[GeoNode-users] Cannot load geonode page: DoesNotExist: Site matching query does not exist. IntegrityError: Problem installing fixture
Shah Md. Rajibul Islam
rajibul.islam at cdmp.org.bd
Sat Dec 12 21:29:26 PST 2015
I am using geonode 2.0 on Ubuntu 12.04
I am having a problem while loading the geonode site as follows-
"There was a problem loading this page. Please contact your GeoNode
administrator (he may have received an email automatically if he configured
it properly). If you are the site administrator, enable debug mode to see
the actual error and fix it or file an issue in GeoNode's issue tracker"
It probably happened when I deleted the IP address from geoserver site
management and add a site name geonode.dmic.org.bd. However, I have added
the IP again to the site.
I tried to update the IP again using sudo geonode-updateip 203.83.183.18 and
gives following error:
When I run the sudo apt-get install --reinstall geonode command it gives
following error message:
'/usr/local/lib/python2.7/dist-packag
es/geonode/layers/fixtures/initial_data.json': Could not load
security.GenericOb
jectRoleMapping(pk=3): duplicate key value violates unique constraint
"security_
genericobjectrolemap_subject_object_ct_id_object_i_key"
DETAIL: Key (subject, object_ct_id, object_id, role_id)=(anonymous, 42, 1,
4) already exists.
Is there any suggestions please?
Best regards
Rajib
GIS Analyst
CDMP - II, UNDP
Disaster Management & Relief Bhaban
92-93, Mohakhali C/A, Dhaka - 1212
Tel # 989 0937; 882 1255; 882 1459, Ext - 303
Mobile: +88 01716 027389, E-mail: <mailto:rajibul.islam at cdmp.org.bd>
Web: <http://www.cdmp.org.bd/> www.cdmp.org.bd
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151213/53344200/attachment.html>
More information about the geonode-users
