[GeoNode-users] Fwd: Restrict the add_layer auth to some user
FERRARI Hugo
ferrari_hugo at yahoo.fr
Tue Jun 16 21:24:29 PDT 2015
That's what I thought, but not giving the add_layer auth to a group
doesn't affect the group members.
So first Do I have to make it work for a single member?
On the same topic , usually django admin backend has a auth user menu.
It vanished in my geonode installation, there is only the group auth menu.
Is it the expected behavior ?
Thanks a lot.
Le 16/06/2015 18:26, Simone Dalmasso a écrit :
> Hi Hugo,
> well this permission is not implemented in GeoNode, you will need to
> hack a bit into it and implement checks for it on the layer upload
> views and add its support in the client. The permission itself can
> then be granted to a group.
> 2015-06-16 16:13 GMT+02:00 FERRARI Hugo <ferrari_hugo at yahoo.fr
> <mailto:ferrari_hugo at yahoo.fr>>:
> Hello world,
> in Geonode there are permissions on resources and we can modify them.
> But is there any way to restrict actions for some users ?
> I want only few users to be allowed to add new layers in geonode
> but apparently the only existing criteria to permit is authentication.
> I'm sure i'm not the first to ask this question.
> In auth_permission postgres table we can see that the "add_layer"
> permision already exists but it is not affected to users.
> Thanks for your advices
> Hugo FERRARI
> Le 09/06/2015 18:50, geonode-users-request at lists.osgeo.org
> <mailto:geonode-users-request at lists.osgeo.org> a écrit :
> Send geonode-users mailing list submissions to
> geonode-users at lists.osgeo.org
> <mailto:geonode-users at lists.osgeo.org>
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geonode-users-owner at lists.osgeo.org
> <mailto:geonode-users-owner at lists.osgeo.org>
> When replying, please edit your Subject line so it is more
> specific
> than "Re: Contents of geonode-users digest..."
> Today's Topics:
> 1. developpement: Modifying permission behavior and data
> visibility in Geonode (FERRARI Hugo)
> 2. Re: developpement: Modifying permission behavior and data
> visibility in Geonode (Ariel Nunez)
> 3. Re: developpement: Modifying permission behavior and data
> visibility in Geonode (Paolo Corti)
> Message: 1
> Date: Tue, 09 Jun 2015 16:56:18 +0400
> From: FERRARI Hugo <ferrari_hugo at yahoo.fr
> To: geonode-users at lists.osgeo.org
> Subject: [GeoNode-users] developpement: Modifying permission
> behavior
> and data visibility in Geonode
> Message-ID: <5576E272.6090606 at yahoo.fr
> <mailto:5576E272.6090606 at yahoo.fr>>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> Hello everyone,
> I have installed a complete geonode instance on a
> developpement server.
> I want to change thebehaviorofthesoftware to make it fit the
> need of
> the institution I work for.
> So i'm looking for some advices because I didn't manage to
> code it yet.
> My aim to separate metada access from the data access.
> That is to make all the layers uploaded in geoserver VISIBLE
> for all
> users (logged or not) but only in the layer-list page , not on the
> layer-detail page .
> If you click on any specific layer in the layer-list (or
> document-list
> because i want the same behavior for both), you get the layer
> detail so
> you what will see is:
> - In the case you have the view_resourcebase permission (who
> can see it
> ?), you will see the current template corresponding to
> layer_detail.html: both access to datas and metadatas.
> - In the other case if you don't have the view_resourcebase
> permission,
> you 'll only have access to metadatas's ressource (that means
> a template
> similar to layer_detail.html but Instead of the geoexplorer
> frame you
> sould have a "permission denied" message, but the possibility to
> retrieve metadata).
> It's quite simple to make all the layers visible in the layer
> list,
> whoever is logged in (you just have to modify
> SKIP_PERMS_FILTERS in
> settings.py AND read_list function in module
> api/authorisation.py).
> but the actual behavior is to catch a 403 http error when
> trying to view
> the layer detail.
> Modifying the 403.html template does not seems to be the good
> way to
> process.
> I don't think it is necessary to modify geonode's database
> model because
> the view_ressource permission is enough, considering that
> viewing the
> ressource is equivalent to having access to the data (even if
> you can't
> download it). There's no need to add a new kind of
> permissions, as far
> as I can guess.
> What is prefered is not throwing a 403 error but just the
> layer_detail.html template modified to get only metadatas.
