[GeoNode-users] Editing navigation bar
Carmine Massarelli carmine.massarelli at ba.irsa.cnr.it
Tue Jul 28 07:32:33 PDT 2015
Thanks...
if i create a link i will exit from the framework...
I would like to have a section without the content-wrap, so i duplicated
/documents/  renaming it in /multimedia/ but i am not able to link to
the new folder created editing base.html, urls.py and settings.py.
I have already modified the document_base.html in my new multimedia
folder to have what i want, but to create the link it seems hard.
I should link the code /<a href="{% url "documents_browse" %}">{% trans
"Multimedia" %}</a>///to the modified file in my new /multimedia/ folder
(copy of /documents/) inside the geonode content
(/usr/local/lib/python2.7/dist-packages/geonode).
Any suggestion?
Thanks
Il 07/28/2015 02:23 PM, Simone Dalmasso ha scritto:
> Hi, that tag is a django template tag that creates a url from it's
> name defined in urls.py.
> see https://docs.djangoproject.com/en/1.8/ref/templates/builtins/#url
> If you don't have a django url for what you need, then you can
> hardcode the link instead of having a "{% url" block.
> Hope it helps
> 2015-07-28 14:02 GMT+02:00 Carmine Massarelli
> <carmine.massarelli at ba.irsa.cnr.it
> <mailto:carmine.massarelli at ba.irsa.cnr.it>>:
>     Dear,
>     I would like to add a voice to the navigation bar for a link to a
>     web page that I am creating (html5, javascript and OL3) with
>     multimedia contents for on-line visualisation.
>     Because I would like this page to be available within geonode
>     framework, I edited the base.html addind this line copyed:
>     {% block extra-nav %}
>     <li id="nav_documents">
>     <a href="{% url "documents_browse" %}">{% trans "Multimedia" %}</a>
>     </li>
>     {% endblock %}
>     The problem is that i do not know the mean of the code {% url
>     "documents_browse" %} and where is the referred link
>     documents_browse that i would modify tofit for my cms.
>     Thanks
>     Dr. Nat. Carmine Massarelli, Ph.D.
>     National Research Council
>     Water Research Institute (IRSA)
>     Addr: De Blasio n.5 - 70132 Bari Z.I.
>     Tel: +39 080 582 05 06
>     Skype: carmine.massarelli
>     _______________________________________________
>     geonode-users mailing list
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150728/ae8d0492/attachment.html>
More information about the geonode-users mailing list
