[GeoNode-devel] Geonode 2.4 on Ubuntu 16.04 - unmet dependencies
Jeffrey Johnson
ortelius at gmail.com
Fri Nov 11 03:54:51 PST 2016
+1 I can help when I'm back from holidays.
On Friday, November 11, 2016, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Thanks Jonathan,
> we have a role for Ubuntu 14.04 https://github.com/GeoNode/ansible-geonode,
> I think it would be good to have a branch for 16 too. Right @jj0hns0n?
> 2016-11-10 23:51 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au
> <javascript:_e(%7B%7D,'cvml','j.doig at unsw.edu.au');>>:
>> Thanks Simone
>> I followed those instructions – with a few changes – and managed to get
>> Geonode 2.4 installed on Ubuntu 16.04, thanks.
>> I’ve created Ansible playbooks for the whole thing, may be able to share
>> these if helpful. They’re pretty basic, no error-checking, but they work
>> for me.
>> Jonathan
>> *From:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com
>> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>]
>> *Sent:* Thursday, 3 November 2016 5:33 PM
>> *To:* Jonathan Doig
>> *Cc:* geonode-devel at lists.osgeo.org
>> <javascript:_e(%7B%7D,'cvml','geonode-devel at lists.osgeo.org');>
>> *Subject:* Re: [GeoNode-devel] Geonode 2.4 on Ubuntu 16.04 - unmet
>> dependencies
>> Hi,
>> not sure that's the issue because the only place geonode 2.5 is available
>> is in the testing ppa moreover the error is that geonode depends on django
>> <=1.7 but the 1.8 is to be installed and I think is because the 1.6 might
>> not be available for xenial https://launchpad.net/u
>> buntu/+source/python-django.
>> I would suggest you to go for the manual installation under a virtualenv,
>> the doc is for the 2.4 but the process is very similar
>> http://docs.geonode.org/en/master/tutorials/install_
>> and_admin/geonode_install/index.html
>> hope this helps
>> 2016-11-03 0:01 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au
>> Hi devs
>> No reply on geonode-users, so I’m trying here.
>> Thanks
>> Jonathan
>> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org
>> <javascript:_e(%7B%7D,'cvml','geonode-users-bounces at lists.osgeo.org');>] *On
>> Behalf Of *Jonathan Doig
>> *Sent:* Wednesday, 2 November 2016 5:05 PM
>> *To:* geonode-users at lists.osgeo.org
>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>> *Subject:* [GeoNode-users] Geonode 2.4 on Ubuntu 16.04
>> Hi
>> I’m trying to install Geonode 2.4 on Ubuntu 16.04, being new to both.
>> I’m stepping through the OSGeoLive install_geonode.sh script following
>> this advice from Angelos Tzotsos on Aug 18:
>> Ø GeoNode 2.4 works fine on Xenial.
>> Ø The Debian packaging has been updated accordingly.
>> Ø Please check the OSGeoLive install script to find out how to install:
>> Ø https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonode.sh
>> However line 50:
>> apt-get --assume-yes install python-geonode libapache2-mod-wsgi curl
>> Is giving trouble:
>> The following packages have unmet dependencies:
>> python-geonode : Depends: python-django (<= 1.7) but 1.8.7-1ubuntu5.2 is
>> to be installed
>> Recommends: transifex-client but it is not going to be
>> installed
>> E: Unable to correct problems, you have held broken packages.
>> I think it’s because python-geonode is v2.5.5 which uses django 1.8,
>> where I want v2.4 which needs django 1.6.
>> I tried specifying a geonode version: --target_release ‘2.4*’ or /release
>> or /stable but nothing was found.
>> Advice please.
>> Thanks
>> *Jonathan Doig*
>> *Software Engineer – Spatial Systems*
>> *City Futures Research Centre*
>> *UNSW Built Environment *
>> cityfutures.net.au <http://cityfutures.be.unsw.edu.au/>
>> geonode-devel mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20161111/14f29018/attachment.html>
More information about the geonode-devel
