[GeoNode-users] "layers_uploadsession" does not exist
    Simone Dalmasso
    simone.dalmasso at gmail.com
    Fri Jul 10 02:17:13 PDT 2015
hm clearly something went wrong with the restore then. I would suggest you
to try to reload back the db. Everything should be preserver and especially
geoserver should not have changed at all since you never touched it's data
folder.
2015-07-10 11:05 GMT+02:00 Christian Willmes <
christian.willmes at googlemail.com>:
>  Hi,
> wow cool, thats an easy fix. I can edit the metadata again. I was worried,
> the whole DB (user rights etc.) would be messed up.
> The metadata not stored also in Geoserver, such as the keywords and
> categories are missing. Also the spatial region is not there. But the
> descriptions/abstracts and titles are still there.
> regards,
> Christian
> Am 09.07.2015 um 18:11 schrieb Simone Dalmasso:
> Hi your error is:
> Permission denied: u'/var/www/geonode/uploaded/
> so a:
> $ sudo chmod -R a+w /var/www/geonode/uploaded
> should fix.
>  For the metadata and categories, they shouldn't be gone at all.
> Not sure what went wrong there.
> 2015-07-09 16:56 GMT+02:00 Christian Willmes <
>>  Hi,
>> first it seemed to work fine, all layers are back and accessible, but I
>> cant edit the metadata of existing layers vie the geonode webapp anymore.
>> The frontend dies and gives an "Internal Server Error".
>> The apache error messages look like:
>> [Thu Jul 09 09:50:53.648422 2015] [:error] [pid 2080:tid 140415632357120]
>> Internal Server Error: /layers/geonode:sealevels_10_150m/metadata
>> [Thu Jul 09 09:50:53.648484 2015] [:error] [pid 2080:tid 140415632357120]
>> Traceback (most recent call last):
>> [Thu Jul 09 09:50:53.648652 2015] [:error] [pid 2080:tid 140415632357120]
>> IOError: [Errno 13] Permission denied:
>> u'/var/www/geonode/uploaded/thumbs/layer-d680d189-b46f-468e-8267-e8e5b497988c-thumb.png'
>> [Thu Jul 09 09:50:53.664269 2015] [:error] [pid 2080:tid 140415632357120]
>> [remote 134.95.150.136:14361] mod_wsgi (pid=2080): Exception occurred
>> processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
>> [Thu Jul 09 09:50:53.665753 2015] [:error] [pid 2080:tid 140415632357120]
>> [remote 134.95.150.136:14361]   File
>> "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
>> __getitem__
>> [Thu Jul 09 09:50:53.665849 2015] [:error] [pid 2080:tid 140415632357120]
>> [remote 134.95.150.136:14361]     raise KeyError(key)
>> [Thu Jul 09 09:50:53.665872 2015] [:error] [pid 2080:tid 140415632357120]
>> [remote 134.95.150.136:14361] KeyError: 'request'
>> It is the same account name for the superuser.
>> Additionally all the Categories and Keywords are gone... (that's why I
>> wanted to edit the metadata in the first place...)
>> Any hint on how I can fix this?
>> Thanks and regards,
>> Christian
>> Am 07.07.2015 um 15:49 schrieb Simone Dalmasso:
>> Christian, in your case the backup preserver the old schema. Although
>> since the difference in the new schema is a single column being added, you
>> can use the "geonode syncdb --no-initial-data"  before loading back the
>> backup. The syncdb will create the new schema and the backup should load
>> leaving the new column blank. The --no-initial-data will make sure that
>> syncdb only creates the schema without loading any fixture.
>>  Hope this helps.
>> 2015-07-07 14:48 GMT+02:00 Christian Willmes <
>>> Hi,
>>> following up on this thread:
>>> https://github.com/GeoNode/geonode/issues/2046
>>> I did the sugested steps, but the upload problem persits. No wonder,
>>> because in which step should the 'layers_uploadsession' session be created?
>>> The erreor inthe apache log looks like:
>>> [Tue Jul 07 07:39:11.377817 2015] [:error] [pid 22673:tid
>>> 139958275774208] column "context" of relation "layers_uploadsession" does
>>> not exist
>>> [Tue Jul 07 07:39:11.377877 2015] [:error] [pid 22673:tid
>>> 139958275774208] LINE 1: ...e", "user_id", "processed", "error",
>>> "traceback", "context")...
>>> [Tue Jul 07 07:39:11.377884 2015] [:error] [pid 22673:tid
>>> 139958275774208] ^
>>> [Tue Jul 07 07:39:11.377898 2015] [:error] [pid 22673:tid
>>> 139958275774208] Traceback (most recent call last):
>>> [Tue Jul 07 07:39:11.377904 2015] [:error] [pid 22673:tid
>>> 139958275774208]   File
>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py"
>>> I did exactly the following (from
>>> http://docs.geonode.org/en/master/tutorials/admin/backup/index.html):
>>> sudo -u postgres -i pg_dump -c -Fc geonode > geonodedb.backup
>>> sudo service apache2 stop
>>> sudo /etc/init.d/tomcat7 stop
>>> sudo service postgresql start
>>> sudo -u postgres -i "psql -c 'drop database geonode;'"
>>> sudo -u postgres -i "psql -c 'create database geonode;'"
>>> sudo -u postgres -s "pg_restore -Fc -d geonode /path/to/geonodedb.backup"
>>> sudo service apache2 start
>>> sudo /etc/init.d/tomcat7 start
>>> How can I solve this problem?
>>> Best regards,
>>> Christian
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150710/d45324ff/attachment-0001.html>
More information about the geonode-users
