[GeoNode-devel] developer setup
Paolo Corti pcorti at gmail.com
Fri Jun 17 08:01:26 PDT 2016
Yes everything works, as said it was failing because my configuration.
Thanks for updating the doc, I can do it as well if you have no time
cheers
p
On Fri, Jun 17, 2016 at 10:58 AM, Sara Safavi <ssafavi at boundlessgeo.com> wrote:
> Paolo - does running 'paver sync' following the initial 'paver setup' work
> for you? 'paver sync' currently works in the Travis CI builds, and my local
> dev, without raising those migration-related exceptions, so it should fix
> your trouble. Agree that the docs should be updated, I'll get on that. :)
> On Fri, Jun 17, 2016 at 9:43 AM, Ariel Nunez <ingenieroariel at gmail.com>
> wrote:
>> Paolo, the way to do it is to first do a migrate auth and after that you
>> can do a regular syncdb.
>> python manage.py migrate auth
>> python manage.py syncdb
>> Not sure if that can be avoided - it seems a bit weird to me that a
>> regular syncdb would not work.
>> -a
>> On Fri, Jun 17, 2016 at 9:40 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>> It seems that from Django 1.8 it is needed to run migrate with the
>>> --fake-initial settings
>>> (http://stackoverflow.com/questions/29760817/how-can-i-resolve-django-content-type-already-exists)
>>> Though, I am now getting a different error:
>>> Applying layers.0001_initial...Traceback (most recent call last):
>>> django.db.utils.ProgrammingError: relation "layers_attribute" already
>>> exists
>>> p
>>> On Fri, Jun 17, 2016 at 10:34 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>> > Hi developers
>>> > I am trying to install geonode from master (I haven't done this since
>>> > 2.4 was released). I am wondering which is the way to setup a
>>> > developer geonode instance.
>>> > Once it was possible, following this instructions [1], to generate an
>>> > environment using paver setup, which was taking care of the database
>>> > initial sync.
>>> > Now setup just set geoserver.
>>> > If I try to create the database, I get this error:
>>> >   Applying contenttypes.0001_initial...Traceback (most recent call
>>> > last):
>>> >   File "./manage.py", line 29, in <module>
>>> >     execute_from_command_line(sys.argv)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> > line 354, in execute_from_command_line
>>> >     utility.execute()
>>> >   File
>>> > line 346, in execute
>>> >     self.fetch_command(subcommand).run_from_argv(self.argv)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/base.py",
>>> > line 394, in run_from_argv
>>> >     self.execute(*args, **cmd_options)
>>> >   File
>>> > line 445, in execute
>>> >     output = self.handle(*args, **options)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
>>> > line 222, in handle
>>> >     executor.migrate(targets, plan, fake=fake,
>>> > fake_initial=fake_initial)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/executor.py",
>>> > line 110, in migrate
>>> >     self.apply_migration(states[migration], migration, fake=fake,
>>> >   File
>>> > line 148, in apply_migration
>>> >     state = migration.apply(state, schema_editor)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/migration.py",
>>> > line 115, in apply
>>> >     operation.database_forwards(self.app_label, schema_editor,
>>> > old_state, project_state)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/operations/models.py",
>>> > line 59, in database_forwards
>>> >     schema_editor.create_model(model)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/base/schema.py",
>>> > line 286, in create_model
>>> >     self.execute(sql, params or None)
>>> >   File
>>> > line 111, in execute
>>> >     cursor.execute(sql, params)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/utils.py",
>>> > line 79, in execute
>>> >     return super(CursorDebugWrapper, self).execute(sql, params)
>>> >   File
>>> > line 64, in execute
>>> >     return self.cursor.execute(sql, params)
>>> >   File
>>> > "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/utils.py",
>>> > line 98, in __exit__
>>> >     six.reraise(dj_exc_type, dj_exc_value, traceback)
>>> >   File
>>> > line 62, in execute
>>> >     return self.cursor.execute(sql)
>>> > django.db.utils.ProgrammingError: relation "django_content_type"
>>> > already exists
>>> > I believe it is also important to always keep documentation updated.
>>> > thanks
>>> > p
>>> > [1] https://github.com/GeoNode/geonode
>>> > Paolo Corti
>>> > Geospatial software developer
>>> > web: http://www.paolocorti.net
>>> > twitter: @capooti
>>> > skype: capooti
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
