[GeoNode-users] Restrict the add_layer auth to some user
Daniel Victoria daniel.victoria at gmail.com
Tue Jun 16 07:45:02 PDT 2015
On the same topic of restricting permissions, can it be done for entire
groups? For our use case we though of having a two step process:
1) A producer group that can add data but it won't be public available;
2) A metadata validation group would then come in and validate the metadata
(is everything filled correctly?) and make the layers/maps public.
On Tue, Jun 16, 2015 at 11:13 AM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
wrote:
> Hello world,
> in Geonode there are permissions on resources and we can modify them.
> But is there any way to restrict actions for some users ?
> I want only few users to be allowed to add new layers in geonode but
> apparently the only existing criteria to permit is authentication.
> I'm sure i'm not the first to ask this question.
> In auth_permission postgres table we can see that the "add_layer"
> permision already exists but it is not affected to users.
> Thanks for your advices
> Hugo FERRARI
> Le 09/06/2015 18:50, geonode-users-request at lists.osgeo.org a écrit :
>> Send geonode-users mailing list submissions to
>>         geonode-users at lists.osgeo.org
>> To subscribe or unsubscribe via the World Wide Web, visit
>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>         geonode-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of geonode-users digest..."
>> Today's Topics:
>>     1. developpement: Modifying permission behavior and data
>>        visibility in Geonode (FERRARI Hugo)
>>     2. Re: developpement: Modifying permission behavior and data
>>        visibility in Geonode (Ariel Nunez)
>>     3. Re: developpement: Modifying permission behavior and data
>>        visibility in Geonode (Paolo Corti)
>> Message: 1
>> Date: Tue, 09 Jun 2015 16:56:18 +0400
>> From: FERRARI Hugo <ferrari_hugo at yahoo.fr>
>> To: geonode-users at lists.osgeo.org
>> Subject: [GeoNode-users] developpement: Modifying permission behavior
>>         and data visibility in Geonode
>> Message-ID: <5576E272.6090606 at yahoo.fr>
>> Content-Type: text/plain; charset=windows-1252; format=flowed
>> Hello everyone,
>> I have installed a complete geonode instance on a developpement server.
>> I want  to change thebehaviorofthesoftware  to make it fit the need of
>> the institution I work for.
>> So i'm looking for some advices because  I didn't manage to code it yet.
>> My aim to separate metada access from the data access.
>> That  is to make all the layers uploaded in geoserver VISIBLE for all
>> users (logged or not) but only in the layer-list page , not on the
>> layer-detail page .
>> If you click on any specific layer in the layer-list (or document-list
>> because i want the same behavior for both), you get the layer detail so
>> you what will see is:
>> - In the case you have the view_resourcebase permission (who can see it
>> ?), you will see the current template corresponding to
>> layer_detail.html: both access to datas and metadatas.
>> - In the other case if you don't have the view_resourcebase permission,
>> you 'll only have access to metadatas's ressource (that means a template
>> similar to layer_detail.html but Instead of the geoexplorer frame you
>> sould have a "permission denied" message, but the possibility to
>> retrieve metadata).
>> It's quite simple to make all the layers visible in the layer list,
>> whoever is logged in (you just have to modify SKIP_PERMS_FILTERS in
>> settings.py AND read_list function in module api/authorisation.py).
>> but the actual behavior is to catch a 403 http error when trying to view
>> the layer detail.
>> Modifying the 403.html template does not seems to be the good way to
>> process.
>> I don't think it is necessary to modify geonode's database model because
>> the view_ressource permission  is enough, considering that  viewing the
>> ressource is equivalent to having access to the data (even if you can't
>> download it). There's no need to add a new kind of permissions, as far
>> as I can guess.
>> What is prefered is not throwing a 403 error but just the
>> layer_detail.html template modified to get only metadatas.
>> I hope the explanation was clear enough,
>> Hugo FERRARI
>> PS
>> Does it correspond to the actual geonode developpement policy ?
>> Datas and metada are strongly linked in this software.
>> Could this functionnality be interresting for any other geonode users?
>> Le 08/06/2015 23:00, geonode-users-request at lists.osgeo.org a ?crit :
>>> Today's Topics:
>>>      1. Re: osgeo module install problem (Simone Dalmasso)
>>>      2. Problems to Translate Geonode - Transifex -     Portuguese
>>>         (Brazil) (Davi Custodio)
>>>      3. Re: Problems to Translate Geonode - Transifex - Portuguese
>>>         (Brazil) (Julien Collaer)
>>> Message: 1
>>> Date: Sun, 7 Jun 2015 21:40:13 +0200
>>> From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>> To: Vicente <deluca.vicente at gmail.com>
>>> Cc: geonode-users <geonode-users at lists.osgeo.org>
>>> Subject: Re: [GeoNode-users] osgeo module install problem
>>> Message-ID:
>>>         <CAAHAC+cU9GgbBUe-ocH4GJZ1PaXEZDrY5W=
>>> ZCsTzSUSx5ymVvA at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi, you are missing the gdal python bindings, a "pip install gdal" should
>>> fix it.
>>> Hope it helps, ciao
>>> 2015-06-07 17:59 GMT+02:00 Vicente <deluca.vicente at gmail.com>:
>>>  Good afternoon,
>>>> If I run the following line from my command line, the answer is
>>>> successful
>>>> $ sudo apt-get -y install libgdal1h libgdal-dev python-gdal
>>>> But if I run from the session virtualenv, the answer is No module named
>>>> osgeo.
