[GeoNode-devel] DB migrations
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jun 1 03:43:47 PDT 2016
Yes we used south. But the migrations squash is new to me and looks a cool
feature.
2016-06-01 10:57 GMT+02:00 Emanuele Tajariol <etj at geo-solutions.it>:
> Hi Simone,
> for each release we could as well provide the unique migration script by
> making django squash the single migrations created while developing the new
> release, as documented in
> https://docs.djangoproject.com/en/1.8/topics/migrations/#squashing-
> migrations
> I thought this was quite a new feature in geonode since migrations have
> been
> introduced in django 1.7 as far I can see. Did you use South?
> Cheers,
> Emanuele
> Alle 10:27:57 di Wednesday 1 June 2016, Simone Dalmasso ha scritto:
> > We used to have migrations in the past but then dropped them in favor of
> a
> > unique migration script between stable versions. This because there were
> so
> > many changes that most of the migrations were actually useless and
> messing
> > up the procedure. I'm +0
> > Il mercoledì 1 giugno 2016, Alessio Fabiani <
> > alessio.fabiani at geo-solutions.it> ha scritto:
> > > +1
> > > Best Regards,
> > > Alessio Fabiani.
> > > GeoServer Professional Services from the experts!
> > > Visit http://goo.gl/it488V for more information.
> > > Ing. Alessio Fabiani
> > > @alfa7691
> > > Founder/Technical Lead
> > > GeoSolutions S.A.S.
> > > Via di Montramito 3/A
> > > 55054 Massarosa (LU)
> > > Italy
> > > phone: +39 0584 962313
> > > fax: +39 0584 1660272
> > > mob: +39 331 6233686
> > > http://www.geo-solutions.it
> > > http://twitter.com/geosolutions_it
> > > *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> > > Le informazioni contenute in questo messaggio di posta elettronica e/o
> > > nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> > > loro utilizzo è consentito esclusivamente al destinatario del
> messaggio,
> > > per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> > > messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> > > darcene notizia via e-mail e di procedere alla distruzione del
> messaggio
> > > stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
> stesso,
> > > divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> > > utilizzarlo per finalità diverse, costituisce comportamento contrario
> ai
> > > principi dettati dal D.Lgs. 196/2003.
> > > The information in this message and/or attachments, is intended solely
> > > for the attention and use of the named addressee(s) and may be
> > > confidential or proprietary in nature or covered by the provisions of
> > > privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> Data
> > > Protection Code).Any use not in accord with its purpose, any
> disclosure,
> > > reproduction, copying, distribution, or either dissemination, either
> > > whole or partial, is strictly forbidden except previous formal approval
> > > of the named
> > > addressee(s). If you are not the intended recipient, please contact
> > > immediately the sender by telephone, fax or e-mail and delete the
> > > information in this message that has been received in error. The sender
> > > does not give any warranty or accept liability as the content, accuracy
> > > or completeness of sent messages and accepts no responsibility for
> > > changes made after they were sent or for other risks which arise as a
> > > result of e-mail transmission, viruses, etc.
> > > On Wed, Jun 1, 2016 at 10:21 AM, Emanuele Tajariol <
> > > <javascript:_e(%7B%7D,'cvml','etj at geo-solutions.it');>> wrote:
> > >> Hi List,
> > >> in order to have django properly update the db schema when some
> changes
> > >> in the
> > >> models are performed, it needs some initial migration files, as
> > >> described in
> > >> https://docs.djangoproject.com/en/1.8/topics/migrations/.
> > >> This change may still be related to the porting to django 1.8.
> > >> I can provide a PR for this.
> > >> Cheers,
> > >> Emanuele
> > >> Visit http://goo.gl/NWWaa2 for more information.
> > >> Ing. Emanuele Tajariol
> > >> Technical Lead
> > >> GeoSolutions S.A.S.
> > >> Italy
> > >> mob: +39 380 2116282
> > >> _______________________________________________
> > >> geonode-devel mailing list
> > >> geonode-devel at lists.osgeo.org
> > >> <javascript:_e(%7B%7D,'cvml','geonode-devel at lists.osgeo.org');>
> > >> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Technical Lead
> GeoSolutions S.A.S.
> Italy
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160601/b0d61b6d/attachment-0001.html>
More information about the geonode-devel
