[GeoNode-users] error on admin interface "Select resource base to change" geonode version 2.4.dev20150415201451 (master)
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Apr 16 00:48:23 PDT 2015
Hi Jesus, yes it is a small bug that we'll fix soon. Thanks for reporting.
Anyway ResourceBase should not be used from the admin and we should remove
it from there. It's children are the ones to use (layers, maps, documents
and services)
Ciao
2015-04-15 22:02 GMT+02:00 Jesus <gesusjl at gmail.com>:
> Hi all,
> Pastebin is down (see below).. I'm having a TypeError when clicking over
> a ID link in admin interface on section Resource bases
> Any suggestion? Could be a bug? Something related with the template
> rendering.
> Thank you
> Jesús
> TypeError at /admin/base/resourcebase/1/
> int() argument must be a string or a number, not 'QuerySet'
> Request Method: GET Request URL:
> http://192.168.50.4/admin/base/resourcebase/1/ Django Version: 1.6.10 Exception
> Type: TypeError Exception Value:
> Exception Location: /home/vagrant/.venvs/geonode/lib/python2.7/site-packages/django/db/models/fields/__init__.py
> in get_prep_value, line 613 Python Executable: /usr/bin/python Python
> Version: 2.7.3 Python Path:
> ['/home/vagrant/geonode',
> '/home/vagrant/cdfgeonode',
> '/home/vagrant/.venvs/geonode/lib/python2.7/site-packages',
> '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/var/www']
> Server time: Wed, 15 Apr 2015 14:53:34 -0500
> Error during template rendering
> In template
> /home/vagrant/.venvs/geonode/lib/python2.7/site-packages/django/contrib/admin/templates/admin/includes/fieldset.html,
> error at line *19*
> int() argument must be a string or a number, not 'QuerySet' 9 {% for
> field in line %} 10 <div{% if not line.fields|length_is:'1' %}
> class="field-box{% if field.field.name %} field-{{ field.field.name }}{%
> endif %}{% if not field.is_readonly and field.errors %} errors{% endif
> %}"{% elif field.is_checkbox %} class="checkbox-row"{% endif %}> 11 {%
> if not line.fields|length_is:'1' and not field.is_readonly %}{{
> field.errors }}{% endif %} 12 {% if field.is_checkbox %} 13 {{
> field.field }}{{ field.label_tag }} 14 {% else %} 15 {{ field.label_tag
> }} 16 {% if field.is_readonly %} 17 <p>{{ field.contents|linebreaksbr
> }}</p> 18 {% else %} 19 {{ field.field }} 20 {% endif %} 21 {% endif
> %} 22 {% if field.field.help_text %} 23 <p class="help">{{
> field.field.help_text|safe }}</p> 24 {% endif %} 25 </div> 26 {%
> endfor %} 27 </div> 28 {% endfor %} 29 </fieldset>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150416/efb41598/attachment-0001.html>
More information about the geonode-users
