[GeoNode-devel] Issue building GeoServer-GeoNode-ext due to missing geogig artifacts
Jeffrey Johnson ortelius at gmail.com
Mon Jan 9 06:33:04 PST 2017
Is it possible for us just go get rid of this GeoGit dependency by
default since it continues to cause so many problems. Perhaps we can
make a separate build that includes it, or let the folks that do use
it help maintain it. Its getting a bit frustrating to deal with this
every time we have to do a new build.
On Mon, Jan 9, 2017 at 3:31 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Hi guys,
> can someone help with this issue?
> [INFO]
> [INFO] BUILD FAILURE
> [INFO]
> [INFO] Total time: 54.889 s
> [INFO] Finished at: 2017-01-09T11:45:35+00:00
> [INFO] Final Memory: 28M/67M
> [INFO]
> [ERROR] Failed to execute goal on project geonode-geoserver-ext: Could not
> resolve dependencies for project
> org.opengeo:geonode-geoserver-ext:jar:2.9-SNAPSHOT: The following artifacts
> could not be resolved: org.locationtech.geogig:geogig-cli:jar:1.1-SNAPSHOT,
> org.locationtech.geogig:geogig-geotools:jar:1.1-SNAPSHOT,
> org.locationtech.geogig:geogig-datastore:jar:1.1-SNAPSHOT,
> org.locationtech.geogig:geogig-web-api:jar:1.1-SNAPSHOT,
> org.locationtech.geogig:geogig-postgres:jar:1.1-SNAPSHOT: Could not find
> artifact org.locationtech.geogig:geogig-cli:jar:1.1-SNAPSHOT in geosolutions
> (http://maven.geo-solutions.it/) -> [Help 1]
> [ERROR]
> [ERROR] To see the full stack trace of the errors, re-run Maven with the -e
> switch.
> [ERROR] Re-run Maven using the -X switch to enable full debug logging.
> [ERROR]
> [ERROR] For more information about the errors and possible solutions, please
> read the following articles:
> [ERROR] [Help 1]
> http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
> [JENKINS] Archiving
> /disk/jenkins/workspace/geoserver-geonode-dev-oauth2/pom.xml to
> org.opengeo/geonode-geoserver-ext/2.9-SNAPSHOT/geonode-geoserver-ext-2.9-SNAPSHOT.pom
> channel stopped
> Finished: FAILURE
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
