[GeoNode-devel] testing importing GeoNode metadata into QGIS
Thomas Gertin tgertin at vt.edu
Tue Jun 28 06:08:37 PDT 2016
Could someone help with this issue?
I am testing downloading a shapefile from GeoNode and the metadata then
opening the dataset in QGIS.
This is the layer I am testing:
http://geonode.state.gov/layers/geonode%3ASyria_RefugeeSites_2016Jan21_HIU_DoS0
   I downloaded the data as a shapefile.
   I then downloaded the metadata and saved it as an xml file with the same
   basename as the shapefile.
here is the directory with all of my files:
[image: pic-of-dir]
<https://cloud.githubusercontent.com/assets/2665840/16394012/2cd1102e-3c81-11e6-8cb8-2f1f91fccfcc.PNG>
I then opened this shapefile in QGIS 2.14.3, with no plug-ins. I do not see
the metadata I am hoping to see. If I right-click on the layer and go to
properties it opens the layer properties window. Then if I click on the
Metadata tab, the properties only show General properties. All of the field
in the Description section are blank. Is there a way to populate these
fields? Are the metadata fields supposed to automatically show up? Or is
there a way you need to import the xls manually by selecting the xls file?
Thanks,
Tom G
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160628/14c0543f/attachment.html>
More information about the geonode-devel mailing list