> I hope the explanation was clear enough,
> Hugo FERRARI
> PS
> Does it correspond to the actual geonode developpement policy ?
> Datas and metada are strongly linked in this software.
> Could this functionnality be interresting for any other
> geonode users?
> Le 08/06/2015 23:00, geonode-users-request at lists.osgeo.org
> <mailto:geonode-users-request at lists.osgeo.org> a ?crit :
> specific
> Today's Topics:
> 1. Re: osgeo module install problem (Simone Dalmasso)
> 2. Problems to Translate Geonode - Transifex -
> Portuguese
> (Brazil) (Davi Custodio)
> 3. Re: Problems to Translate Geonode - Transifex -
> Portuguese
> (Brazil) (Julien Collaer)
> Message: 1
> Date: Sun, 7 Jun 2015 21:40:13 +0200
> From: Simone Dalmasso <simone.dalmasso at gmail.com
> <mailto:simone.dalmasso at gmail.com>>
> To: Vicente <deluca.vicente at gmail.com
> <mailto:deluca.vicente at gmail.com>>
> Cc: geonode-users <geonode-users at lists.osgeo.org
> <mailto:geonode-users at lists.osgeo.org>>
> Subject: Re: [GeoNode-users] osgeo module install problem
> Message-ID:
> <CAAHAC+cU9GgbBUe-ocH4GJZ1PaXEZDrY5W=ZCsTzSUSx5ymVvA at mail.gmail.com
> <mailto:ZCsTzSUSx5ymVvA at mail.gmail.com>>
> Content-Type: text/plain; charset="utf-8"
> Hi, you are missing the gdal python bindings, a "pip
> install gdal" should
> fix it.
> Hope it helps, ciao
> 2015-06-07 17:59 GMT+02:00 Vicente
> <deluca.vicente at gmail.com <mailto:deluca.vicente at gmail.com>>:
> Good afternoon,
> If I run the following line from my command line, the
> answer is successful
> $ sudo apt-get -y install libgdal1h libgdal-dev
> python-gdal
> But if I run from the session virtualenv, the answer
> is No module named
> osgeo.
> I have just added the following session variables in
> my .bashrc:
> export VIRTUALENVWRAPPER_PYTHON = / usr / bin / python
> export WORKON_HOME = ~ / .venvs
> source /usr/local/bin/virtualenvwrapper.sh
> export PIP_DOWNLOAD_CACHE = $ HOME / .pip-downloads
> Both session with virtualenv or outside, the python to
> run is the same,
> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
> The result is that I can not run because there is
> paver start the osgeo
> module from within the session obviously.
> Thanks!
> [image: MANTA] <http://www.estudiomanta.com/>
> Vicente Deluca
> *+54 11 6091 4579 <tel:%2B54%2011%206091%204579>
> <%2B54%2011%206091%204579>*
> Message: 2
> Date: Tue, 9 Jun 2015 09:01:34 -0500
> From: Ariel Nunez <ingenieroariel at gmail.com
> <mailto:ingenieroariel at gmail.com>>
> To: FERRARI Hugo <ferrari_hugo at yahoo.fr
> Cc: "geonode-users at lists.osgeo.org
> <mailto:geonode-users at lists.osgeo.org>"
> Subject: Re: [GeoNode-users] developpement: Modifying permission
> behavior and data visibility in Geonode
> Message-ID:
> <CALh6R-QDnFhFPgQdejPp0Kuh5NABLExo7ONaQWjhyb2hk3chEw at mail.gmail.com
> <mailto:CALh6R-QDnFhFPgQdejPp0Kuh5NABLExo7ONaQWjhyb2hk3chEw at mail.gmail.com>>
> Hugo,
> Based on what I understand, the best path forward is to have a
> view_metadata permission that you use to enforce the behavior
> you want.
> Assigning a new meaning to the existing permission may be
> problematic for
> other users with different needs (for example where metadata
> is sensitive
> information).
> The place where we want to get to, is to allow uploaders to
> restrict any
> actions they want, but give the end user buttons to request
> permissions (to
> view if they cannot view, to download if they can only view,
> to edit if the
> can only download) to encourage a conversation between
> uploaders and users
> and provide a workflow to allow access to information when it
> is needed.
> The changes you make would be good candidates for inclusion in
> the main
> version of GeoNode so others can benefit in the future.
> Hopefully others
> (Paolo?) can chime in with more specific feedback.
> Best,
> Ariel.
