[GeoNode-users] Fwd: Re: modifying the layer list request
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jun 19 07:02:44 PDT 2015
Very useful Hugo, also for the list. Glad you solved. The only advice, in
case the api response gets slow is to reduce the numbers of the results per
query.
Ciao
2015-06-19 15:55 GMT+02:00 FERRARI Hugo <ferrari_hugo at yahoo.fr>:
> The simplest and less "resource-consuming" way I finally found is
> In resourcebase_api, create_response()
> Just make an other guardian query (get_objects_for_user) to get resource
> ids that the user can download.
> then I iterate over the complete list of objects already stores in
> data['objects'] variable, and add a single field in each json object to
> indicate if user can download resource or not.
> It fits to my needs and it's only one more query on the DB.
> Thanks again
> Hugo
> Ps: i don't know if this kind of message has to be shared as it is a very
> particular developement problem. please tell me if it is not the case.
> -------- Message transféré -------- Sujet : Re: [GeoNode-users]
> modifying the layer list request Date : Fri, 19 Jun 2015 08:45:15 +0200 De :
> Simone Dalmasso <simone.dalmasso at gmail.com> <simone.dalmasso at gmail.com> Pour :
> FERRARI Hugo <ferrari_hugo at yahoo.fr> <ferrari_hugo at yahoo.fr> Copie à :
> geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
> The query on the cb should be more or less ok. The big difference is that
> it's fetching all the data a user has permission then dumps them in bulk.
> In your case it will fetch all the data then loop over each of them to see
> whether the user has permission or not and add a "permitted " field on the
> API on the fly. That loop is what we avoided by customizing the API.
> Il venerdì 19 giugno 2015, FERRARI Hugo <ferrari_hugo at yahoo.fr> ha
> scritto:
>> It works pretty well the way I did, but I understand the problem.
>> There is no perfomance decrease yet it is probably because i'm in the
>> developpement stage with few users, not in production.
>> When you say it slows down the API, is it because it produces many more
>> SQL requests on the DB ?
>> (ie Having a first result from the db, then making new queries to obtain
>> the user-resource-permision value)
>> Can a solution be to build a raw SQL query
>> <https://docs.djangoproject.com/en/1.8/topics/db/sql/> a bit more
>> complex ?
>> create a special view with a join between user, resource and perms then
>> request it... only reading it, never write.
>> Thanks
>> Le 18/06/2015 17:09, Simone Dalmasso a écrit :
>> Hi Hugo,
>> the "easies" way would be to create a dedicated API for non permitted
>> resources that is used in a separate tab in the search pages dedicate to
>> resources that are in GeoNode but the user does not have the permission to
>> view.
>> The reasons behind that are:
>> - The current api, for performances purpose, do not loop over each result
>> in any way, they just take the data from the db, apply filters, then send
>> to the client. If you have to distinguish between permitted and not
>> permitted then you have to add back the post processing that will slow down
>> the API. Better have a dedicated API to this task.
>> - In the client side, there's Angular.js that renders the resources and
>> even if the angular tags look the same as the django ones {{tag}} they are
>> actually rendered by Angular. The _resourcebase_snippet works this way, so
>> you cannot use django template tags in there.
>> If you create a separate tab you can use the same logic both on the
>> client and on the server with just a different api endpoint at the price of
>> not having the results mixed in the same list.
>> If you decide to activate the API post processing (dehidratation cycle)
>> then try to keep it as light as possible otherwise the performances will
>> drop especially if you visualize many data all together.
>> 2015-06-18 13:38 GMT+02:00 FERRARI Hugo <ferrari_hugo at yahoo.fr>:
>>> Hello everyone
>>> I've modified geonode behavior to make every user (logged or not) to
>>> view the complete list of the resources stored in geoserver and geonode
>>> store, and the ability to download the metadatas.
>>> Then I add some restrictions to allow only a few users to explore it:
>>> what I mean by "exploring it" is displaying the geoexplorer frame for
>>> layers and giving auth to download it.
>>> the aim is to show users the whole catalog first, and e-mail the Point
>>> of Contact if a resource cannot be retrivied because of restriction.
>>> To improve the user experience I want to make a distinction on resource
>>> lists:
>>> when a resource is only "viewable" (ie displayed in the list but with no
>>> permision to download it),
>>> it displays a "restricted access" message in the resource-base-snippet
>>> template, near the MD infos and thumbnail.
