[GeoNode-users] ubuntu 12.04 LTS error installation
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Apr 22 10:15:37 PDT 2015
Hi Vladimiro,
thanks for posting here.
is the ubuntu you are using a brand new system?
Are you aware that there is the geonode 2.4 beta available for ubuntu 14.04
which has many many improvements from the 2.0?
It's a beta but quite stable and we will not change its data model before
the official release so any update should be smooth.
To install it on 14.04 use ppa:geonode/testing instead of
ppa:geonode/release.
Regards
2015-04-22 19:09 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
> Hi,
> i was installing geonode using ubuntu 12.04.5 LTS
> I'm following this guide:
> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/quick_install.html#quick-installation
> i have dependecies issue right on start:
> root at ubuntu:/# cat /etc/issue
> Ubuntu 12.04.5 LTS \n \l
> root at ubuntu:/#
> root at ubuntu:/# sudo apt-get install python-software-properties
> Leyendo lista de paquetes... Hecho
> Creando árbol de dependencias
> Leyendo la información de estado... Hecho
> python-software-properties ya está en su versión más reciente.
> 0 actualizados, 0 se instalarán, 0 para eliminar y 3 no actualizados.
> root at ubuntu:/# sudo add-apt-repository ppa:geonode/release
> You are about to add the following PPA to your system:
> Ubuntu packages for GeoNode. More information at http://geonode.org
> More info: https://launchpad.net/~geonode/+archive/ubuntu/release
> Press [ENTER] to continue or ctrl-c to cancel adding it
> gpg: anillo «/tmp/tmpBi2FHa/secring.gpg» creado
> gpg: anillo «/tmp/tmpBi2FHa/pubring.gpg» creado
> gpg: solicitando clave 9FBF90A1 de hkp servidor keyserver.ubuntu.com
> gpg: /tmp/tmpBi2FHa/trustdb.gpg: se ha creado base de datos de confianza
> gpg: clave 9FBF90A1: clave pública "Launchpad PPA for geonode" importada
> gpg: Cantidad total procesada: 1
> gpg: importadas: 1 (RSA: 1)
> OK
> root at ubuntu:/#
> root at ubuntu:/# sudo apt-get update
> Obj http://ppa.launchpad.net precise Release.gpg
> Obj http://es.archive.ubuntu.com precise Release.gpg
> Des:1 http://es.archive.ubuntu.com precise-updates Release.gpg [198 B]
> Des:2 http://es.archive.ubuntu.com precise-updates Release [196 kB]
> Obj http://ppa.launchpad.net precise/main Sources
> Obj http://ppa.launchpad.net precise/main amd64 Packages
> Obj http://ppa.launchpad.net precise/main i386 Packages
> Obj http://ppa.launchpad.net precise/main TranslationIndex
> Obj http://ppa.launchpad.net precise/main Translation-en
> Obj http://es.archive.ubuntu.com precise/main Sources
> Obj http://es.archive.ubuntu.com precise/restricted Sources
> Obj http://es.archive.ubuntu.com precise/main amd64 Packages
> Obj http://es.archive.ubuntu.com precise/restricted amd64 Packages
> Obj http://es.archive.ubuntu.com precise/main i386 Packages
> Obj http://es.archive.ubuntu.com precise/restricted i386 Packages
> Obj http://es.archive.ubuntu.com precise/main TranslationIndex
> Obj http://es.archive.ubuntu.com precise/restricted TranslationIndex
> Des:3 http://es.archive.ubuntu.com precise-updates/main Sources [487 kB]
> Des:4 http://es.archive.ubuntu.com precise-updates/restricted Sources [7.981 B]
> Des:5 http://es.archive.ubuntu.com precise-updates/main amd64 Packages [888 kB]
> Des:6 http://es.archive.ubuntu.com precise-updates/restricted amd64 Packages [13,6 kB]
> Des:7 http://es.archive.ubuntu.com precise-updates/main i386 Packages [929 kB]
> Des:8 http://es.archive.ubuntu.com precise-updates/restricted i386 Packages [13,6 kB]
> Obj http://es.archive.ubuntu.com precise-updates/main TranslationIndex
> Obj http://es.archive.ubuntu.com precise-updates/restricted TranslationIndex
> Obj http://es.archive.ubuntu.com precise/main Translation-es
> Obj http://es.archive.ubuntu.com precise/main Translation-en
> Obj http://es.archive.ubuntu.com precise/restricted Translation-es
> Obj http://es.archive.ubuntu.com precise/restricted Translation-en
> Obj http://es.archive.ubuntu.com precise-updates/main Translation-es
> Obj http://es.archive.ubuntu.com precise-updates/main Translation-en
> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-es
> Obj http://es.archive.ubuntu.com precise-updates/restricted Translation-en
> Descargados 2.535 kB en 6seg. (395 kB/s)
> root at ubuntu:/#
> and now.. the error !
> root at ubuntu:/# sudo apt-get install geonode
> No se pudieron instalar algunos paquetes. Esto puede significar que
> usted pidió una situación imposible o, si está usando la distribución
> inestable, que algunos paquetes necesarios no han sido creados o han
> sido movidos fuera de Incoming.
> La siguiente información puede ayudar a resolver la situación:
> Los siguientes paquetes tienen dependencias incumplidas:
> geonode : Depende: geoserver-geonode pero no va a instalarse o
> geoserver pero no va a instalarse
> Depende: python-virtualenv pero no es instalable
> Depende: python-pyproj pero no es instalable
> Depende: python-shapely pero no es instalable
> Depende: gdal-bin pero no es instalable
> Depende: libgeos-dev pero no es instalable
> Depende: postgresql-9.1-postgis pero no es instalable o
> postgresql-8.4-postgis pero no es instalable
> Depende: python-gdal pero no es instalable
> Depende: libproj-dev pero no es instalable
> Depende: python-django-downloadview pero no va a instalarse
> Depende: python-django-extensions pero no va a instalarse
> Depende: python-django-user-accounts pero no va a instalarse
> Depende: python-pycsw pero no va a instalarse
> Depende: python-paver pero no va a instalarse
> Depende: python-pinax-theme-bootstrap-account pero no va a instalarse
> Depende: python-multipartposthandler pero no es instalable
> Recomienda: python-gisdata pero no va a instalarse
> Recomienda: transifex-client pero no es instalable
> E: No se pudieron corregir los problemas, usted ha retenido paquetes rotos.
> root at ubuntu:/#
> anyone know how this could be?
> thanks!
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150422/85b4a4f7/attachment-0001.html>
More information about the geonode-users
