[GeoNode-users] "layers_uploadsession" does not exist
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Jul 14 04:30:06 PDT 2015
Christian, did you get any errors while loading the database?.
A dump and reload of it should be a smooth operation.
The stacktrace doesn't tell that much...
2015-07-14 10:54 GMT+02:00 Christian Willmes <
christian.willmes at googlemail.com>:
> Hi,
> I have the following issues with geonode since the update and fixing the
> DB, as discussed in this thread.
> 1. The keyword handling is somehow messed up. GeoNode only shows one
> Keyword, there are at least10 different assigned to the various layers.
> 2. After a "geonode updatelayers", layers that were deleted through the
> frontend reappear in the GeoNode catalog.
> 3. On each request I get the following error in apache error.log:
> [Tue Jul 14 03:03:06.744495 2015] [:error] [pid 23485:tid 140415573407488]
> Internal Server Error: /api/keywords/17/
> [Tue Jul 14 03:03:06.744523 2015] [:error] [pid 23485:tid 140415573407488]
> Traceback (most recent call last):
> [Tue Jul 14 03:03:06.744530 2015] [:error] [pid 23485:tid
> 140415573407488] File
> "/usr/lib/python2.7/dist-packages/tastypie/resources.py", line 217, in
> wrapper
> [Tue Jul 14 03:03:06.744536 2015] [:error] [pid 23485:tid
> 140415573407488] response = callback(request, *args, **kwargs)
> [Tue Jul 14 03:03:06.755778 2015] [:error] [pid 23485:tid 140415573407488]
> KeyError: 'objects'
> [Tue Jul 14 03:03:06.772377 2015] [:error] [pid 23485:tid 140415573407488]
> [remote 134.95.19.174:59667] mod_wsgi (pid=23485): Exception occurred
> processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
> [Tue Jul 14 03:03:06.772430 2015] [:error] [pid 23485:tid 140415573407488]
> [remote 134.95.19.174:59667] Traceback (most recent call last):
> [Tue Jul 14 03:03:06.773172 2015] [:error] [pid 23485:tid 140415573407488]
> [remote 134.95.19.174:59667] File
> "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
> __getitem__
> [Tue Jul 14 03:03:06.773196 2015] [:error] [pid 23485:tid 140415573407488]
> [remote 134.95.19.174:59667] raise KeyError(key)
> [Tue Jul 14 03:03:06.773219 2015] [:error] [pid 23485:tid 140415573407488]
> [remote 134.95.19.174:59667] KeyError: 'request'
> Is there anything I can do to rescue the instance, I really don't want to
> wipe and reinstall including styling the layers etc... :/
> Thanks and regards,
> Christian
> Am 10.07.2015 um 11:17 schrieb Simone Dalmasso:
> hm clearly something went wrong with the restore then. I would suggest you
> to try to reload back the db. Everything should be preserver and especially
> geoserver should not have changed at all since you never touched it's data
> folder.
> 2015-07-10 11:05 GMT+02:00 Christian Willmes <
>> Hi,
>> wow cool, thats an easy fix. I can edit the metadata again. I was
>> worried, the whole DB (user rights etc.) would be messed up.
>> The metadata not stored also in Geoserver, such as the keywords and
>> categories are missing. Also the spatial region is not there. But the
>> descriptions/abstracts and titles are still there.
>> regards,
>> Christian
>> Am 09.07.2015 um 18:11 schrieb Simone Dalmasso:
>> Hi your error is:
>> Permission denied: u'/var/www/geonode/uploaded/
>> so a:
>> $ sudo chmod -R a+w /var/www/geonode/uploaded
>> should fix.
>> For the metadata and categories, they shouldn't be gone at all.
>> Not sure what went wrong there.
>> 2015-07-09 16:56 GMT+02:00 Christian Willmes <
>>> Hi,
>>> first it seemed to work fine, all layers are back and accessible, but I
>>> cant edit the metadata of existing layers vie the geonode webapp anymore.
>>> The frontend dies and gives an "Internal Server Error".
