[GeoNode-users] Create new filter for layers
Paolo Corti
pcorti at gmail.com
Fri Jun 19 00:03:22 PDT 2015
Hi
nice customization.
What about creating your own TopicCategory model in a different application
with a one to one foreign key (or many to many one) to base ResourceBase?
This way you don't need to fork GeoNode, but just extend the template
regards
p
On Fri, Jun 19, 2015 at 12:19 AM, Melvin Ramos <melvin.ramos1991 at gmail.com>
wrote:
> Hello Simone,
> "You did well young padawan" (:
> Thanks. I just checked it out. In theory I replicated everything but still
> not working. I will go step by step like before:
> *Modified search_scripts.html in the search templates*
> I added this line of code:
> *IUCN_CATEGORIES_ENDPOINT = '{% url 'api_dispatch_list' api_name='api'
>> resource_name='iucn_categories' %}';*
> Just like the categories endpoint
> *Modified the search.js in the static folder*
> I added in the loaded section the following
>> * module.load_iucn_categories = function ($http, $rootScope, $location){*
>> * var params = typeof FILTER_TYPE == 'undefined' ? {} : {'type':
>> FILTER_TYPE};*
>> * if ($location.search().hasOwnProperty('title__icontains')){*
>> * params['title__icontains'] =
>> $location.search()['title__icontains'];*
>> * $http.get(IUCN_CATEGORIES_ENDPOINT, {params:
>> params}).success(function(data){*
>> if($location.search().hasOwnProperty('iucn_category__identifier__in')){*
>> * data.objects =
>> module.set_initial_filters_from_query(data.objects,*
>> * $location.search()['iucn_category__identifier__in'],
>> 'identifier');*
>> * $rootScope.categories = data.objects;*
>> * if (HAYSTACK_FACET_COUNTS && $rootScope.query_data) {*
>> * module.haystack_facets($http, $rootScope, $location);*
> Then I added in the module.haystack_facets the following
>> * if ("iucn_categories" in $rootScope) {*
>> * $rootScope.category_counts = data.meta.facets.category;*
>> * for (var id in $rootScope.categories) {*
>> * var category = $rootScope.categories[id];*
>> * if (category.identifier in $rootScope.category_counts) {*
>> * category.count =
>> $rootScope.category_counts[category.identifier]*
>> * } else {*
>> * category.count = 0;*
> Finally, in the module.run I added this
>> * if ($('#iucn_categories').length > 0){*
>> * module.load_categories($http, $rootScope, $location);** }*
> But it didn't work, still shows nothing on the template.What am I missing??
> Thanks in advance,
> Melvin
> Enviado con MailTrack
> <https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
> 2015-06-18 17:01 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Melvin,
>> you did well, the only missing thing is here
>> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/search/search.js,
>> javascript part that loads the categories through the api and compiles the
>> query.
>> Ciao
>> 2015-06-18 23:17 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com>:
>>> Hello,
>>> I'm trying to duplicate the Categories filter, because I'm need to use a
>>> new set of categories for my layers, but I'm having a hard time trying to
>>> find out how the templates gets the data since it uses AngularJS.
>>> So here is what I''ve done so far:
>>> *Modified the models.py of the Base app*
>>> I added a new class called IUCNCategory
>>>> *class IUCNCategory(models.Model): """ Metadata regarding IUCN
>>>> standards """ identifier = models.CharField(max_length=255)
>>>> category_type = models.CharField( choices=(
>>>> ('risk_criteria', 'Risk Criteria'), ('bio_realm',
>>>> 'Biogeographical Realm'), ('typology', 'Typology') ),
>>>> max_length=255, ) description = models.TextField(default='')
>>>> gn_description = models.TextField('RLE description', default='',
>>>> null=True) # is_choice = models.BooleanField(default=True) def
>>>> __unicode__(self): return u"{0}".format(self.gn_description)
>>>> class Meta: ordering = ("category_type","identifier",)
>>>> verbose_name_plural = 'IUCN Categories'*
>>> It's just like TopicCategory with one different attribute.
>>> I added to the class ResourceBase the following attribute
>>> *iucn_category = models.ForeignKey(IUCNCategory, null=True, blank=True)*
>>> *Modified the api.py **of the Api app*
>>> I created a new class called IUCNCategoryResource
>>>> *class IUCNCategoryResource(TypeFilteredResource):** """IUCN
>>>> Category api"""*
>>>> * def serialize(self, request, data, format, options={}):**
>>>> options['count_type'] = 'iucn_category'*
>>>> * return super(IUCNCategoryResource, self).serialize(request,
>>>> data, format, options)*
>>>> * class Meta:*
>>>> * queryset = IUCNCategory.objects.all()*
>>>> * resource_name = 'iucn_categories'*
>>>> * allowed_methods = ['get']*
>>>> * filtering = {*
>>>> * 'identifier': ALL,*
>>>> * }** serializer = CountJSONSerializer()*
>>> It's like the class TopicCategoryResource
>>> *Modified the* *resourcebase_api.py **of the Api app*
>>> I added to the class CommonModelApi the following attribute
>>>> *iucn_category = fields.ToOneField( IUCNCategoryResource,
>>>> 'iucn_category', null=True, full=True)*
>>> In the definition on the Haystack filters I added the following in the
>>> proper places:
>>>> *...iucn_category =
>>>> parameters.getlist("iucn_category__identifier__in")...if iucn_category:
>>>> sqs = (SearchQuerySet() if sqs is None else sqs).narrow(
>>>> 'iucn_category:%s' % ','.join(map(str, iucn_category)))...*
>>> Just like the category field.
>>> *Modified the** urls**.py **of the Api app*
>>> I imported the IUCNCategoryResource from the apy.py and wrote
>>> *api.register(IUCNCategoryResource())*
>>> *Modified the template _general_filters.html inside the search templates*
>>> I added the following code
>>>> *<nav class="filter">*
>>>> * <h4><a href="#" class="toggle toggle-nav"><i class="fa
>>>> fa-chevron-right"></i>{% trans "Risk Criteria" %}</a></h4>*
>>>> * <ul class="nav closed" id="iucn_categories">*
>>>> * {% verbatim %}*
>>>> * <li ng-repeat="iucn_category in iucn_categories"
>>>> ng-if="iucn_category.count > 0">*
>>>> * <a data-value="{{ iucn_category.identifier }}"
>>>> data-filter="iucn_category__identifier__in" *
>>>> * ng-click="multiple_choice_listener($event)"
>>>> class="{{iucn_category.active}}">{{ iucn_category.gn_description | limitTo:
>>>> 25 }}{{ iucn_category.gn_description.length > 25 ? '...' : ''}}*
>>>> * <span class="badge pull-right">{{ iucn_category.count
>>>> }}</span>*
>>>> * </a>*
>>>> * </li>*
>>>> * {% endverbatim %}*
>>>> * </ul>**</nav>*
>>> But nothing shows beneath the filter name in the template, even when I
>>> have one IUCN category stored in database. I'm guessing there is a view
>>> somewhere or I'm missing something that allows to pass the data and I can't
>>> find it or just Angular is too mystic for me.
>>> Can anybody help me?
>>> Thanks in advance,
>>> Melvin
>>> Melvin David Ramos Macías
>>> 07-41408
>>> Ingeniería de Computación
>>> Universidad Simón Bolívar
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
> 07-41408
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150619/97020d1e/attachment.html>
More information about the geonode-users
