[GeoNode-users] Select/Filter remote services' layers
Paolo Corti pcorti at gmail.com
Wed Jun 10 07:17:36 PDT 2015
Hi
I need this feature as well and I should be implementing it sometime soon
in the next few weeks - if it will not be there already at the time :)
cheers
p
On Wed, Jun 10, 2015 at 3:24 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Alessandro, good points. I don't think that is possible to import a
> subset of the layers nor set the permissions in advance.
> As a workaround delete layers you could use the admin panel, while for the
> permissions you can change the GeoNode default permissions from settings
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L413 before
> importing them or change them in bulk from the layer list page (select all
> of them and use the set permissions widget).
> Anyway I think it would be good to have a ticket for the services layers
> subset. Could you open it?
> 2015-06-10 15:10 GMT+02:00 Alessandro Sarretta <
> alessandro.sarretta at gmail.com>:
>>  Dear all,
>> I'm testing the use of remote services with GeoNode 2.4.
>> I'm testing it with some WMS services serving hundreds of layers, and I'd
>> like to register in geonode only some of those.
>> Is it possible, before or during the registration phase, to select which
>> layer to register from a specific service? I've seen that after the
>> registration the layers from the registered service can be deleted one by
>> one, but this could be a long and tricky issue...
>> In addition to that, when I register the service, the layers appear to be
>> visible to everyone (and I think this depends from the default
>> permissions): is it possible (from the web interface) to set the default
>> permissions for the registered layer in advance (i.e. during the
>> registration process?).
>> Thank you,
>> Ale
>> Alessandro Sarretta
>> skype/twitter: alesarrett
>> Web: ilsarrett.wordpress.com
>> Research information:
>>    - Google scholar profile
>>    <http://scholar.google.it/citations?user=IsyXargAAAAJ&hl=it>
>>    - ORCID <http://orcid.org/0000-0002-1475-8686>
>>    - Research Gate
>>    <https://www.researchgate.net/profile/Alessandro_Sarretta>
>>    - <https://impactstory.org/AlessandroSarretta>
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150610/f4d88cf4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150610/f4d88cf4/attachment-0001.png>
More information about the geonode-users mailing list