>>> The apache error messages look like:
>>> [Thu Jul 09 09:50:53.648422 2015] [:error] [pid 2080:tid
>>> 140415632357120] Internal Server Error:
>>> /layers/geonode:sealevels_10_150m/metadata
>>> [Thu Jul 09 09:50:53.648484 2015] [:error] [pid 2080:tid
>>> 140415632357120] Traceback (most recent call last):
>>> [Thu Jul 09 09:50:53.648652 2015] [:error] [pid 2080:tid
>>> 140415632357120] IOError: [Errno 13] Permission denied:
>>> u'/var/www/geonode/uploaded/thumbs/layer-d680d189-b46f-468e-8267-e8e5b497988c-thumb.png'
>>> [Thu Jul 09 09:50:53.664269 2015] [:error] [pid 2080:tid
>>> 140415632357120] [remote 134.95.150.136:14361] mod_wsgi (pid=2080):
>>> Exception occurred processing WSGI script
>>> [Thu Jul 09 09:50:53.665753 2015] [:error] [pid 2080:tid
>>> 140415632357120] [remote 134.95.150.136:14361] File
>>> __getitem__
>>> [Thu Jul 09 09:50:53.665849 2015] [:error] [pid 2080:tid
>>> 140415632357120] [remote 134.95.150.136:14361] raise KeyError(key)
>>> [Thu Jul 09 09:50:53.665872 2015] [:error] [pid 2080:tid
>>> 140415632357120] [remote 134.95.150.136:14361] KeyError: 'request'
>>> It is the same account name for the superuser.
>>> Additionally all the Categories and Keywords are gone... (that's why I
>>> wanted to edit the metadata in the first place...)
>>> Any hint on how I can fix this?
>>> Thanks and regards,
>>> Christian
>>> Am 07.07.2015 um 15:49 schrieb Simone Dalmasso:
>>> Christian, in your case the backup preserver the old schema. Although
>>> since the difference in the new schema is a single column being added, you
>>> can use the "geonode syncdb --no-initial-data" before loading back the
>>> backup. The syncdb will create the new schema and the backup should load
>>> leaving the new column blank. The --no-initial-data will make sure that
>>> syncdb only creates the schema without loading any fixture.
>>> Hope this helps.
>>> 2015-07-07 14:48 GMT+02:00 Christian Willmes <
>>>> Hi,
>>>> following up on this thread:
>>>> https://github.com/GeoNode/geonode/issues/2046
>>>> I did the sugested steps, but the upload problem persits. No wonder,
>>>> because in which step should the 'layers_uploadsession' session be created?
>>>> The erreor inthe apache log looks like:
>>>> [Tue Jul 07 07:39:11.377817 2015] [:error] [pid 22673:tid
>>>> 139958275774208] column "context" of relation "layers_uploadsession" does
>>>> not exist
>>>> [Tue Jul 07 07:39:11.377877 2015] [:error] [pid 22673:tid
>>>> 139958275774208] LINE 1: ...e", "user_id", "processed", "error",
>>>> "traceback", "context")...
>>>> [Tue Jul 07 07:39:11.377884 2015] [:error] [pid 22673:tid
>>>> 139958275774208] ^
>>>> [Tue Jul 07 07:39:11.377898 2015] [:error] [pid 22673:tid
>>>> 139958275774208] Traceback (most recent call last):
>>>> [Tue Jul 07 07:39:11.377904 2015] [:error] [pid 22673:tid
>>>> 139958275774208] File
>>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py"
>>>> I did exactly the following (from
>>>> http://docs.geonode.org/en/master/tutorials/admin/backup/index.html):
>>>> sudo -u postgres -i pg_dump -c -Fc geonode > geonodedb.backup
>>>> sudo service apache2 stop
>>>> sudo /etc/init.d/tomcat7 stop
>>>> sudo service postgresql start
>>>> sudo -u postgres -i "psql -c 'drop database geonode;'"
>>>> sudo -u postgres -i "psql -c 'create database geonode;'"
>>>> sudo -u postgres -s "pg_restore -Fc -d geonode
>>>> /path/to/geonodedb.backup"
>>>> sudo service apache2 start
>>>> sudo /etc/init.d/tomcat7 start
>>>> How can I solve this problem?
>>>> Best regards,
>>>> Christian
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150714/f50a3a44/attachment-0001.html>
More information about the geonode-users
