[GeoNode-devel] Why "initial_data" has been removed?
Ariel Nunez
ingenieroariel at gmail.com
Thu Sep 22 07:26:13 PDT 2016
I can take care of creating a PR to fix this.
That initial data was very troublesome for migrations on downstream
projects. Loading things by default at the wrong time was causing circular
dependencies trouble in Django 1.8
I'll create a PR this weekend.
-a
On Sep 22, 2016 9:02 AM, "Daniel Berry" <dberry at boundlessgeo.com> wrote:
> We could always rename that to a different name other than initial_data
> and reference that in the migration.
> On Thu, Sep 22, 2016 at 8:30 AM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> When implementing migrations we must also refactor the topiccategories
>> script.
>> Right now it tries to read and update data from initial_data json file
>> https://github.com/GeoNode/geonode/pull/2496/files#diff-dabb
>> 72a704294b551bf78964ac5cb36fR45
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts!
>> Visit http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Thu, Sep 22, 2016 at 3:26 PM, Daniel Berry <dberry at boundlessgeo.com>
>> wrote:
>>> The use of fixtures has been deprecated and now should be using
>>> migrations. I know Ariel has a WIP pull request for this, but since it is
>>> not complete it may be wise to add back the initial_data.json.
>>> Dan
>>> On Thu, Sep 22, 2016 at 8:15 AM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Dear all,
>>>> I noticed that on a fresh geonode installation the old fixture
>>>> "initial_data" has been replaced by a new one "sample_admin".
>>>> sample_admin creates a superuser, which is good, but on the other side
>>>> does not populate GeoNode model with initial required data, like regions
>>>> and topiccategories.
>>>> Is there a reason for this choice?
>>>> I guess we should have back the initial_data, otherwise new
>>>> installation of master branch won't be able to consistently update Layers
>>>> metadata.
>>>> We may envisage a merge of the initial fixtures, sample_admin and
>>>> initial_data.
>>>> Notice that right now if you try to import both of them the GeoNode
>>>> fails to start due to a missing profile for admin.
>>>> Opinions?
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> *Daniel Berry*
>>> Senior Software Engineer | Boundless
>>> 512-468-3946 (cell)
>>> @boundlessgeo
> *Daniel Berry*
> 512-468-3946 (cell)
> @boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160922/13cc3662/attachment-0001.html>
More information about the geonode-devel
