[GeoNode-users] 'NoneType' object has no attribute 'name'
Israel López asralf at gmail.com
Tue Jun 2 13:13:27 PDT 2015
Hello
I'm having the same issue and I don't understand the solution very well,
could you tell wich files exactly??
Or
Are you talking about all the xml?? I have 200 shapes :S
2015-04-09 16:06 GMT-05:00 GC-54 <nepanode at gmail.com>:
> I encountered this same issue... I solved it by replacing the XML
> documents for layers in geoserver_data directory. I'm assuming there must
> have been a change in the schema for the upgraded version geoserver geonode
> now uses - I'd suggest investigating if you didn't try to migrate data
> manually; but if you did move old files in the new geoserver_data dir those
> are likely to be what are corrupting things.
> On Thu, Apr 9, 2015 at 9:55 AM, Paul Magdon <pmagdon at gwdg.de> wrote:
>> Dear all,
>> I have trouble with uploading a shapefile on a fresh install of Geonode
>> (2.4b24) on a Ubuntu 14.04 VM.
>> Everything is running but when I try to upload a layer I get the
>> follwoing error (from the apache2 log:
>> [Thu Apr 09 07:46:31.547150 2015] [:error][style, created =
>> Style.objects.get_or_create(name=gs_style.name)
>> [Thu Apr 09 07:46:31.547154 2015] [:error] AttributeError: 'NoneType'
>> I guess some think with the Geoserver configuration is missing but I have
>> no clue where to start search for.
>> Any ideas?
>> Greetings Paul
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150602/63756281/attachment.html>
More information about the geonode-users mailing list
