[GeoNode-users] Cannot load geonode page: DoesNotExist: Site matching query does not exist. IntegrityError: Problem installing fixture
Shah Md. Rajibul Islam
rajibul.islam at cdmp.org.bd
Tue Dec 22 10:45:23 PST 2015
Dear Paolo,
Thank you for your reply. I am not good in psql and related coding as well
and have very limited programming knowledge. It would be very helpful for
me if you could also tell me the steps and codes that I have follow to do
this.
Best regards
Rajib
On Tue, Dec 22, 2015 at 11:43 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Then do a ssh connection to the server, and use psql in place of pgadmin
> regards
> p
> On Tue, Dec 22, 2015 at 3:55 AM, Shah Md. Rajibul Islam
> <rajibul.islam at cdmp.org.bd> wrote:
> > Dear Ariel,
> > Thank you for your reply and I am really sorry for late reply.
> > Is there other way to do the required task you mentioned? It would be
> better
> > if I can do this using ssh client putty.
> > Looking forward to your reply.
> > Best regards
> > Rajib
> > Sent from Samsung Mobile
> > -------- Original message --------
> > From: Ariel Nunez <ingenieroariel at gmail.com>
> > Date: 12/14/2015 8:06 PM (GMT+06:00)
> > To: "Shah Md. Rajibul Islam" <rajibul.islam at cdmp.org.bd>
> > Cc: geonode-users at lists.osgeo.org
> > Subject: Re: [GeoNode-users] Cannot load geonode page: DoesNotExist: Site
> > Hello Rajib,
> > Since you deleted the default Site (with id=1) instead of editing the
> site
> > name and url this caused problems with the permissions and all around the
> > site.
> > Your best bet is to create a new Site object with id =1 and the right
> name
> > and dome. Are you familiar with pgadminIII ? You can use that to connect
> to
> > your database and recreate the missing entry in sites_site graphically.
> > -a
> > On Sun, Dec 13, 2015 at 12:29 AM, Shah Md. Rajibul Islam
> >> Hi,
> >> I am using geonode 2.0 on Ubuntu 12.04
> >> I am having a problem while loading the geonode site as follows-
> >> “There was a problem loading this page. Please contact your GeoNode
> >> administrator (he may have received an email automatically if he
> configured
> >> it properly). If you are the site administrator, enable debug mode to
> see
> >> the actual error and fix it or file an issue in GeoNode's issue tracker”
> >> It probably happened when I deleted the IP address from geoserver site
> >> management and add a site name geonode.dmic.org.bd. However, I have
> added
> >> the IP again to the site.
> >> I tried to update the IP again using sudo geonode-updateip
> 203.83.183.18
> >> and gives following error:
> >> When I run the sudo apt-get install --reinstall geonode command it gives
> >> following error message:
> >> '/usr/local/lib/python2.7/dist-packag
> >> es/geonode/layers/fixtures/initial_data.json': Could not load
> >> security.GenericOb
> >> jectRoleMapping(pk=3): duplicate key value violates unique constraint
> >> "security_
> >> genericobjectrolemap_subject_object_ct_id_object_i_key"
> >> DETAIL: Key (subject, object_ct_id, object_id, role_id)=(anonymous, 42,
> >> 1, 4) already exists.
> >> Is there any suggestions please?
> >> Best regards
> >> Rajib
> >> GIS Analyst
> >> CDMP – II, UNDP
> >> Disaster Management & Relief Bhaban
> >> 92-93, Mohakhali C/A, Dhaka - 1212
> >> Tel # 989 0937; 882 1255; 882 1459, Ext - 303
> >> Mobile: +88 01716 027389, E-mail: rajibul.islam at cdmp.org.bd
> >> Web: www.cdmp.org.bd
> >> _______________________________________________
> >> geonode-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
*Shah Md. Rajibul Islam*
*GIS Analyst*CDMP – II, UNDP
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151223/6b6028d0/attachment-0001.html>
More information about the geonode-users
