[GeoNode-users] geonode can't retreive layers uplaoded by a deleted user
Paolo Corti pcorti at gmail.com
Thu Jul 9 04:03:48 PDT 2015
If you delete a user all the related objects will be deleted, django
admin should have provided you with a warning of all the resources
that would be deleted together with the user.
The workflow in such a case, if you want to remove a user and keep
his/her layers, it is to change the ownership of the layers.
hope it helps
p
On Thu, Jul 9, 2015 at 12:00 PM, FERRARI Hugo <ferrari_hugo at yahoo.fr> wrote:
> Hello everyone
> In my geonode instance if I delete a user who had uploaded layers , the
> corresponding layers can't be retrieved by geoserver once the user has been
> deleted
> and when i go to the geoserver backend interface, all the layers from the
> deleted user have disapeared
> from GET request which usually retrive the WMS
> full request adress
> http://carto-reunion.cirad.fr/geoserver/wms?LAYERS=geonode%3Aroute_1&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer
> response
> <?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
> ServiceExceptionReport SYSTEM
> "http://carto-reunion.cirad.fr:80/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1" >
>  	<ServiceException code="LayerNotDefined" locator="MapLayerInfoKvpParser">
>      		 geonode:route_1: no such layer on this server
> 	</ServiceException>
> </ServiceExceptionReport>
> Is it a normal behavior or did I miss something ?
> Thanks,
> Hugo FERRARI
> Le 06/07/2015 09:33, FERRARI Hugo a écrit :
> I've found a temporary solution, but with a security failure...
> I' ve created a directory inside /var/www/geonode called notification and I
> gave a 777 perms on it.
> So everyone can write.
> does it mean that the user who puts the notifications locks is not www-data
> (ie apache) ? which user could it be ?
> thanks a lot ,
> Hugo FERRARI
> Le 03/07/2015 18:27, FERRARI Hugo a écrit :
> hello
>  I've got a problem trying to uplaod layers and having the notification
> system enabled
> I got this message in front end
> failed to create /var/www/<hostname>.MainThread-2979
> I read this message on the issues forum,
> so I put
>  NOTIFICATION_LOCK_LOCATION='/var/www/geonode'
> in the settings files
> even if this folder is owned by www-data user, I always get this error
> message, and no data has been loaded in geoserver. I only received the
> notification e mail which indicates that the layer have been loaded...
> In apache error.log I got this queue
> [Fri Jul 03 09:07:23.260468 2015] [:error] [pid 2979]   File
> "/home/ferrari/geonode/geonode/tasks/email.py" , line 21, in
> send_queued_notifications
> [Fri Jul 03 09:07:23.260473 2015] [:error] [pid 2979]
> send_all(settings.NOTIFICATION_LOCK_LOCATION)
> [Fri Jul 03 09:07:23.260478 2015] [:error] [pid 2979]   File
> "/usr/local/lib/python2.7/dist-packages/notification/engine.py", line 43, in
> send_all
> [Fri Jul 03 09:07:23.260483 2015] [:error] [pid 2979]     lock =
> acquire_lock(*args)
> [Fri Jul 03 09:07:23.260488 2015] [:error] [pid 2979]   File
> "/usr/local/lib/python2.7/dist-packages/notification/engine.py", line 31, in
> acquire_lock
> [Fri Jul 03 09:07:23.260493 2015] [:error] [pid 2979]
> lock.acquire(LOCK_WAIT_TIMEOUT)
> [Fri Jul 03 09:07:23.260497 2015] [:error] [pid 2979]   File
> "/usr/local/lib/python2.7/dist-packages/notification/lockfile.py", line 249,
> in acquire
> [Fri Jul 03 09:07:23.260502 2015] [:error] [pid 2979]     raise
> LockFailed("failed to create %s" % self.unique_name)
> [Fri Jul 03 09:07:23.260507 2015] [:error] [pid 2979] LockFailed: failed to
> create
> Any ideas ?
> thanks a lot,
> Hugo FERRARI
> Le 02/07/2015 23:00, geonode-users-request at lists.osgeo.org a écrit :
> Send geonode-users mailing list submissions to
> 	geonode-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	geonode-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-users digest..."
> Today's Topics:
>    1. Re: geonode_project branch migration (Alessio)
>    2. Re: geonode_project branch migration (Simone Dalmasso)
>    3. Re: GeoNode Updateip Error (No module named	relationships)
>       (Paolo Corti)
> Message: 1
> Date: Thu, 2 Jul 2015 12:17:57 +0200
> From: Alessio <alessio.dl at gmail.com>
> To: geonode-users at lists.osgeo.org
> Subject: Re: [GeoNode-users] geonode_project branch migration
> Message-ID:
> 	<CAHguyMtkSEw9zXuO5fdjiBDdZdZD5Pm7m=7ANa-uEaOHxdp4Eg at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Simone,
> I'm testing GeoNode 2.4b25 on a virtual machine and I just created a
> project.
> I can't find local_settings.py .sample inside the folder of my project, is
> it fine? It contains only a settings.py file.
> Thanks
> 2015-06-30 10:47 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Dears,
> we just reorganized the geonode_project branches to better reflect the
> geonode branches setup and avoid common confusion.
> Now the branch master of the geonode_project correctly supports the branch
> master of geonode,
> while the branch 2.0 supports the branch 2.0.x of geonode. The branch 2.4
> of the geonode_project is gone.
> https://github.com/GeoNode/geonode-project
> https://github.com/GeoNode/geonode-project/tree/2.0
> Hope this makes things easier.
> The geonode dev team
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
