[GeoNode-users] geonode can't retreive layers uplaoded by a deleted user
Simone Dalmasso simone.dalmasso at gmail.com
Mon Jul 13 02:59:12 PDT 2015
Hi I tested on demo and can confirm the Hugo error. Need to fix that. Let's
open a ticket.
2015-07-13 11:29 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> Hi
> I made a test, on a fresh geonode instance.
> what I did:
> 1. create a new user
> 2. upload a shapefile with the new user
> 3. change ownership, and contact points in the layer to a different user
> now If I try to remove the user, I get the following error:
> UploadSession matching query does not exist.
> Definitely something wrong, though the error is different from the one you
> get.
> I will have a deeper look and get back.
> thanks for let us know
> p
> On Thu, Jul 9, 2015 at 1:28 PM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
> wrote:
> > that's what I did.
> > I change the owner, MD producer and PoC  before deleting the user.
> > the layers last in geonode resource list but have been deleted from
> > geoserver.
> > in my customized geonode instance it's not a problem because  I probably
> > won't delete a user if I gave him permission to add resource.
> > But I tought I could' be usefull to mention it.
> > Thanks again
> > Le 09/07/2015 15:03, Paolo Corti a écrit :
> >> If you delete a user all the related objects will be deleted, django
> >> admin should have provided you with a warning of all the resources
> >> that would be deleted together with the user.
> >> The workflow in such a case, if you want to remove a user and keep
> >> his/her layers, it is to change the ownership of the layers.
> >> hope it helps
> >> p
> >> On Thu, Jul 9, 2015 at 12:00 PM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
> >> wrote:
> >>> Hello everyone
> >>> In my geonode instance if I delete a user who had uploaded layers , the
> >>> corresponding layers can't be retrieved by geoserver once the user has
> >>> been
> >>> deleted
> >>> and when i go to the geoserver backend interface, all the layers from
> the
> >>> deleted user have disapeared
> >>> from GET request which usually retrive the WMS
> >>> full request adress
> http://carto-reunion.cirad.fr/geoserver/wms?LAYERS=geonode%3Aroute_1&SERVICE=WMS&VERSION=1.1.1&REQUEST=DescribeLayer
> >>> response
> >>> <?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
> >>> ServiceExceptionReport SYSTEM
> http://carto-reunion.cirad.fr:80/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd
> >>> <ServiceExceptionReport version="1.1.1" >
> >>>         <ServiceException code="LayerNotDefined"
> >>> locator="MapLayerInfoKvpParser">
> >>>                  geonode:route_1: no such layer on this server
> >>>         </ServiceException>
> >>> </ServiceExceptionReport>
> >>> Is it a normal behavior or did I miss something ?
> >>> Thanks,
> >>> Hugo FERRARI
> >>> Le 06/07/2015 09:33, FERRARI Hugo a écrit :
> >>> I've found a temporary solution, but with a security failure...
> >>> I' ve created a directory inside /var/www/geonode called notification
> and
> >>> I
> >>> gave a 777 perms on it.
> >>> So everyone can write.
> >>> does it mean that the user who puts the notifications locks is not
> >>> www-data
> >>> (ie apache) ? which user could it be ?
> >>> thanks a lot ,
> >>> Hugo FERRARI
> >>> Le 03/07/2015 18:27, FERRARI Hugo a écrit :
> >>> hello
> >>>   I've got a problem trying to uplaod layers and having the
> notification
> >>> system enabled
> >>> I got this message in front end
> >>> failed to create /var/www/<hostname>.MainThread-2979
> >>> I read this message on the issues forum,
> >>> so I put
> >>>   NOTIFICATION_LOCK_LOCATION='/var/www/geonode'
> >>> in the settings files
> >>> even if this folder is owned by www-data user, I always get this error
> >>> message, and no data has been loaded in geoserver. I only received the
> >>> notification e mail which indicates that the layer have been loaded...
