[GeoNode-devel] GeoServer version 2.8.x+ ?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue May 31 01:08:37 PDT 2016
Dear all,
while the Backup & Restore stuff for GeoServer is moving towards the end of
development
(https://github.com/geosolutions-it/geoserver/tree/backup_restore)
I would like to propose here an update of the GeoServer version on GeoNode
master branch too.
GeoServer is currently at version 2.10 while GeoNode is still using the old
2.7 one.
Consider also that in few days we plan to start working on an heavy
refactoring of the Authorization & Authentication subsystem of
GeoNode/GeoServer.
The new GeoServer versions not only have a lot of new features but also
bug-fixes, performance improvements and some heavy refactoring of the code
base which allows GeoServer to work much better and be quite versatile.
I guess we should start thinking to move at least at version 2.8.x of
GeoServer if not a newest one.
I volunteer to update the security plugins if the community agrees on the
version update.
Please let me know what are your thoughts about this topic.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160531/579d7b2e/attachment.html>
More information about the geonode-devel
