[GeoNode-users] [geonode] Errors were encountered while processing: geoserver-geonode geonode (#2371)
Simone Dalmasso simone.dalmasso at gmail.com
Tue Dec 1 10:20:40 PST 2015
Ah now I see.
The hardware is not enough for GeoNode, sorry.
For the next time just use the quick install as it is and it will go much
better.
2015-12-01 19:08 GMT+01:00 Jessel, Tanner Monroe <tjessel at utk.edu>:
> Hi Simone and Alessio,
> My mistake, I meant to write port 8000 earlier.
> http://54.152.180.217:8000/ <http://54.152.180.217:8080/>
> I'm guessing ERR_CONNECTION_REFUSED has something to do with a firewall
> setting?
> I set up a custom TCP rule for port 8000 to allow any IP to access;
> I'm unsure what else to try.
> To Simone's question about the actual hardware:
> I am using a virtual machine, Ubuntu Server 14.04 LTS (HVM)
> <https://aws.amazon.com/marketplace/pp/B00JV9TBA6/ref=mkt_wir_Ubuntu14>
> 64 bit.
> One virtual CPU.
> Volume size is 8GiB
> I have a T2.micro version <https://aws.amazon.com/ec2/instance-types/> I
> selected because it's eligible for a free 12 month trial.
> Amazon seems to suggest the virtual machines use "High Frequency Intel
> Xeon Processors with Turbo up to 3.3GHz"
> For details, I looked up CPU info in the command line using:
> less /proc/cpuinfo
> processor       : 0
> vendor_id       : GenuineIntel
> cpu family      : 6
> model           : 63
> model name      : Intel(R) Xeon(R) CPU E5-2676 v3 @ 2.40GHz
> stepping        : 2
> microcode       : 0x25
> cpu MHz         : 2394.514
> cache size      : 30720 KB
> physical id     : 0
> siblings        : 1
> core id         : 0
> cpu cores       : 1
> apicid          : 0
> initial apicid  : 0
> fpu             : yes
> fpu_exception   : yes
> cpuid level     : 13
> wp              : yes
> flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca
> cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx rdtscp lm
> constant_tsc rep_good nopl xtopology eagerfpu pni pclmulqdq ssse3 fma cx16
> pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx
> f16c rdrand hypervisor lahf_lm abm xsaveopt fsgsbase bmi1 avx2 smep bmi2
> erms invpcid
> bogomips        : 4789.02
> clflush size    : 64
> cache_alignment : 64
> address sizes   : 46 bits physical, 48 bits virtual
> power management:
> Thanks,
> Tanner
> *From:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Sent:* Tuesday, December 1, 2015 11:12 AM
> *To:* Alessio Fabiani
> *Cc:* Jessel, Tanner Monroe; geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] [geonode] Errors were encountered while
> In order to better understand why the apt package is giving you errors,
> could you tell us what kind of hardware your machine is running on? Maybe
> if it's not fast enough the geoserver takes too much to be configured.
> thanks
> 2015-12-01 17:03 GMT+01:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Hi,
>> GeoNode runs on port 8000 only GeoServer runs on port 8080.
>> So you should be able to access your GeoNode at
>> If you need to put everything under the same domain/port you need to
>> proxy the TCP endpoints using an http server like apache, ngnix, ...
>> Hope this helps,
>> -A.
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/NWWaa2 for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via Poggio alle Viti 1187
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, Dec 1, 2015 at 4:34 PM, Jessel, Tanner Monroe <tjessel at utk.edu>
>> wrote:
>>> Hi Alessio, thanks.
>>> No, I did not execute dependencies setup steps.
>>> I'm new to ubuntu and really just wanted to follow the "quick" install
>>> outlined here:
>>> http://geonode.org/blog/2015/11/19/geonode-2.4-released/
>>> I don't really understand what happened, but I did avoid the error I
>>> had by doing what you suggested.
>>> (If it's of interest / useful for documentation I'm sending the
>>> new CLI session text output)
>>> Now I have a new question:
>>> I can access geonode at
>>> http://localhost:8000/ <http://localhost:8080/geonode>
>>> I can access the geoserver associated with the geonode install online at
>>> http://54.152.180.217:8080/geoserver/web/
>>> But, I can't access the geonode at http://54.152.180.217:8080/
>>> I'm guessing I need to do some more manual configuration?
