[GeoNode-devel] developer setup
Ariel Nunez
ingenieroariel at gmail.com
Fri Jun 17 07:43:10 PDT 2016
Paolo, the way to do it is to first do a migrate auth and after that you
can do a regular syncdb.
python manage.py migrate auth
python manage.py syncdb
Not sure if that can be avoided - it seems a bit weird to me that a regular
syncdb would not work.
-a
On Fri, Jun 17, 2016 at 9:40 AM, Paolo Corti <pcorti at gmail.com> wrote:
> It seems that from Django 1.8 it is needed to run migrate with the
> --fake-initial settings
> http://stackoverflow.com/questions/29760817/how-can-i-resolve-django-content-type-already-exists
> Though, I am now getting a different error:
> Applying layers.0001_initial...Traceback (most recent call last):
> django.db.utils.ProgrammingError: relation "layers_attribute" already
> exists
> p
> On Fri, Jun 17, 2016 at 10:34 AM, Paolo Corti <pcorti at gmail.com> wrote:
> > Hi developers
> > I am trying to install geonode from master (I haven't done this since
> > 2.4 was released). I am wondering which is the way to setup a
> > developer geonode instance.
> > Once it was possible, following this instructions [1], to generate an
> > environment using paver setup, which was taking care of the database
> > initial sync.
> > Now setup just set geoserver.
> > If I try to create the database, I get this error:
> > Applying contenttypes.0001_initial...Traceback (most recent call last):
> > File "./manage.py", line 29, in <module>
> > execute_from_command_line(sys.argv)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> > line 354, in execute_from_command_line
> > utility.execute()
> > File
> > line 346, in execute
> > self.fetch_command(subcommand).run_from_argv(self.argv)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/base.py",
> > line 394, in run_from_argv
> > self.execute(*args, **cmd_options)
> > File
> > line 445, in execute
> > output = self.handle(*args, **options)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
> > line 222, in handle
> > executor.migrate(targets, plan, fake=fake, fake_initial=fake_initial)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/executor.py",
> > line 110, in migrate
> > self.apply_migration(states[migration], migration, fake=fake,
> > File
> > line 148, in apply_migration
> > state = migration.apply(state, schema_editor)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/migration.py",
> > line 115, in apply
> > operation.database_forwards(self.app_label, schema_editor,
> > old_state, project_state)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/operations/models.py",
> > line 59, in database_forwards
> > schema_editor.create_model(model)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/base/schema.py",
> > line 286, in create_model
> > self.execute(sql, params or None)
> > File
> > line 111, in execute
> > cursor.execute(sql, params)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/utils.py",
> > line 79, in execute
> > return super(CursorDebugWrapper, self).execute(sql, params)
> > File
> > line 64, in execute
> > return self.cursor.execute(sql, params)
> > File
> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/utils.py",
> > line 98, in __exit__
> > six.reraise(dj_exc_type, dj_exc_value, traceback)
> > File
> > line 62, in execute
> > return self.cursor.execute(sql)
> > django.db.utils.ProgrammingError: relation "django_content_type" already
> exists
> > I believe it is also important to always keep documentation updated.
> > thanks
> > p
> > [1] https://github.com/GeoNode/geonode
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net
> > twitter: @capooti
> > skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160617/cb86567d/attachment.html>
More information about the geonode-devel
