[GeoNode-users] Help geonode on windows raster layer publish
Miguel-Angel Manso-Callejo (UPM)
m.manso at upm.es
Wed Jun 17 05:44:46 PDT 2015
Hello
I think that the style is not asigned by geoserver. In any where the
style file is created on-the-fly because none of the file have the
structure of the style generated for my raster layer in the publish process.
The problem is on geoserver importer plugin. When use it to publish make
a style with xml validations problems.
Best regards
Miguel A
El 17/06/2015 a las 14:02, Simone Dalmasso escribió:
> It is assigned by geoserver. You can edit it directly in geoserver ->
> styles tab.
> ps. please always write to the list instead of directly as others may
> benefit from this thread.
> Regards
> 2015-06-17 13:59 GMT+02:00 Miguel-Angel Manso-Callejo (UPM)
> <m.manso at upm.es <mailto:m.manso at upm.es>>:
> Hi Simone
> It is true. The style generated has issues.
> These style is copyed or created on the fly?
> How to or where modify to solve it?
> Regards
> Miguel A
> El 17/06/2015 a las 13:47, Simone Dalmasso escribió:
>> Hi seems to be an issue related to the layer style. Maybe the
>> default style has some issues.
>> 2015-06-17 13:36 GMT+02:00 Miguel-Angel Manso-Callejo (UPM)
>> Dear all,
>> I have problems to publish raster layer on geonode 2.4(b25
>> and early) in windows platform.
>> The file is published on geoserver (datastores, layer, style)
>> but in django geonode framework the process do not finish.
>> The log of apache web server is next.
>> Gdal is ok installed, and this not appear to be the problem.
>> Can any one help us to resolve this issue?
>> regards,
>> Miguel A. Manso
>> [Wed Jun 17 13:31:06.065807 2015] [wsgi:error] [pid 1504:tid
>> 1232] Traceback (most recent call last):
>> 1232] File "c:/GeoNode/GeoNode\\geonode\\upload\\views.py",
>> line 604, in view
>> 1232] resp = _steps[step](req, upload_session)
>> line 495, in final_step_view
>> 1232] saved_layer = upload.final_step(upload_session,
>> req.user)
>> 1232] File "c:/GeoNode/GeoNode\\geonode\\upload\\upload.py",
>> line 567, in final_step
>> 1232] defaults=defaults
>> 1232] File
>> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\manager.py",
>> line 154, in get_or_create
>> 1232] return self.get_queryset().get_or_create(**kwargs)
>> 1232] File
>> "c:\\GeoNode\\venv\\Lib\\site-packages\\modeltranslation\\manager.py",
>> line 341, in get_or_create
>> 1232] return super(MultilingualQuerySet,
>> self).get_or_create(**kwargs)
>> 1232] File
>> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\query.py",
>> line 383, in get_or_create
>> 1232] obj.save(force_insert=True, using=self.db)
>> 1232] File
>> "c:\\GeoNode\\venv\\Lib\\site-packages\\polymorphic\\polymorphic_model.py",
>> line 90, in save
>> 1232] return super(PolymorphicModel, self).save(*args,
>> **kwargs)
>> 1232] File
>> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\base.py",
>> line 545, in save
>> 1232] force_update=force_update, update_fields=update_fields)
>> 1232] File
>> line 582, in save_base
>> 1232] update_fields=update_fields, raw=raw, using=using)
>> 1232] File
>> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\dispatch\\dispatcher.py",
>> line 185, in send
>> 1232] response = receiver(signal=self, sender=sender,
>> **named)
>> 1232] File
>> "c:/GeoNode/GeoNode\\geonode\\geoserver\\signals.py", line
>> 465, in geoserver_post_save
>> 1232] set_styles(instance, gs_catalog)
>> 1232] File
>> "c:/GeoNode/GeoNode\\geonode\\geoserver\\helpers.py", line
>> 755, in set_styles
>> 1232] layer.default_style = save_style(default_style)
>> 1232] File
>> 770, in save_style
>> 1232] style.sld_title = gs_style.sld_title
>> 1232] File
>> "c:\\GeoNode\\venv\\Lib\\site-packages\\geoserver\\style.py",
>> line 49, in sld_title
>> 1232] title_node =
>> user_style.find("{http://www.opengis.net/sld}Title
>> <http://www.opengis.net/sld%7DTitle>")
>> 1232] AttributeError: 'NoneType' object has no attribute 'find'
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> <mailto:geonode-users at lists.osgeo.org>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/a8024a4b/attachment-0001.html>
More information about the geonode-users
