[GeoNode-devel] [GeoNode-users] Changes to local_settings.py ignored [Windows, Apache]
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Nov 2 03:33:43 PDT 2016
Hello Nicolai,
I'm going to maintain the discussion on the mailing list so that it can be
useful for other users too in the future.
The problem should be related only to the maps. I'm currently not aware of
a quick command to do this. At this point you have two options:
1. Delete only the old maps and rebuild them from scratch.
2. Manually update the GeoServer ip address on the database -> main geonode
database, table "maps_maplayer"
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Wed, Nov 2, 2016 at 10:15 AM, Nicolai Cryer <nkcryer at gmail.com> wrote:
> Dear Alessio,
> Thank you so much for your reply, this is really driving me nuts :)
> I just tested it out, and you were spot on - it's only the old maps that
> have this issue. New maps created after changing the URL work perfectly.
> THANK YOU!!! This is such a relief.
> Do you know if there's any way to update the configuration in the
> database? Or should I re-upload all the data?
> 2016-11-02 9:41 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> Dear Nicolai,
>> is the problem related to the new layers also or just the old ones? Can
>> you please describe exactly your test-case?
>> The thing is... if you are trying to expose your saved maps, consider
>> that the configuration is stored on the database. Therefore if you created
>> those maps with the old ip most probably the configuration still has the
>> latter recored on the DB.
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, Nov 1, 2016 at 3:29 PM, Nicolai Cryer <nkcryer at gmail.com> wrote:
>>> Hi,
>>> We're trying to open our Geonode installation to the public, and have
>>> done the necessary DNS stuff. As such, our Geonode is able to serve static
>>> files (html etc.) to outside the internal network, but the url for WMS
>>> services etc. still seems to be configured to the localhost.
>>> As such, users can view the Geonode front-end but cannot be served
>>> WMS/WFS content from our geoserver (these show up as bad tiles in
>>> geoexplorer).
>>> I tried to solve this by editing local_settings.py in
>>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode, specifically the
>>> "PUBLIC_LOCATION" key in the OGC dictionary.
>>> The big problem is that no matter what I change in settings.py or
>>> local_settings.py, how many times I restart Apache/Tomcat/the whole server,
>>> delete .pyc files to be regenerated etc., the changes are never reflected
>>> in the actual OGC configuration. I don't understand where the problem lies!
>>> I've even attempted to delete settings.py without incident, so it's like
>>> the files are cached somewhere (perhaps in the bowels of Apache?)
>>> I would be most grateful for any ideas, because I've almost exhausted
>>> the list of buttons to push :/
>>> Best,
>>> Nicolai
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161102/4e8704e5/attachment.html>
More information about the geonode-devel
