[GeoNode-users] error on saving maps, again!
Eugenio Trumpy frippe12573 at hotmail.com
Wed Dec 9 04:55:59 PST 2015
Hi Francesco and all,
I followed your link, and I tried to debug apache. However I'm not able to get the core file.
I think I did the correct procedure, I added the suggested packages, created the dir in /tmp,
added the line: CoreDumpDirectory /tmp/apache-coredumps in /etc/apache2/apache2.conf
retsarted the apache, without errors.
Then I tried to save map on geonode to get the seg-fault. On the error. log I got:
[Wed Dec 09 13:48:25.299288 2015] [core:notice] [pid 18000] AH00051: child pid 18004 exit signal Segmentation fault (11), possible coredump in /tmp/apache-coredumps
In the /tmp/apache-coredumps there is no files.
So I cannot go toward gdb debug.
I thought my problem was due to the dir owner, so I changed the grants to www-data for /tmp/apache-coredumps/ dir.
Am I missing something?
Can you help me?
E.
Subject: Re: [GeoNode-users] error on saving maps, again!
Date: Sun, 6 Dec 2015 16:33:10 +0100
CC: simone.dalmasso at gmail.com; geonode-users at lists.osgeo.org
To: frippe12573 at hotmail.com
Eugenio,
a possible way to investigate more your problem is to attach httpd child process to gdb, cause it’s not reproducible. Follow instructions in this blog [1] and then look at the next crash.
Francesco
[1] http://sysadmin.carlusgg.com/?p=197
Il giorno 06/dic/2015, alle ore 10:58, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
Hi Francesco,
I'm trying  to use geonode 2.4.dev20151203130956.
I tried to save both an empty map and one containing a wms from an external geoserver. Same error.
I also tried to upload a new layer for using it on a new map, but that geonode version misses the category choose, so I got error also on upload a shp file.
Any idea on the reason of my problem?
Eugenio
Date: Sat, 5 Dec 2015 18:03:21 +0100
Hi Eugenio,
what version are you running? Did your unsaved map contain remote any layer from remote service?
Francesco
Il giorno 04/dic/2015, alle ore 16:51, Eugenio Trumpy <frippe12573 at hotmail.com> ha scritto:
Dear Simone and all,
I'm very sad to announce you that I'm getting the same error I got 1 month ago.
I got an error on saving maps, and I retrieve the same error in apache error.log:
[Fri Dec 04 16:40:39.271057 2015] [core:notice] [pid 15782] AH00051: child pid 26334 exit signal Segmentation fault (11), possible coredump in /etc/apache2
same stuff on segmentation fault!
I can consider me very unlucky on this installation.
Actually It was 10 days up to yesterday that I did not use geonode, but I'm sure it was working fine.
Yesterday I had the problem raised on the geonode user mailing list, so today I decided to upgrade all geonode system.
The installation went fine, but I have the same problem on saving map.
I don't understand what happen.
I solved this problem upgrading the server from 12.04 up to 14.04 version. This task was a bit time spending but all the applications
as well as geonode then worked fine.
In the meanwhile no important activities I performed on the server, only a few OS update.
Can you help me again?
Eugenio
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151209/000bde9f/attachment.html>
More information about the geonode-users mailing list