> On Tue, Jun 9, 2015 at 7:56 AM, FERRARI Hugo
> <ferrari_hugo at yahoo.fr <mailto:ferrari_hugo at yahoo.fr>> wrote:
> Hello everyone,
> the need of the
> to code it yet.
> VISIBLE for all
> not on the
> layer-detail page .
> document-list
> layer detail so you
> what will see is:
> (who can see it
> layer_detail.html:
> view_resourcebase permission,
> means a template
> geoexplorer frame you sould
> retrieve
> metadata).
> layer list,
> trying to view
> the layer detail.
> good way to
> process.
> model because
> that viewing the
> if you can't
> permissions, as far as I
> can guess.
> Hugo FERRARI
> PS
> policy ?
> geonode users?
> 'help' to
> more specific
> Today's Topics:
> Portuguese
> - Portuguese
> Message: 1
> Message-ID:
> fix it.
> Hope it helps, ciao
> Good afternoon,
> the answer is
> successful
> python-gdal
> answer is No module named
> osgeo.
> in my .bashrc:
> python to run is the same,
> Thanks!
> Vicente Deluca
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150609/4dbe42d3/attachment-0001.html>
> Message: 3
> Date: Tue, 9 Jun 2015 16:50:01 +0200
> From: Paolo Corti <pcorti at gmail.com <mailto:pcorti at gmail.com>>
> To: Ariel Nunez <ingenieroariel at gmail.com
> Cc: FERRARI Hugo <ferrari_hugo at yahoo.fr
> <mailto:ferrari_hugo at yahoo.fr>>,
> Message-ID:
> <CAHXrU-JBaUUQUBz7BjsNuTkmOpOSLB7rxAaXEt3Qsn1TmKmvqw at mail.gmail.com
> <mailto:CAHXrU-JBaUUQUBz7BjsNuTkmOpOSLB7rxAaXEt3Qsn1TmKmvqw at mail.gmail.com>>
> Content-Type: text/plain; charset=UTF-8
> Yes, Ariel is totally right.
> Currently we don't have a specific permission for viewing
> metadata.
> This is implicit with the view_resourcebase permission that gives
> access to the data and metadata at the same time.
> As suggested by Ariel you may consider to add a new django
> guardian
> permission at the resource base model, like it has been done
> here [1]
> and then have your GeoNode instance behaved according to it in
> views,
> templates and javascript.
> I don't think there is an easy way to avoid forking GeoNode and
> customize the beahviour in your GeoNode project, though it may
> be not
> impossible and this would keep your instance easily updateable
> with
> mainstream code.
> Even better, as Ariel suggested, you may though fork it and
> send a PR
> as it could be useful for others as well.
> regards
> p
> [1]
> https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L648
> On Tue, Jun 9, 2015 at 4:01 PM, Ariel Nunez
> <ingenieroariel at gmail.com <mailto:ingenieroariel at gmail.com>>
> wrote:
> Hugo,
> have a view_metadata
> permission that you use to enforce the behavior you want.
> Assigning a new
> meaning to the existing permission may be problematic for
> other users with
> different needs (for example where metadata is sensitive
> information).
> to restrict any
> request permissions (to
> view, to edit if the
> uploaders and users
> it is needed.
> inclusion in the main
> Hopefully others
> Best,
> Ariel.
> Hello everyone,
> fit the need of the
> manage to code it yet.
> VISIBLE for all
> , not on the
> layer-detail page .
> (or document-list
> the layer detail so you
> what will see is:
> permission (who can see it
> layer_detail.html:
> (that means a template
> possibility to retrieve
> metadata).
> the layer list,
> when trying to view
> the layer detail.
> the good way to
> process.
> database model because
> that viewing the
> (even if you can't
> can guess.
> Hugo FERRARI
> PS
> policy ?
> other geonode users?
> Web, visit
> 'help' to
> is more specific
> Today's Topics:
> Dalmasso)
> - Portuguese
> Transifex - Portuguese
> Message: 1
> problem
> Message-ID:
> "pip install gdal" should
> fix it.
> Hope it helps, ciao
> Good afternoon,
> line, the answer is
> successful
> libgdal-dev python-gdal
> osgeo.
> variables in my .bashrc:
> / python
> .pip-downloads
> is paver start the osgeo
> Thanks!
> Vicente Deluca
> *+54 11 6091 4579
> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/3faa2dc5/attachment-0001.html>
More information about the geonode-users