>>>> I have just added the following session variables in my .bashrc:
>>>> export VIRTUALENVWRAPPER_PYTHON = / usr / bin / python
>>>> export WORKON_HOME = ~ / .venvs
>>>> source /usr/local/bin/virtualenvwrapper.sh
>>>> export PIP_DOWNLOAD_CACHE = $ HOME / .pip-downloads
>>>> Both session with virtualenv or outside, the python to run is the same,
>>>> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>>>> The result is that I can not run because there is paver start the osgeo
>>>> module from within the session obviously.
>>>> Thanks!
>>>> [image: MANTA] <http://www.estudiomanta.com/>
>>>> Vicente Deluca
>>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>>>> _______________________________________________
>> Message: 2
>> Date: Tue, 9 Jun 2015 09:01:34 -0500
>> From: Ariel Nunez <ingenieroariel at gmail.com>
>> To: FERRARI Hugo <ferrari_hugo at yahoo.fr>
>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>> Subject: Re: [GeoNode-users] developpement: Modifying permission
>>         behavior and data visibility in Geonode
>> Message-ID:
>> CALh6R-QDnFhFPgQdejPp0Kuh5NABLExo7ONaQWjhyb2hk3chEw at mail.gmail.com>
>> Hugo,
>> Based on what I understand, the best path forward is to have a
>> view_metadata permission that you use to enforce the behavior you want.
>> Assigning a new meaning to the existing permission may be problematic for
>> other users with different needs (for example where metadata is sensitive
>> information).
>> The place where we want to get to, is to allow uploaders to restrict any
>> actions they want, but give the end user buttons to request permissions
>> (to
>> view if they cannot view, to download if they can only view, to edit if
>> the
>> can only download) to encourage a conversation between uploaders and users
>> and provide a workflow to allow access to information when it is needed.
>> The changes you make would be good candidates for inclusion in the main
>> version of GeoNode so others can benefit in the future. Hopefully others
>> (Paolo?) can chime in with more specific feedback.
>> Best,
>> Ariel.
>> On Tue, Jun 9, 2015 at 7:56 AM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
>> wrote:
>>  Hello everyone,
>>> the
>>> layer-detail page .
>>> you
>>> what will see is:
>>> ?), you will see the current template corresponding to layer_detail.html:
>>> sould
>>> have a "permission denied" message, but the possibility to retrieve
>>> metadata).
>>> the layer detail.
>>> process.
>>> as I
>>> can guess.
>>> Hugo FERRARI
>>> PS
>>>> Today's Topics:
>>>> Message: 1
>>>> Message-ID:
>>>> should
>>>> fix it.
>>>> Hope it helps, ciao
>>>>   Good afternoon,
>>>>> successful
>>>>> osgeo.
>>>>> Thanks!
>>>>> Vicente Deluca
>>>  -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <
>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20150609/4dbe42d3/attachment-0001.html
>> Message: 3
>> Date: Tue, 9 Jun 2015 16:50:01 +0200
>> From: Paolo Corti <pcorti at gmail.com>
>> To: Ariel Nunez <ingenieroariel at gmail.com>
>> Cc: FERRARI Hugo <ferrari_hugo at yahoo.fr>,
>> Message-ID:
>> CAHXrU-JBaUUQUBz7BjsNuTkmOpOSLB7rxAaXEt3Qsn1TmKmvqw at mail.gmail.com>
>> Content-Type: text/plain; charset=UTF-8
>> Yes, Ariel is totally right.
>> Currently we don't have a specific permission for viewing metadata.
>> This is implicit with the view_resourcebase permission that gives
>> access to the data and metadata at the same time.
>> As suggested by Ariel you may consider to add a new django guardian
>> permission at the resource base model, like it has been done here [1]
>> and then have your GeoNode instance behaved according to it in views,
>> templates and javascript.
>> I don't think there is an easy way to avoid forking GeoNode and
>> customize the beahviour in your GeoNode project, though it may be not
>> impossible and this would keep your instance easily updateable with
>> mainstream code.
>> Even better, as Ariel suggested, you may though fork it and send a PR
>> as it could be useful for others as well.
>> regards
>> p
>> [1]
>> https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L648
>> On Tue, Jun 9, 2015 at 4:01 PM, Ariel Nunez <ingenieroariel at gmail.com>
>> wrote:
>>> Hugo,
>>> view_metadata
>>> permission that you use to enforce the behavior you want. Assigning a new
>>> meaning to the existing permission may be problematic for other users
>>> with
>>> different needs (for example where metadata is sensitive information).
>>> (to
>>> the
>>> users
>>> Best,
>>> Ariel.
>>> wrote:
>>>> Hello everyone,
>>>> the
>>>> layer-detail page .
>>>> you
>>>> what will see is:
>>>> layer_detail.html:
>>>> sould
>>>> metadata).
>>>> the layer detail.
>>>> process.
>>>> as I
>>>> can guess.
>>>> Hugo FERRARI
>>>> PS
>>>>> Today's Topics:
>>>>> Message: 1
>>>>> Message-ID:
>>>>> <CAAHAC+cU9GgbBUe-ocH4GJZ1PaXEZDrY5W=ZCsTzSUSx5ymVvA at mail.gmail.com>
>>>>> should
>>>>> fix it.
>>>>> Hope it helps, ciao
>>>>>  Good afternoon,
>>>>>> successful
>>>>>> named
>>>>>> osgeo.
>>>>>> same,
>>>>>> osgeo
>>>>>> Thanks!
>>>>>> Vicente Deluca
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150616/874a461c/attachment-0001.html>
More information about the geonode-users mailing list
