[GeoNode-devel] Uploading layer hangs at: Performing Final GeoServer Config Step
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 24 09:46:15 PDT 2016
Hm, and this is happening both in dev mode and production?
btw have you considered using the official release of geonode 2.4?
2016-06-24 17:54 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
> Thanks again Simone.
> I have corrected the entry in the geoserver data
> dir/security/auth/geonodeAuthProvider/config.xml; and the geoserver now
> keeps the login from geonode.
> However; the upload still hangs in the same place as initially reported.
> What has also been happening is that the data makes its way into geoserver
> and is visible from geoserver as a layer. but it will not be visible in
> geonode until the update layers command is run and then the output of the
> command will say that the layer has been created. at that point the layer
> is visible in geonode.
> May Yahweh bless you and keep you.
> May Yahweh let his face shine on you and be gracious to you.
> May Yahweh show you his face and bring you peace.
> (New Jerusalem Bible Numbers 6:24-26)
> email: marcathian at gmail.com
> Home: 453-3632 / 453-3454
> Mobile: 719-2248
> Work: 468-4434
> On Fri, Jun 24, 2016 at 9:15 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> You need to tell geoserver where to correctly find geonode. In the
>> geoserver data dir/security/auth/geonodeAuthProvider/config.xml you can set
>> the correct url of your geonode, then restart tomcat.
>> 2016-06-24 15:12 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>> Hello Simone;
>>> Thanks for your assistance so far.
>>> The login from geonode is not kept when the /geoserver is accessed.
>>> I have to login again to the geoserver.
>>> How do I resolve this?
>>> Mobile: 719-2248
>>> Work: 468-4434
>>> On Fri, Jun 24, 2016 at 7:31 AM, Simone Dalmasso <
>>>> Than is not that the issue. Other thing it could be is a communication
>>>> issue between geonode and geoserver which could lead to "no such layer".
>>>> Does geoserver correctly keeps the login from geonode when you access
>>>> "/geoserver" or "localhost:8080/geoserver"?
>>>> 2016-06-24 12:07 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>:
>>>>> It is being done in a VM with 4 cores, and 8Gig of RAM.
>>>>> the Xms and Xmx values for tomcat are 4096m.
>>>>> How may i provide the aditional resources to geoserver?
>>>>> Mobile: 719-2248
>>>>> Work: 468-4434
>>>>> On Fri, Jun 24, 2016 at 3:27 AM, Simone Dalmasso <
>>>>>> Hi, could it be that your machine is not powerful enough? Seems that
>>>>>> geoserver has not enough resources to process the layer in reasonable time.
>>>>>> 2016-06-24 2:18 GMT+02:00 Marcathian Alexander <marcathian at gmail.com>
>>>>>>> Hello;
>>>>>>> I am preparing to deploy a geonode installation using GeoNode
>>>>>>> version 2.4.dev20160527174840.
>>>>>>> When attempting to upload an esri shp file through the upload layers
>>>>>>> page the process hangs at the message: performing Final GeoServer Config
>>>>>>> Step.
>>>>>>> I shall be grateful for assistance in resolving the issue.  The
>>>>>>> content of the logs are below.
>>>>>>> output from the postgresql log:
>>>>>>> 2016-06-23 18:44:40 AST [5406-25] geonode at geonode WARNING:  01000:
>>>>>>> ST_Force_2d signature was deprecated in 2.1.0. Please use ST_Force2D
>>>>>>> 2016-06-23 18:44:40 AST [5406-26] geonode at geonode CONTEXT:  SQL
>>>>>>> function "st_force_2d" during startup
>>>>>>> 2016-06-23 18:44:40 AST [5406-27] geonode at geonode LOCATION:
>>>>>>>  exec_stmt_raise, pl_exec.c:3216
>>>>>>> 2016-06-23 18:44:40 AST [5406-28] geonode at geonode STATEMENT:
>>>>>>>  SELECT
>>>>>>> ST_AsText(ST_Force_2D(ST_Envelope(ST_Extent("the_geom"::geometry)))) FROM
>>>>>>> "public"."West_Highway"
>>>>>>> 2016-06-23 18:44:46 AST [5406-29] geonode at geonode WARNING:  01000:
>>>>>>> 2016-06-23 18:44:46 AST [5406-30] geonode at geonode CONTEXT:  SQL
>>>>>>> 2016-06-23 18:44:46 AST [5406-31] geonode at geonode LOCATION:
>>>>>>> 2016-06-23 18:44:46 AST [5406-32] geonode at geonode STATEMENT:
>>>>>>>  SELECT "fid",encode(ST_AsBinary(ST_Force_2D("the_geom")),'base64') as
>>>>>>> "the_geom" FROM "public"."West_Highway" WHERE  "the_geom" &&
>>>>>>> ST_GeomFromText('POLYGON ((487266.2853154304 1518248.9631568347,
>>>>>>> 487266.2853154304 1546225.3912784152, 524325.9693206407 1546225.3912784152,
>>>>>>> 524325.9693206407 1518248.9631568347, 487266.2853154304
>>>>>>> 1518248.9631568347))', 2006) AND ST_Intersects("the_geom",
>>>>>>> 1518248.9631568347))', 2006))
>>>>>>> Output from TomCat7 log:
>>>>>>> Jun 23, 2016 6:44:40 PM org.geoserver.importer.rest.TaskResource
>>>>>>> handlePost
>>>>>>> INFO: Handling POST of multipart/form-data;
>>>>>>> boundary=----------ThIs_Is_tHe_bouNdaRY_$
>>>>>>> 23 Jun 18:44:40 WARN [geoserver.security] - Could not find factory
>>>>>>> for store : DataStoreInfoImpl[datastore]. Unable to encrypt connection
>>>>>>> parameters.
