[GeoNode-users] Create new filter for layers
Melvin Ramos
melvin.ramos1991 at gmail.com
Sat Jun 20 13:32:00 PDT 2015
I'm guessing you are saying this:
module.load_categories = function ($http, $rootScope, $location){
> var params = typeof FILTER_TYPE == 'undefined' ? {} : {'type':
> FILTER_TYPE};
> if ($location.search().hasOwnProperty('title__icontains')){
> params['title__icontains'] =
> $location.search()['title__icontains'];
> $http.get(CATEGORIES_ENDPOINT, {params:
> params}).success(function(data){
> if($location.search().hasOwnProperty('category__identifier__in')){
> data.objects =
> module.set_initial_filters_from_query(data.objects,
> $location.search()['category__identifier__in'],
> 'identifier');
> $rootScope.categories = data.objects;
> if (HAYSTACK_FACET_COUNTS && $rootScope.query_data) {
> module.haystack_facets($http, $rootScope, $location);
> $http.get(IUCN_CATEGORIES_ENDPOINT, {params:
> if($location.search().hasOwnProperty('iucn_category__identifier__in')){
> data.objects =
> $location.search()['iucn_category__identifier__in'],
> 'identifier');
> $rootScope.iucn_categories = data.objects;
where I should also write this:
if ($('#categories').length > 0 && $('#iucn_categories').length > 0){
> module.load_categories($http, $rootScope, $location);
But it doesn't work either way. I was sort of debugging this and I found
out that the rootScope Object is showing that iucn_categories is an
Array[0] against categories (Array[19]). I guess that says that the query
is not getting anything or something but I have no idea where I can check
this
Enviado con MailTrack
<https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
2015-06-19 2:29 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com>:
> One issue is in the first part of the js. Module.load-ounce-categories.
> Despite the name the original function is used to load also the keywords
> etc. so instead or rewrite the entire function just add the chunk $http.get
> for your categories into the original module.load-categories.
> That should help. :)
> Il venerdì 19 giugno 2015, Melvin Ramos <melvin.ramos1991 at gmail.com> ha
> scritto:
>> Hello Simone,
>> "You did well young padawan" (:
>> Thanks. I just checked it out. In theory I replicated everything but
>> still not working. I will go step by step like before:
>> *Modified search_scripts.html in the search templates*
>> I added this line of code:
>> *IUCN_CATEGORIES_ENDPOINT = '{% url 'api_dispatch_list' api_name='api'
>>> resource_name='iucn_categories' %}';*
>> Just like the categories endpoint
>> *Modified the search.js in the static folder*
>> I added in the loaded section the following
>>> * module.load_iucn_categories = function ($http, $rootScope,
>>> $location){*
>>> * var params = typeof FILTER_TYPE == 'undefined' ? {} : {'type':
>>> FILTER_TYPE};*
>>> * if ($location.search().hasOwnProperty('title__icontains')){*
>>> * params['title__icontains'] =
>>> $location.search()['title__icontains'];*
>>> * $http.get(IUCN_CATEGORIES_ENDPOINT, {params:
>>> params}).success(function(data){*
>>> if($location.search().hasOwnProperty('iucn_category__identifier__in')){*
>>> * data.objects =
>>> module.set_initial_filters_from_query(data.objects,*
>>> $location.search()['iucn_category__identifier__in'], 'identifier');*
>>> * $rootScope.categories = data.objects;*
>>> * if (HAYSTACK_FACET_COUNTS && $rootScope.query_data) {*
>>> * module.haystack_facets($http, $rootScope, $location);*
>> Then I added in the module.haystack_facets the following
>>> * if ("iucn_categories" in $rootScope) {*
>>> * $rootScope.category_counts = data.meta.facets.category;*
>>> * for (var id in $rootScope.categories) {*
>>> * var category = $rootScope.categories[id];*
>>> * if (category.identifier in $rootScope.category_counts) {*
>>> * category.count =
>>> $rootScope.category_counts[category.identifier]*
>>> * } else {*
>>> * category.count = 0;*
>> Finally, in the module.run I added this
>>> * if ($('#iucn_categories').length > 0){*
>>> * module.load_categories($http, $rootScope, $location);** }*
>> But it didn't work, still shows nothing on the template.What am I
>> missing??
>> Thanks in advance,
>> Melvin
>> 2015-06-18 17:01 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi Melvin,
>>> you did well, the only missing thing is here
>>> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/search/search.js,
>>> javascript part that loads the categories through the api and compiles the
>>> query.
>>> Ciao
>>> 2015-06-18 23:17 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com>:
>>>> Hello,
>>>> I'm trying to duplicate the Categories filter, because I'm need to use
>>>> a new set of categories for my layers, but I'm having a hard time trying to
>>>> find out how the templates gets the data since it uses AngularJS.