>>> I'm a bit terrified of messing something up, which is why I was hoping
>>> the "quick install" would work.
>>> Can you recommend a particular place in the instructions for a custom
>>> install that I should pick up at?
>>> I'm looking at this right now:
>>> http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#configure-using-the-ubuntu-config-file
>>> Thanks again, and looking forward to additional hints.
>>> -Tanner
>>> *From:* alessio.fabiani at gmail.com <alessio.fabiani at gmail.com> on behalf
>>> of Alessio Fabiani <alessio.fabiani at geo-solutions.it>
>>> *Sent:* Tuesday, December 1, 2015 5:05 AM
>>> *To:* Jessel, Tanner Monroe
>>> *Cc:* geonode-users at lists.osgeo.org
>>> Did you executed the dependencies setup steps?
>>> # change into the folder called geonde$ cd geonode
>>> # Installs django etc.$ sudo pip install -e .
>>> # Downloads geoserver.war$ sudo paver setup
>>> Enterprise Support and Development Services
>>> GeoSolutions offers enterprise support and development services tobuild
>>> enterprise-class Spatial Data Infrastructures (SDI) with Open Source
>>> components.
>>> Read more... <http://goo.gl/NWWaa2>
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> On Mon, Nov 30, 2015 at 2:36 PM, Jessel, Tanner Monroe <tjessel at utk.edu>
>>> wrote:
>>>> Good morning,
>>>> Thanks.
>>>> It's a new and fresh ubuntu;
>>>> I actually just set up a new one this morning and had the same problem.
>>>> I'm attaching the CLI session as text...
>>>> The errors are below:
>>>> Creating config file /etc/logrotate.d/tomcat7 with new version
>>>>  * Starting Tomcat servlet engine tomcat7
>>>>                   [ OK ]
>>>> Processing triggers for ureadahead (0.100.0-16) ...
>>>> Setting up geoserver-geonode (2.7.4-2) ...
>>>>  * Stopping Tomcat servlet engine tomcat7
>>>>                   [ OK ]
>>>>                   [fail]
>>>> dpkg: error processing package geoserver-geonode (--configure):
>>>>  subprocess installed post-installation script returned error exit
>>>> status 1
>>>> dpkg: dependency problems prevent configuration of geonode:
>>>>  geonode depends on geoserver-geonode | geoserver; however:
>>>>   Package geoserver-geonode is not configured yet.
>>>>   Package geoserver is not installed.
>>>> dpkg: error processing package geonode (--configure):
>>>>  dependency problems - leaving unconfigured
>>>> Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
>>>> No apport report written because the error message indicates its a
>>>> followup error from a previous failure.
>>>>           Processing triggers for ufw (0.34~rc-0ubuntu2) ...
>>>> Processing triggers for python-support (1.0.15) ...
>>>> Processing triggers for ca-certificates (20141019ubuntu0.14.04.1) ...
>>>> Updating certificates in /etc/ssl/certs... 0 added, 0 removed; done.
>>>> Running hooks in /etc/ca-certificates/update.d....
>>>> done.
>>>> done.
>>>>  geoserver-geonode
>>>>  geonode
>>>> E: Sub-process /usr/bin/dpkg returned an error code (1)
>>>> ubuntu at ip-172-31-59-87:~$
>>>> -Tanner
>>>> *From:* Simone Dalmasso <notifications at github.com>
>>>> *Sent:* Monday, November 30, 2015 4:23 AM
>>>> *To:* GeoNode/geonode
>>>> *Subject:* Re: [geonode] Errors were encountered while processing:
>>>> Hi GeoNode should install smoothly on ubuntu server 14.04. Is the same
>>>> Os we use for demo.geonode.org.
>>>> Did you install it on a new and fresh ubuntu?
>>>> ps, please use the mailing lists geonode-users at lists.osgeo.org rather
>>>> than tickets to ask for support
>>>> Reply to this email directly or view it on GitHub
>>>> <https://github.com/GeoNode/geonode/issues/2371#issuecomment-160568535>
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151201/a9475e12/attachment-0001.html>
More information about the geonode-users mailing list
