[GeoNode-devel] Docker for development
Francesco Bartoli xbartolone at gmail.com
Tue Sep 6 10:48:07 PDT 2016
Actually I realized that SITE_URL and GEOSERVER_PUBLIC_LOCATION are not properly set at the moment. I’m going to prepare a fix for this.
I did not get through best practices to manage geonode-project but I’m feeling that Ariel could help. Tomorrow is good for me.
Il giorno 06/set/2016, alle ore 18:45, Jeffrey Johnson <ortelius at gmail.com> ha scritto:
> Merged. Im going to do some more testing this week.
> I'd like some guidance on the best way to setup a downstream project
> using these docker configs. I setup my 'eventkit' project last week
> with a little help from Ariel.
> https://github.com/terranodo/eventkit/tree/docker ... Note the dual
> database setup (which should be using a volume.
> Perhaps we should schedule a time to chat about these things in gitter?
> On Mon, Sep 5, 2016 at 1:16 AM, Francesco Bartoli <xbartolone at gmail.com> wrote:
>> Hi team,
>> I would like to share latest work on docker:
>> - with this PR https://github.com/GeoNode/docker-geoserver/pull/5 we are now
>> able to automatically set the baseUrl in the configuration (config.xml) from
>> the geonodeAuthProvider of GeoServer. This means if you are in a docker
>> shell you should have automatically an environment variable DOCKER_HOST with
>> a value like this “tcp://192.168.99.100:2376” where the ip address is
>> normally the same of the output from “docker-machine ip”. The baseUrl will
>> be configured with a value like this “http://192.168.99.100:80/“ that is the
>> url you are going to open up in the browser for accessing geonode so you
>> should be able then to being automatically logged in geoserver too.
>> - this commit
>> https://github.com/GeoNode/geonode/commit/6b24bf9f46bb3cd46696a36e13d4f46faa35fe16
>> brings the required variable in the compose of geonode
>> - after running “make up” and “make sync” we should be in the same situation
>> of what paver was doing for development till now
>> The next improvement I’d like to have would be to giving the priority to two
>> new variables NGINX_HOST and NGINX_PORT for the baseUrl from the nginx
>> service in the docker-compose file. I’m happy if somebody can merge the PR
>> and provide any feedback/thought about this.
>> Thanks,
>> Francesco
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