>>>> So here is what I''ve done so far:
>>>> *Modified the models.py of the Base app*
>>>> I added a new class called IUCNCategory
>>>>> *class IUCNCategory(models.Model): """ Metadata regarding IUCN
>>>>> standards """ identifier = models.CharField(max_length=255)
>>>>> category_type = models.CharField( choices=(
>>>>> ('risk_criteria', 'Risk Criteria'), ('bio_realm',
>>>>> 'Biogeographical Realm'), ('typology', 'Typology') ),
>>>>> max_length=255, ) description = models.TextField(default='')
>>>>> gn_description = models.TextField('RLE description', default='',
>>>>> null=True) # is_choice = models.BooleanField(default=True) def
>>>>> __unicode__(self): return u"{0}".format(self.gn_description)
>>>>> class Meta: ordering = ("category_type","identifier",)
>>>>> verbose_name_plural = 'IUCN Categories'*
>>>> It's just like TopicCategory with one different attribute.
>>>> I added to the class ResourceBase the following attribute
>>>> *iucn_category = models.ForeignKey(IUCNCategory, null=True, blank=True)*
>>>> *Modified the api.py **of the Api app*
>>>> I created a new class called IUCNCategoryResource
>>>>> *class IUCNCategoryResource(TypeFilteredResource):** """IUCN
>>>>> Category api"""*
>>>>> * def serialize(self, request, data, format, options={}):**
>>>>> options['count_type'] = 'iucn_category'*
>>>>> * return super(IUCNCategoryResource, self).serialize(request,
>>>>> data, format, options)*
>>>>> * class Meta:*
>>>>> * queryset = IUCNCategory.objects.all()*
>>>>> * resource_name = 'iucn_categories'*
>>>>> * allowed_methods = ['get']*
>>>>> * filtering = {*
>>>>> * 'identifier': ALL,*
>>>>> * }** serializer = CountJSONSerializer()*
>>>> It's like the class TopicCategoryResource
>>>> *Modified the* *resourcebase_api.py **of the Api app*
>>>> I added to the class CommonModelApi the following attribute
>>>>> *iucn_category = fields.ToOneField( IUCNCategoryResource,
>>>>> 'iucn_category', null=True, full=True)*
>>>> In the definition on the Haystack filters I added the following in the
>>>> proper places:
>>>>> *...iucn_category =
>>>>> parameters.getlist("iucn_category__identifier__in")...if iucn_category:
>>>>> sqs = (SearchQuerySet() if sqs is None else sqs).narrow(
>>>>> 'iucn_category:%s' % ','.join(map(str, iucn_category)))...*
>>>> Just like the category field.
>>>> *Modified the** urls**.py **of the Api app*
>>>> I imported the IUCNCategoryResource from the apy.py and wrote
>>>> *api.register(IUCNCategoryResource())*
>>>> *Modified the template _general_filters.html inside the search
>>>> templates*
>>>> I added the following code
>>>>> *<nav class="filter">*
>>>>> * <h4><a href="#" class="toggle toggle-nav"><i class="fa
>>>>> fa-chevron-right"></i>{% trans "Risk Criteria" %}</a></h4>*
>>>>> * <ul class="nav closed" id="iucn_categories">*
>>>>> * {% verbatim %}*
>>>>> * <li ng-repeat="iucn_category in iucn_categories"
>>>>> ng-if="iucn_category.count > 0">*
>>>>> * <a data-value="{{ iucn_category.identifier }}"
>>>>> data-filter="iucn_category__identifier__in" *
>>>>> * ng-click="multiple_choice_listener($event)"
>>>>> class="{{iucn_category.active}}">{{ iucn_category.gn_description | limitTo:
>>>>> 25 }}{{ iucn_category.gn_description.length > 25 ? '...' : ''}}*
>>>>> * <span class="badge pull-right">{{ iucn_category.count
>>>>> }}</span>*
>>>>> * </a>*
>>>>> * </li>*
>>>>> * {% endverbatim %}*
>>>>> * </ul>**</nav>*
>>>> But nothing shows beneath the filter name in the template, even when I
>>>> have one IUCN category stored in database. I'm guessing there is a view
>>>> somewhere or I'm missing something that allows to pass the data and I can't
>>>> find it or just Angular is too mystic for me.
>>>> Can anybody help me?
>>>> Thanks in advance,
>>>> Melvin
>>>> Melvin David Ramos Macías
>>>> 07-41408
>>>> Ingeniería de Computación
>>>> Universidad Simón Bolívar
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Simone
>> 07-41408
> Simone
07-41408
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150620/bb8c2ae3/attachment-0001.html>
More information about the geonode-users
