
>> <mailto:frippe12573 at hotmail.com>>:
>> >>>> Hi, what about to use this workaround (at least temporary):
>> >>>> to set apiKey after a registration to mapquest? They allow 15000
>> transaction for free...
>> >>>> actually I don't know if those are enough...
>> >>>> E.
>> >>>> Da: geonode-devel <geonode-devel-bounces at lists.osgeo.org <mailto:
>> geonode-devel-bounces at lists.osgeo.org>> per conto di Simone Dalmasso <
>> simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>>
>> >>>> Inviato: martedì 12 luglio 2016 11.00
>> >>>> A: Dimitris Karakostis
>> >>>> Cc: geonode-devel
>> access
>> >>>> Hi, yes I think we have to remove those layers from base maps.
>> >>>> 2016-07-12 10:49 GMT+02:00 Dimitris Karakostis <
>> karakostis.dimitris at gmail.com <mailto:karakostis.dimitris at gmail.com>>:
>> >>>> As of July 11 MapQuest has discontinued direct tile access.
>> >>>> More on the matter here:
>> http://devblog.mapquest.com/2016/06/15/modernization-of-mapquest-results-in-changes-to-open-tile-access/
>> >>>> Example of broken baselayer in Geonode Demo page:
>> >>>> http://demo.geonode.org/layers/geonode%3Aentidad <
>> http://demo.geonode.org/layers/geonode%3Aentidad>
>> >>>> Dimitris
>> >>>> _______________________________________________
>> >>>> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
>> >>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel <
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel>
>> >>>> Simone
>> >>>> Simone
>> >>> Simone
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160712/f20fb7f9/attachment-0001.html
>> Message: 2
>> Date: Tue, 12 Jul 2016 11:17:02 -0500
>> From: Daniel Berry <dberry at boundlessgeo.com>
>> Cc: Bart van den Eijnden <bartvde at boundlessgeo.com>, geonode-devel
>>         access
>> Message-ID:
>>         <CAHEpKprAo0fZnSTUNJcGjg-qjDZ_k+aZ6=
>> Wh4Vr-svtsHQP0sg at mail.gmail.com>
>> Dimitris,
>> In GeoNode master Mapbox layer support has been added (XYZ). Mapbox layers
>> can be added by setting the value here
>> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L623
>> README  -
>> https://github.com/GeoNode/geonode/blob/master/geonode/contrib/api_basemaps/README.md
>> Respectfully,
>> Daniel Berry
>> On Tue, Jul 12, 2016 at 10:31 AM, Dimitris Karakostis <
>> >     "fixed": True,
>> >> Best regards,
>> >> Bart
>> >> On 12 Jul 2016, at 16:46, Eugenio Trumpy <frippe12573 at hotmail.com>
>> wrote:
>> >> Hi,
>> the
>> >> guide:
>> >> MAP_BASELAYERS = [{
>> >>     "fixed": True,
>> >>     "name": "mapnik",
>> >>     "fixed": True,
>> >>    # "source": {
>> >>    # "name": "osm",
>> >>    # "fixed":True
>> >>    # "source": {
>> >>    # "name": "naip",
>> >>    # "fixed":True
>> >> E.
>> >> *Da:* Bart van den Eijnden <bartvde at boundlessgeo.com>
>> >> *Inviato:* martedì 12 luglio 2016 11.55
>> >> *A:* Simone Dalmasso
>> >> *Cc:* Eugenio Trumpy; Dimitris Karakostis; geonode-devel
>> >> *Oggetto:* Re: [GeoNode-devel] MapQuest has discontinued direct tile
>> >> access
>> seem
>> far.
>> >> Bart
>> >> On 12 Jul 2016, at 11:50, Simone Dalmasso <simone.dalmasso at gmail.com>
>> >> wrote:
>> >> Thanks Bart,
>> >> interesting, so our gxp based viewers are unable to show mapquest tiles
>> >> anymore....
>> >>> only for Leaflet:
>> >>> Best regards,
>> >>> Bart
>> >>> On 12 Jul 2016, at 11:45, Simone Dalmasso <simone.dalmasso at gmail.com>
>> >>> wrote:
>> >>> Well everyone is still free to make their own mapquest purchase plans
>> >>> 2016-07-12 11:41 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> >>>> E.
>> >>>> *Da:* geonode-devel <geonode-devel-bounces at lists.osgeo.org> per
>> conto
>> >>>> di Simone Dalmasso <simone.dalmasso at gmail.com>
>> >>>> *Inviato:* martedì 12 luglio 2016 11.00
>> >>>> *A:* Dimitris Karakostis
>> >>>> *Cc:* geonode-devel
>> >>>> access
>> >>>> karakostis.dimitris at gmail.com>:
>> >>>>> Dimitris
>> >>>> Simone
>> >>> Simone
>> >> Simone
>> *Daniel Berry*
>> Senior Software Engineer | Boundless
>> 512-468-3946 (cell)
>> @boundlessgeo
>> URL: <
>> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160712/7adf9980/attachment.html
>> Subject: Digest Footer
>> End of geonode-devel Digest, Vol 18, Issue 22
*Daniel Berry*
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160713/afefbbf5/attachment-0001.html>
More information about the geonode-devel mailing list
