[GeoNode-devel] after mass data import : "KeyError: 'request'" when clicking on a document
Simone Dalmasso
simone.dalmasso at gmail.com
Fri May 6 01:59:16 PDT 2016
ok the error is that self.maintenance_frequency][0][1].title()is empty. Did
you correctly set it in base_resourcebase?
As a note base_resourcebase have to have the same id of the related
document_document item.
Hope this helps!
2016-05-06 10:40 GMT+02:00 Haertel, Michael (IITA) <M.Haertel at cgiar.org>:
> Hello Simone,
> Thank you for attending to this so promptly.
> This is what is added to the error.log at the time I click on a link:
> [Fri May 06 03:38:41.634679 2016] [:error] [pid 2361] Internal Server
> Error: /documents/98
> [Fri May 06 03:38:41.634741 2016] [:error] [pid 2361] Traceback (most
> recent call last):
> [Fri May 06 03:38:41.634752 2016] [:error] [pid 2361] File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112,
> in get_response
> [Fri May 06 03:38:41.634764 2016] [:error] [pid 2361] response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Fri May 06 03:38:41.634772 2016] [:error] [pid 2361] File
> "/usr/local/lib/python2.7/dist-packages/geonode/documents/views.py", line
> 103, in document_detail
> [Fri May 06 03:38:41.634792 2016] [:error] [pid 2361]
> context_dict["social_links"] = build_social_links(request, document)
> [Fri May 06 03:38:41.634800 2016] [:error] [pid 2361] File
> "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line 609, in
> build_social_links
> [Fri May 06 03:38:41.634808 2016] [:error] [pid 2361] caveats =
> build_caveats(resourcebase)
> [Fri May 06 03:38:41.634816 2016] [:error] [pid 2361] File
> "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line 589, in
> build_caveats
> [Fri May 06 03:38:41.634824 2016] [:error] [pid 2361]
> caveats.append(resourcebase.maintenance_frequency_title())
> [Fri May 06 03:38:41.634831 2016] [:error] [pid 2361] File
> "/usr/local/lib/python2.7/dist-packages/geonode/base/models.py", line 613,
> in maintenance_frequency_title
> [Fri May 06 03:38:41.634839 2016] [:error] [pid 2361] return [v for i,
> v in enumerate(UPDATE_FREQUENCIES) if v[0] ==
> [Fri May 06 03:38:41.634859 2016] [:error] [pid 2361] IndexError: list
> index out of range
> [Fri May 06 03:38:41.656303 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] mod_wsgi (pid=2361): Exception occurred processing WSGI
> script '/var/www/geonode/wsgi/geonode.wsgi'.
> [Fri May 06 03:38:41.656511 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] Traceback (most recent call last):
> [Fri May 06 03:38:41.656645 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206,
> in __call__
> [Fri May 06 03:38:41.656779 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] response = self.get_response(request)
> [Fri May 06 03:38:41.656835 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194,
> in get_response
> [Fri May 06 03:38:41.656885 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] response = self.handle_uncaught_exception(request,
> resolver, sys.exc_info())
> [Fri May 06 03:38:41.656966 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236,
> in handle_uncaught_exception
> [Fri May 06 03:38:41.657032 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] return callback(request, **param_dict)
> [Fri May 06 03:38:41.657083 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in
> _wrapped_view
> [Fri May 06 03:38:41.657310 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] response = view_func(request, *args, **kwargs)
> [Fri May 06 03:38:41.657345 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 46, in
> server_error
> [Fri May 06 03:38:41.657404 2016] [:error] [pid 2361] [remote
> http.HttpResponseServerError(template.render(Context({})))
> [Fri May 06 03:38:41.657478 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in
> render
> [Fri May 06 03:38:41.657539 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] return self._render(context)
> [Fri May 06 03:38:41.657587 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in
> _render
> [Fri May 06 03:38:41.657625 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] return self.nodelist.render(context)
> [Fri May 06 03:38:41.657673 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in
> render
> [Fri May 06 03:38:41.657787 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] bit = self.render_node(node, context)
> [Fri May 06 03:38:41.657856 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in
> render_node
> [Fri May 06 03:38:41.657897 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] return node.render(context)
> [Fri May 06 03:38:41.657968 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 53,