>>> So the user will be aware that he has no right to retrieve it directly
>>> without contact the PoC.
>>> To do that I modify JSON answer from the server when we ask him to get
>>> the list of available resources:
>>> the answer is built in create_response method from CommonModelApi in api
>>> module.
>>> We can see that a single resource retrieved from the db is sent back
>>> with some Metadata-fields.
>>> I just want to put a single boolean that will tell if user has the right
>>> to download it.
>>> I have already written the short function to get this boolean, but as a
>>> template tag, used in the resources detail templates.
>>> So i 'll have to write an other function to use it the python module.
>>> It will produce duplicate code.
>>> Do you have some advice to do it in a better way ?
>>> Thanks,
>>> Hugo FERRARI
>>> Le 17/06/2015 23:00, geonode-users-request at lists.osgeo.org a écrit :
>>>> Send geonode-users mailing list submissions to
>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> or, via email, send a message with subject or body 'help' to
>>>> You can reach the person managing the list at
>>>> geonode-users-owner at lists.osgeo.org
>>>> When replying, please edit your Subject line so it is more specific
>>>> than "Re: Contents of geonode-users digest..."
>>>> Today's Topics:
>>>> 1. Cannot find /var/lib/geonode/ to get templates (William Francis)
>>>> 2. Re: Query on a medium sized postgis table layer takes forever
>>>> on 2.4b25 (Paolo Corti)
>>>> 3. Implementing GeoNode for University (Florian Hoedt)
>>>> 4. Re: Query on a medium sized postgis table layer takes forever
>>>> on 2.4b25 (Francesco Bartoli)
>>>> 5. Bad Thumbnail png files (Miguel-Angel Manso-Callejo (UPM))
>>>> 6. Re: Bad Thumbnail png files (Simone Dalmasso)
>>>> Message: 1
>>>> Date: Wed, 17 Jun 2015 19:24:51 +0630
>>>> From: William Francis <william.francis.james at gmail.com>
>>>> To: geonode-users at lists.osgeo.org
>>>> Subject: [GeoNode-users] Cannot find /var/lib/geonode/ to get
>>>> templates
>>>> Message-ID:
>>>> CAD0vh4b+a6wKWaLRO-XcFxJB5ccGmfHLpbpSAXtp5p3VAs2k6g at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Hello,
>>>> I am following the Customizing the geonode instructions and looking for
>>>> the
>>>> template files to copy to etc/geonode/templates
>>>> e.g.
>>>> /var/lib/geonode/src/GeoNodePy/geonode/templates/index.html
>>>> However the directory /var/lib/geonode/ doesn't exist.
>>>> Where can I find a copy of these templates?
>>>> I am using v*ersion 2.4b25* of geonode.
>>>> Thank you.
>>>> Will
>>>> -------------- next part --------------
>>>> An HTML attachment was scrubbed...
>>>> URL: <
>>>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/e56cd76e/attachment-0001.html
>>>> Message: 2
>>>> Date: Wed, 17 Jun 2015 15:36:35 +0200
>>>> From: Paolo Corti <pcorti at gmail.com>
>>>> To: Rainer Lissewski <rainerlissewski at gmail.com>
>>>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>>>> Subject: Re: [GeoNode-users] Query on a medium sized postgis table
>>>> layer takes forever on 2.4b25
>>>> Message-ID:
>>>> CAHXrU-Jo1L19VAFGZyS+i6WYMm2wtO693KTjBw6F18OqAzCkzA at mail.gmail.com>
>>>> Content-Type: text/plain; charset=UTF-8
>>>> On Wed, Jun 17, 2015 at 2:30 PM, Rainer Lissewski
>>>> <rainerlissewski at gmail.com> wrote:
>>>>> Hi, in the map view, I have tried to query a single attribute value
>>>>> (varchar) from a layer with about 5000 rows, and it has been running
>>>>> over an
>>>>> hour now, with no result. If someone can guide me where to look for the
>>>>> possible culprit (geoserver, django,...), I would gladly take any hints
>>>>> Things I would check (in this order):
>>>> * response to the getfeatureinfo request using your browser debug
>>>> toolbar
>>>> * geoserver log
>>>> * try the query in postgis and check it using EXPLAIN
>>>> regards
>>>> p
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150619/d1378b01/attachment-0001.html>
More information about the geonode-users
