[GeoNode-devel] Layer thumbnail keeps previous version of style
Andrea Pogliaghi
andrea.pogliaghi at gmail.com
Wed Mar 30 01:57:55 PDT 2016
Hello to everybody.
I am using Geonode 2.4 version (on Linux Ubuntu 14.04 LTS with
Postgres/postgis) and I noticed that when I change the style of a layer
(for instance the fill color), the layer thumbnail is not updated with the
new version of the style but it reflects the previous one.
For instance, to replicate it:
1. Choose a layer. Let's suppose it has a RED fill color.
2. Edit the style of the layer and change the fill color to BLUE
3. Save the style and go to the "layers" page. The thumbnail of the color
is RED (should be BLUE)
4. Edit the style of the layer and change the fill color to YELLOW.
5. Save the style and go to the "layers" page. The thumbnail of the color
is BLUE (should be YELLOW)
and so on...
I looked into the source code and it seems that the update of the style in
Gesoserver (A) and the generation of the new thumbnail (B) are carried out
in the wrong sequence, i.e. the new thumbnail is generated before the new
style is updated onto Geoserver, and this explains why in the layer
thumbnail there is the previous version of the style. (i.e. B-A instead of
A-B)
A workaround of the problem may be the following: when choosing a color in
the colorpicker, click on the desired color twice instead of a single time,
allowing a couple of seconds between the clicks. In this way the "style
update" is triggered two times with the same color, and the layer thumbnail
will be in sync with the style.
Obviously this is only a workaround and it does not solve the bug,
I made a modification in the "geoserver/views.py" file, changing reversing
the sequence of update so that it saves the style onto geoserver before
generating the thumbnail.
With this patch it seems that the bug is solved.
Since I am new to the mailing list, what should I do?
Should I open a bug on Geonode GIT?
Do I have to send the patch to someone to review it and/or eventually apply
in on the trunk?
Thank you all,
Andrea
ing. Andrea Pogliaghi
Gesp Srl - Sistemi Informativi Geografici
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160330/273bae17/attachment.html>
More information about the geonode-devel