> >>> In apache error.log I got this queue
> >>> [Fri Jul 03 09:07:23.260468 2015] [:error] [pid 2979]   File
> >>> "/home/ferrari/geonode/geonode/tasks/email.py" , line 21, in
> >>> send_queued_notifications
> >>> [Fri Jul 03 09:07:23.260473 2015] [:error] [pid 2979]
> >>> send_all(settings.NOTIFICATION_LOCK_LOCATION)
> >>> [Fri Jul 03 09:07:23.260478 2015] [:error] [pid 2979]   File
> >>> "/usr/local/lib/python2.7/dist-packages/notification/engine.py", line
> 43,
> >>> in
> >>> send_all
> >>> [Fri Jul 03 09:07:23.260483 2015] [:error] [pid 2979]     lock =
> >>> acquire_lock(*args)
> >>> [Fri Jul 03 09:07:23.260488 2015] [:error] [pid 2979]   File
> 31,
> >>> in
> >>> acquire_lock
> >>> [Fri Jul 03 09:07:23.260493 2015] [:error] [pid 2979]
> >>> lock.acquire(LOCK_WAIT_TIMEOUT)
> >>> [Fri Jul 03 09:07:23.260497 2015] [:error] [pid 2979]   File
> >>> "/usr/local/lib/python2.7/dist-packages/notification/lockfile.py", line
> >>> 249,
> >>> in acquire
> >>> [Fri Jul 03 09:07:23.260502 2015] [:error] [pid 2979]     raise
> >>> LockFailed("failed to create %s" % self.unique_name)
> >>> [Fri Jul 03 09:07:23.260507 2015] [:error] [pid 2979] LockFailed:
> failed
> >>> to
> >>> create
> >>> Any ideas ?
> >>> thanks a lot,
> >>> Hugo FERRARI
> >>> Le 02/07/2015 23:00, geonode-users-request at lists.osgeo.org a écrit :
> >>> Send geonode-users mailing list submissions to
> >>>         geonode-users at lists.osgeo.org
> >>> To subscribe or unsubscribe via the World Wide Web, visit
> >>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> >>> or, via email, send a message with subject or body 'help' to
> >>> You can reach the person managing the list at
> >>>         geonode-users-owner at lists.osgeo.org
> >>> When replying, please edit your Subject line so it is more specific
> >>> than "Re: Contents of geonode-users digest..."
> >>> Today's Topics:
> >>>     1. Re: geonode_project branch migration (Alessio)
> >>>     2. Re: geonode_project branch migration (Simone Dalmasso)
> >>>     3. Re: GeoNode Updateip Error (No module named      relationships)
> >>>        (Paolo Corti)
> >>> Message: 1
> >>> Date: Thu, 2 Jul 2015 12:17:57 +0200
> >>> From: Alessio <alessio.dl at gmail.com>
> >>> To: geonode-users at lists.osgeo.org
> >>> Subject: Re: [GeoNode-users] geonode_project branch migration
> >>> Message-ID:
> >>> <CAHguyMtkSEw9zXuO5fdjiBDdZdZD5Pm7m=7ANa-uEaOHxdp4Eg at mail.gmail.com>
> >>> Content-Type: text/plain; charset="utf-8"
> >>> Hi Simone,
> >>> I'm testing GeoNode 2.4b25 on a virtual machine and I just created a
> >>> project.
> >>> I can't find local_settings.py .sample inside the folder of my project,
> >>> is
> >>> it fine? It contains only a settings.py file.
> >>> Thanks
> >>> 2015-06-30 10:47 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
> >>> Dears,
> >>> we just reorganized the geonode_project branches to better reflect the
> >>> geonode branches setup and avoid common confusion.
> >>> Now the branch master of the geonode_project correctly supports the
> >>> branch
> >>> master of geonode,
> >>> while the branch 2.0 supports the branch 2.0.x of geonode. The branch
> 2.4
> >>> of the geonode_project is gone.
> >>> https://github.com/GeoNode/geonode-project
> >>> https://github.com/GeoNode/geonode-project/tree/2.0
> >>> Hope this makes things easier.
> >>> The geonode dev team
> >>> _______________________________________________
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150713/7e18f1e0/attachment-0001.html>
More information about the geonode-users mailing list
