[GeoNode-devel] QueryBuilder for Download Layer functionality
Eugenio Trumpy
frippe12573 at hotmail.com
Tue May 24 01:33:38 PDT 2016
Ho Dimitris and all,
the tool you developed it' really fantastic as well as useful from my point of view.
Your work made me think about a possible tool: it could be nice to have a query builder for the layer to insert in the map composer, just a sort of a layer pre-filter. Moreover I wonder even if having a combo box, including possible values, in the query builder is easy to implement.
This my 2 cents.
Best
Eugenio
Date: Mon, 23 May 2016 17:14:49 +0200
To: pjdufour.dev at gmail.com
Subject: Re: [GeoNode-devel] QueryBuilder for Download Layer functionality
CC: geonode-devel at lists.osgeo.org
Hi guys,
I have deployed the newly developed 'Query Builder and Map Filter' tool in our staging server for WFP Geonode: http://staging.geonode.wfp.org/layers/ There are still several features to be added but you can have a look and give some recommendations, improvement ideas etc.To use the tool, select a layer, click the Download button and then the Layer Filtering.
CheersDimitris
On Mon, May 16, 2016 at 9:09 PM, Patrick Dufour <pjdufour.dev at gmail.com> wrote:
Yes, I can help with the GNIP when ready.
The implementation will leverage the cql_filter GeoServer WFS querystring parameter, as such no changes to GeoServer or django DB models are needed.
Regards,
Patrick Dufour
On May 16, 2016 6:11 PM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
This is really awesome!
Can you file a GNIP for this so we can discuss the implementation as a
group? If you need help with that, let us know. You will need a core
committer to actually file the GNIP. Perhaps Patrick can help?
Looking forward to seeing/using this!
Jeff
On Mon, May 16, 2016 at 2:34 AM, Dimitris Karakostis
<karakostis.dimitris at gmail.com> wrote:
> Hello guys,
> How are you doing? I wanted to share with you our current development
> plans/progress for WFPGeonode. During the last week I have been working on
> the implementation of a 'Query Builder' functionality in order to be able to
> download specific parts of layers in the provided formats (kml, xls, csv,
> zipped shape, geojson).
> The user can build the query by :
> 1. selecting from a dropdown menu the available attributes,
> 2. selecting an operator,
> 3. enter a valid value
> The different statements of the query can be combined either with AND or OR
> operator. I have also used the OWSLib (0.11.0; thanks Tom) in order to get
> the type of attributes and apply some sort of validation (e.g. if you try to
> put a string, while number is expected then you get an error message).
> For the above process I have used JQuery for the JS functionality and
> BootstrapCSS for the gui. The tool is part of the 'Download Layer' modal and
> is currently being tested and making small fixes.
> The next step will be to build a map tool, which you will select the area of
> interest (rectangle tool; bounding box etc.) and download it.
> I attach some screenshots of the two tools. If you have any
> ideas/advice/comments please let me know. They are most welcome!
> Cheers
> Dimitris
> geonode-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160524/37fac830/attachment.html>
More information about the geonode-devel
