[GeoNode-users] Associate information to shapefiles/raster uploaded
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Apr 15 13:58:54 PDT 2015
Sure you can, the better is if you can extend it through the geonode
project without modify the geonode core. Take a look at the base app and
it's files, the metadata form and model is in there. Otherwise you can fork
geonode and edit.
Il mercoledì 15 aprile 2015, Melvin Ramos <melvin.ramos1991 at gmail.com> ha
scritto:
> Alright, I'll look into it. One more question I just came up with: is
> there a way to modify the metadata form? It might be the way to achieve
> what I want.
> Enviado con MailTrack
> <https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
> 2015-04-15 15:47 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com
> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>>:
>> hm not sure if I got what you need, generally those informations are the
>> layers themselves and since geonode loads them in the db then you can do
>> queries there. Anyway take a look at this
>> https://github.com/GeoNode/geonode-project is the common way we use to
>> extend geonode and develop custom apps. If you use geonode 2.4 then use the
>> 2.4 branch of the project.
>> 2015-04-15 21:43 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com
>> <javascript:_e(%7B%7D,'cvml','melvin.ramos1991 at gmail.com');>>:
>>> Thanks for the reply Simone.
>>> It's no use to me to upload a file with information. The idea is to
>>> store that information in the database because I have to make queries over
>>> them. The main idea is to "ask" the system something like: show me all the
>>> geographic layers where there are forests or desserts or whatever
>>> classification I want, or which ecosystems are in danger in Europe alone,
>>> or which ecosystems have endangered species or even something more complex
>>> like which ecosystems are threatened by processes like polution or
>>> salinization.
>>> In order to do this, I need to create models that contain the fields
>>> which I can use to store the information I need so them I can query them to
>>> show results in the map view. I could create an app with geonode but I'm
>>> not clear how to associate that with a layer (therefore the only map I will
>>> have that is the entire world). Or is there a more straight way like adding
>>> the models.py inside geonode.
>>> 2015-04-15 12:49 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com
>>> Melvin take a look at the Document section of GeoNode. There you can
>>>> upload non spatial data and link them to layers or maps.
>>>> 2015-04-15 17:20 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com
>>>>> Greetings,
>>>>> I'm trying to associate specific information to the files I upload (be
>>>>> that vector or raster) besides the metadata. I'm supposed to implement a
>>>>> database with a whole of information (text and numbers related to
>>>>> statistics and NGO standards), but I have no idea where or how to begin to
>>>>> customize my project: create models, create the forms, query the data
>>>>> (especially from the map view itself), etc.
>>>>> I understand that when I upload a file I create a new layer and that I
>>>>> can add a predetermined info called metadata, and also each file has
>>>>> attributes (which I guess they come from the file itself), but I need more:
>>>>> I need a form that people can fill (from custom models) where people can
>>>>> write the extra info that is required.
>>>>> Can anyone help me on this matter? Thanks in advance,
>>>>> MR
>>>>> Melvin David Ramos Macías
>>>>> 07-41408
>>>>> Ingeniería de Computación
>>>>> Universidad Simón Bolívar
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Simone
>>> 07-41408
>> Simone
> 07-41408
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150415/3f72e198/attachment.html>
More information about the geonode-users