>>>>>>> 23 Jun 18:44:40 INFO [org.geoserver] - Loaded store 'datastore',
>>>>>>> enabled
>>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - begining import
>>>>>>> 23 Jun 18:44:40 ERROR [geoserver.rest] - No such layer: West_Highway
>>>>>>> org.geoserver.rest.RestletException
>>>>>>> at
>>>>>>> org.geoserver.catalog.rest.LayerFinder.findTarget(LayerFinder.java:39)
>>>>>>> at org.restlet.Finder.handle(Finder.java:268)
>>>>>>> at
>>>>>>> org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
>>>>>>> at org.restlet.Filter.doHandle(Filter.java:105)
>>>>>>> at org.restlet.Filter.handle(Filter.java:134)
>>>>>>> at org.restlet.Router.handle(Router.java:444)
>>>>>>> at
>>>>>>> org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
>>>>>>> at
>>>>>>> com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
>>>>>>> at
>>>>>>> org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
>>>>>>> at
>>>>>>> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
>>>>>>> at
>>>>>>> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
>>>>>>> at
>>>>>>> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
>>>>>>> at
>>>>>>> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
>>>>>>> at
>>>>>>> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
>>>>>>> at
>>>>>>> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
>>>>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
>>>>>>> at
>>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
>>>>>>> at
>>>>>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>>>>> at
>>>>>>> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
>>>>>>> at
>>>>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>>>>> at
>>>>>>> at
>>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
>>>>>>> at
>>>>>>> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
>>>>>>> at
>>>>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
>>>>>>> at
>>>>>>> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
>>>>>>> at
>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>>>> at
>>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
>>>>>>> at
>>>>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
>>>>>>> at
>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>>>> at
>>>>>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>>>>>>> at
>>>>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>>>>> at
>>>>>>> at
>>>>>>> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
>>>>>>> at
>>>>>>> at
>>>>>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:111)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>>>>> at
>>>>>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>>>>> at
>>>>>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
>>>>>>> at
>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>>>>> at
>>>>>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>>>>>>> at
>>>>>>> at
>>>>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>>>>> at
>>>>>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>>>>> at
>>>>>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>>>>> at
>>>>>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>>>>> at
>>>>>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>>>>> at
>>>>>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>>>>> at
>>>>>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>>>>> at
>>>>>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>>>>> at
>>>>>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>>>>>> at
>>>>>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>>>>> at
>>>>>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>>>>> at
>>>>>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>>>>> at
>>>>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>>>>> at java.lang.Thread.run(Thread.java:745)
>>>>>>> 23 Jun 18:44:40 INFO [geoserver.importer] - load to target took 104
>>>>>>> 23 Jun 18:44:45 INFO [org.geoserver] - Loaded feature type 'null',
>>>>>>> enabled
>>>>>>> 23 Jun 18:44:45 WARN [catalog.impl] - Failed to load actual store
>>>>>>> for FeatureTypeInfoImpl[null]
>>>>>>> 23 Jun 18:44:45 INFO [catalog.rest] - PUT
>>>>>>> FeatureTypedatastore,West_Highway updated metadata only
>>>>>>> 23 Jun 18:44:46 INFO [geoserver.wms] -
>>>>>>> Request: getServiceInfo
>>>>>>> Request: reflect
>>>>>>> SldBody = null
>>>>>>> ValidateSchema = false
>>>>>>> Sld = null
>>>>>>> StyleUrl = null
>>>>>>> Width = 200
>>>>>>> Height = 150
>>>>>>> Interpolations = []
>>>>>>> StyleFormat = sld
>>>>>>> Transparent = false
>>>>>>> TilesOrigin = null
>>>>>>> Tiled = false
>>>>>>> Palette = null
>>>>>>> FeatureVersion = null
>>>>>>> SRS = null
>>>>>>> Styles = [StyleImpl[ name=geonode_West_Highway1]]
>>>>>>> Layers = [org.geoserver.wms.MapLayerInfo at 1ee3d97d]
>>>>>>> MaxFeatures = null
>>>>>>> Crs = null
>>>>>>> Bbox = null
>>>>>>> RemoteOwsType = null
>>>>>>> RemoteOwsURL = null
>>>>>>> Env = {}
>>>>>>> FormatOptions = {}
>>>>>>> Angle = 0.0
>>>>>>> CQLFilter = null
>>>>>>> Elevation = []
>>>>>>> FeatureId = null
>>>>>>> StartIndex = null
>>>>>>> ViewParams = null
>>>>>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>>>>>> Exceptions = SE_XML
>>>>>>> StyleBody = null
>>>>>>> SldVersion = null
>>>>>>> StyleVersion = null
>>>>>>> ScaleMethod = null
>>>>>>> Format = image/png8
>>>>>>> Buffer = 0
>>>>>>> Time = []
>>>>>>> Filter = null
>>>>>>> Filters = null
>>>>>>> Get = true
>>>>>>> BaseUrl = http://sling.gosl.gov.lc:8080/geoserver/
>>>>>>> RawKvp = {FORMAT=image/png8, HEIGHT=150,
>>>>>>> LAYERS=geonode:West_Highway, WIDTH=200}
>>>>>>> RequestCharset = UTF-8
>>>>>>> Version = null
>>>>>>> Request = GetMap
>>>>>>> Mobile: 719-2248
>>>>>>> Work: 468-4434
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160624/3c0bdfad/attachment-0001.html>
More information about the geonode-devel mailing list
