[GeoNode-users] NameError: name 'PROJECT_ROOT' is not defined
Natalia Queiroz
queiroz.nati at gmail.com
Thu Aug 13 10:28:34 PDT 2015
Hello Group,
I'm working on a complete installation of Geonode and I'm stuck on the part
of *Synchronise db, *it says that there is no name 'PROJECT_ROOT' defined
Any Idea?
# python manage.py syncdb --noinput --all
File "manage.py", line 28, in <module>
execute_from_command_line(sys.argv)
File
"/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
line 399, in execute_from_command_line
utility.execute()
File
line 392, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File
line 261, in fetch_command
commands = get_commands()
File
line 107, in get_commands
apps = settings.INSTALLED_APPS
File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py",
line 54, in __getattr__
self._setup(name)
line 49, in _setup
self._wrapped = Settings(settings_module)
line 128, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py",
line 40, in import_module
__import__(name)
File "/home/ubuntu/geonode/geonode/settings.py", line 885, in <module>
from local_settings import * # noqa
File "/home/ubuntu/geonode/geonode/local_settings.py", line 39, in
<module>
'LOG_FILE': '%s/geoserver/data/logs/geoserver.log' %
os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
*NameError: name 'PROJECT_ROOT' is not defined*
local_settings.py file
import os
SITEURL = "http://localhost:8000/"
DATABASES = {
'default': {
'ENGINE': 'django.db.backends.postgresql_psycopg2',
'NAME': 'geonode',
'USER': 'geonode',
'PASSWORD': 'geonode',
# vector datastore for uploads
'datastore' : {
'ENGINE': 'django.contrib.gis.db.backends.postgis',
'ENGINE': '', # Empty ENGINE name disables
'NAME': 'geonode-imports',
'USER' : 'geonode',
'PASSWORD' : 'geonode',
'HOST' : 'localhost',
'PORT' : '5432',
# OGC (WMS/WFS/WCS) Server Settings
OGC_SERVER = {
'default' : {
'BACKEND' : 'geonode.geoserver',
'LOCATION' : 'http://localhost:8080/geoserver/',
'PUBLIC_LOCATION' : 'http://localhost:8080/geoserver/',
'USER' : 'admin',
'PASSWORD' : 'geoserver',
'MAPFISH_PRINT_ENABLED' : True,
'PRINT_NG_ENABLED' : True,
'GEONODE_SECURITY_ENABLED' : True,
'GEOGIG_ENABLED' : False,
'WMST_ENABLED' : False,
'BACKEND_WRITE_ENABLED': True,
'WPS_ENABLED' : False,
# Set to name of database in DATABASES dictionary to enable
'DATASTORE': '', #'datastore',
CATALOGUE = {
'default': {
# The underlying CSW implementation
# default is pycsw in local mode (tied directly to GeoNode Django
DB)
'ENGINE': 'geonode.catalogue.backends.pycsw_local',
# pycsw in non-local mode
# 'ENGINE': 'geonode.catalogue.backends.pycsw_http',
# GeoNetwork opensource
# 'ENGINE': 'geonode.catalogue.backends.geonetwork',
# deegree and others
# 'ENGINE': 'geonode.catalogue.backends.generic',
# The FULLY QUALIFIED base url to the CSW instance for this GeoNode
'URL': '%scatalogue/csw' % SITEURL,
# 'URL': 'http://localhost:8080/geonetwork/srv/en/csw',
# 'URL': 'http://localhost:8080/deegree-csw-demo-3.0.4/services',
# login credentials (for GeoNetwork)
'USER': 'admin',
'PASSWORD': 'admin',
# Default preview library
#LAYER_PREVIEW_LIBRARY = 'geoext'
ALLOWED_HOST = ['localhost']
Natália Oliveira
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150813/1792b674/attachment-0001.html>
More information about the geonode-users
