[GeoNode-devel] getting started #2
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 17 05:35:02 PDT 2016
We may make sure that the updateip command also updates the thumbnail url,
yes.
Thanks for the feedback
2016-06-17 13:16 GMT+02:00 jonas ellehauge <jonas at ellevator.net>:
> Thanks - and yes, I loaded the layer before changing site ip / domain name.
> That is rather unexpected. Also very inconvenient when migrating data from
> one host to another. Would that qualify as a bug?
> On 06/07/2016 01:39 PM, Simone Dalmasso wrote:
> hi,
> make sure that the SITEURL is set to the geonode public domain, the one
> that you use to access it from your host system. You can do that with "sudo
> geonode-updateip yourdomain".
> If you want to add an external layer to the map composer then you will
> have to add the host in the PROXY_ALLOWED_HOSTS, but only in this case.
> For the thumbnail url, is it possible that you loaded some layers before
> changing the SITEURL?
> 2016-06-07 11:53 GMT+02:00 jonas ellehauge <jonas at ellevator.net>:
>> Hi again,
>> After I got geonode up and running on a VirtualBox guest Ubuntu 14.04
>> server 64 bit, I still got various error messages and pages / images / map
>> content that wouldn't show. I figured it might be related to geonode
>> getting confused by the port forwarding on VB (eg forwarded http requests
>> from 2280 on host machine to 80 on guest).
>> It took a while to figure out how to set up VB with a local static IP
>> address, and set the goenode-updateip to the correct IP. Now it mostly
>> works fine except for the attached 403 error on http://<host>/maps/new -
>> something about a proxy not being in the PROXY_ALLOWED_HOSTS setting.
>> What is the way to resolve this on a production server?
>> On this test server, I just set debug to True and restarted apache2 and
>> the error is gone.
>> I find it surprising that some requests from the client are sent directly
>> to the host IP instead of its domain name. E.g. some requests are sent in
>> my case as:
>> http://10.0.0.206/uploaded/thumbs/layer-15349b62-2718-11e6-81f4-080027626197-thumb.png
>> instead of
>> http://geonode01/uploaded/thumbs/layer-15349b62-2718-11e6-81f4-080027626197-thumb.png
>> Why is that?
>> Cheers,
>> Jonas
>> awesomemap.tools | @Facebook
>> <http://www.facebook.com/awesomemaptools.net> | @Twitter
>> <http://twitter.com/awetools> | ellvtr at Github <https://github.com/ellvtr>
>> | awesomemaptools at Github <https://github.com/awesomemaptools/> |
>> jonas at LinkedIn <http://www.linkedin.com/in/jonasellehauge/> |
>> awesomemaptools at LinkedIn <https://www.linkedin.com/company/10303547> | +47
>> 984 81 362 <%2B47%20984%2081%20362> @mobile | jonas_ellehauge at Skype
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
> awesomemap.tools | @Facebook <http://www.facebook.com/awesomemaptools.net>
> | @Twitter <http://twitter.com/awetools> | ellvtr at Github
> <https://github.com/ellvtr> | awesomemaptools at Github
> <https://github.com/awesomemaptools/> | jonas at LinkedIn
> <http://www.linkedin.com/in/jonasellehauge/> | awesomemaptools at LinkedIn
> <https://www.linkedin.com/company/10303547> | +47 984 81 362 @mobile |
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160617/c03134cb/attachment.html>
More information about the geonode-devel mailing list