> in render
> [Fri May 06 03:38:41.658012 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] result = self.nodelist.render(context)
> [Fri May 06 03:38:41.658061 2016] [:error] [pid 2361] [remote
> render
> [Fri May 06 03:38:41.658100 2016] [:error] [pid 2361] [remote
> [Fri May 06 03:38:41.658131 2016] [:error] [pid 2361] [remote
> render_node
> [Fri May 06 03:38:41.658171 2016] [:error] [pid 2361] [remote
> [Fri May 06 03:38:41.658242 2016] [:error] [pid 2361] [remote
> 155, in render
> [Fri May 06 03:38:41.658283 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] return self.render_template(self.template, context)
> [Fri May 06 03:38:41.658311 2016] [:error] [pid 2361] [remote
> 137, in render_template
> [Fri May 06 03:38:41.658347 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] output = template.render(context)
> [Fri May 06 03:38:41.658375 2016] [:error] [pid 2361] [remote
> render
> [Fri May 06 03:38:41.658410 2016] [:error] [pid 2361] [remote
> [Fri May 06 03:38:41.658438 2016] [:error] [pid 2361] [remote
> _render
> [Fri May 06 03:38:41.658474 2016] [:error] [pid 2361] [remote
> [Fri May 06 03:38:41.658502 2016] [:error] [pid 2361] [remote
> render
> [Fri May 06 03:38:41.658537 2016] [:error] [pid 2361] [remote
> [Fri May 06 03:38:41.658563 2016] [:error] [pid 2361] [remote
> render_node
> [Fri May 06 03:38:41.658598 2016] [:error] [pid 2361] [remote
> [Fri May 06 03:38:41.658625 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py",
> line 24, in render
> [Fri May 06 03:38:41.658662 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] request = context["request"]
> [Fri May 06 03:38:41.658890 2016] [:error] [pid 2361] [remote
> "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
> __getitem__
> [Fri May 06 03:38:41.658940 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] raise KeyError(key)
> [Fri May 06 03:38:41.659002 2016] [:error] [pid 2361] [remote
> 127.0.0.1:20011] KeyError: 'request'
> Regards,
> *Michael Haertel*
> *GIS & Database Expert*
> *International Institute of Tropical Agriculture (IITA, **www.iita.org*
> <http://../../../AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/FGKNP1ID/www.iita.org>
> Headquarters and West Africa Hub
> PMB 5320, Oyo Road, Ibadan 200001, Oyo State, Nigeria
> International Mailing Address: IITA Limited, Part 7th Floor, Grosvenor
> House, 125 High Street, Croydon, Surrey, CR0 9XP
> Tel: +234 2 7517472 | USA Tel: +1 201 6336094 | Fax: +44 208 7113786
> IITA is a member of the CGIAR Consortium (www.cgiar.org
> <http://../../../AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/AppData/Local/Microsoft/Windows/Temporary%20Internet%20Files/Content.Outlook/FGKNP1ID/www.cgiar.org>
> *From:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> *Sent:* Friday, May 06, 2016 9:36 AM
> *To:* Haertel, Michael (IITA)
> *Cc:* geonode-devel at lists.osgeo.org
> *Subject:* Re: [GeoNode-devel] after mass data import : "KeyError:
> Hi, could you post the full trace of the error? is in
> /var/logs/apache2/error.log
> 2016-05-06 10:22 GMT+02:00 Haertel, Michael (IITA) <M.Haertel at cgiar.org>:
> Dear List,
> I imported many datasets from a third party application into GeoNode by
> populating these database tables:
> 1. Base_resourcebase
> 2. Documents_document
> 3. Base_contactrole
> 4. Taggit_tag
> 5. Taggit_taggeditem
> 6. Base_link
> However the link behind each document doesn’t work. I get an “Internal
> server error”. According to the log file the error is raised in
> File "/usr/lib/python2.7/dist-packages/django/template/context.py", line
> 56, in __getitem__
> Raise KeyError(key)
> KeyError: ‘request’
> I noticed that when I click on a link to a PDF document for the first time
> after it has been imported, the column “doc_file” is altered and a suffix
> is appended to the pdf file on disk. So I also checked file permissions but
> “www-data” (linux) can write all files there. It only happens for the
> datasets that I imported myself. Manually added documents work fine.
> I also noticed that for Ids that were manually added and removed
> afterwards, the links (url: documents/<id>) still work and lead to a “file
> not found” page without any “internal server error” message. So GeoNode
> somehow knows which ids are valid (accessible) and which are not. Can
> somebody tell me how it works?
> I am not yet very good in python yet and I don’t want to debug the code at
> this point.
> Thank you very much for your assistance,
> *Michael Haertel*
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160506/bab0dca4/attachment-0001.html>
More information about the geonode-devel
