[GeoNode-users] HTTP Status 404 for GeoServer when trying to install 2.4b25
Tukang Sampah
tkgsmph at gmail.com
Thu Jul 9 02:03:00 PDT 2015
Hi all,
I'm trying to install GeoNode 2.4b25 from source. But getting the following
error when opening http://mydomain:8080/geoserver:
HTTP Status 404 - /geoserver
type Status report
message /geoserver
description The requested resource is not available.
Apache Tomcat/7.0.52 (Ubuntu)
I used the same steps when installing 2.4b22. Here is the output when
running "sudo paver start":
user at ubuntu:/var/www/geonode$ sudo paver start
---> pavement.start
---> pavement.start_geoserver
cd /var/www/geonode/geoserver/data
java -version
java version "1.6.0_35"
OpenJDK Runtime Environment (IcedTea6 1.13.7) (6b35-1.13.7-1ubuntu0.14.04.1)
OpenJDK 64-Bit Server VM (build 23.25-b01, mixed mode)
java -Xmx512m -XX:MaxPermSize=256m
-DGEOSERVER_DATA_DIR=/var/www/geonode/geoserver/data
-Dorg.eclipse.jetty.server.webapp.parentLoaderPriority=true -jar
/var/www/geonode/downloaded/jetty-runner-8.1.8.v20121106.jar --log
/var/www/geonode/geoserver/jetty.log
/var/www/geonode/scripts/misc/jetty-runner.xml > /dev/null &
cd /var/www/geonode
Starting GeoServer on http://localhost:8080/geoserver/
2015-07-09 15:50:11.280:INFO:omjr.Runner:Runner
2015-07-09 15:50:11.281:WARN:omjr.Runner:No tx manager found
2015-07-09 15:50:11.521:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
2015-07-09 15:50:12.175:WARN:oejw.WebAppContext:Failed startup of context
o.e.j.w.WebAppContext{/geoserver,file:/var/www/geonode/geoserver/geoserver/},../geoserver
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:622)
at
org.eclipse.jetty.webapp.IterativeDescriptorProcessor.visit(IterativeDescriptorProcessor.java:85)
at
org.eclipse.jetty.webapp.IterativeDescriptorProcessor.process(IterativeDescriptorProcessor.java:72)
at org.eclipse.jetty.webapp.MetaData.resolve(MetaData.java:367)
at
org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1248)
at
org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706)
at
org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:492)
at
org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
at
org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229)
at
org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172)
at
at
at
at
org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95)
at org.eclipse.jetty.server.Server.doStart(Server.java:277)
at
at org.mortbay.jetty.runner.Runner.run(Runner.java:504)
at org.mortbay.jetty.runner.Runner.main(Runner.java:625)
Caused by:
java.lang.UnsupportedClassVersionError:
org/geoserver/GeoserverInitStartupListener : Unsupported major.minor
version 51.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:643)
at
java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at
org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:421)
at
org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:383)
at
org.eclipse.jetty.server.handler.ContextHandler.loadClass(ContextHandler.java:1514)
at
org.eclipse.jetty.webapp.StandardDescriptorProcessor.visitListener(StandardDescriptorProcessor.java:1864)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
2015-07-09 15:50:12.191:INFO:oejs.NCSARequestLog:Opened
2015-07-09 15:50:12.244:INFO:oejs.AbstractConnector:Started
SelectChannelConnector at 0.0.0.0:8080
The logs are available at /var/www/geonode/geoserver/jetty.log
GeoServer never started properly or timed out.It may still be running in
the background.
Perhaps this is due to the new GeoServer version 2.7? Anyone know how to
get this to work?
Thanks,
Tukang Sampah
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150709/aa0e4a35/attachment-0001.html>
More information about the geonode-users
