[GeoNode-users] Get Remote Service (harvest CSW); add external WMS to Base Maps list
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jun 24 05:52:12 PDT 2015
Hi, the configuration in the settings that you did is not to register a
remote service but is to use geonetwork as default catalogue instead of
pycsw. GeoNode will treat it as a metadata catalogue and not as a data
repository, the data are in postgis + geoserver.
In any case there is no need to put it in the allowed hosts.
If you want to register a remote service the you need to add only the csw
backend http://geoportal.geodaten.niedersachsen.de/harvest/srv/ger/csw
which works on demo.geonode.org although is empty.
Hope this helps
2015-06-23 16:52 GMT+02:00 Florian Hoedt <florian.hoedt at hs-owl.de>:
> Hello,
> I did not get any answers to my questions below. Is something unclear? Are
> those uncommon issues?
> Questions:
> [1] Get remote Services – harvest a CSW
> [2] ArcGIS WMS as Base Map in GeoNode
> *[1] Get remote Services – harvest a CSW:*
> I have changed my
> Local_settings.py to switch to our GeoNetwork instance which is on a
> different machine (Windwos Server with ArcGIS Server) since I thought
> GeoNode would load the data which is stored in there (*but it does not*):
> CATALOGUE = {
> 'default': {
> # The underlying CSW backend
> # ("pycsw_http", "pycsw_local", "geonetwork", "deegree")
> #'ENGINE': 'geonode.catalogue.backends.pycsw_local',
> # The FULLY QUALIFIED base url to the CSW instance for this GeoNode
> #'URL': '%scatalogue/csw' % SITEURL,
> # GeoNetwork opensource
> 'ENGINE': 'geonode.catalogue.backends.geonetwork',
> 'URL': 'http://gissrv.aes.hs-owl.de:8080/geonetwork/srv/en/csw',
> 'USER': 'admin',
> 'PASSWORD': 'AwesomePassword',
> I have added some entries to ALLOWED_HOSTS, but am not quite shure if
> these are correct:
> # For more information on available settings please consult the Django
> docs at
> # https://docs.djangoproject.com/en/dev/ref/settings
> ALLOWED_HOSTS=['localhost', 'geonode.aes.hs-owl.de','.hs-owl.de','*']
> PROXY_ALLOWED_HOSTS=['*', 'localhost']
> Since I still am not able to harvest a REMOTE CSW with the following
> settings:
> SERVICE URL:
> http://geoportal.geodaten.niedersachsen.de/harvest/srv/ger/csw?SERVICE=CSW&VERSION=2.0.2&REQUEST=GetCapabilities
> SERVICE TYPE:
> Calalogue Service
> *Internal Server Error*
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator at webmaster at localhost to inform
> them of the time this error occurred, and the actions you performed just
> before this error.
> More information about this error may be available in the server error
> log.
> *Apache/2.4.7 (Ubuntu) Server at geonode.aes.hs-owl.de
> <http://geonode.aes.hs-owl.de> Port 80*
> *ErrorLog:*
> [Thu Jun 18 05:20:58.600426 2015] [:error] [pid 8795] Internal Server
> Error: /services/register/
> [Thu Jun 18 05:20:58.600469 2015] [:error] [pid 8795] Traceback (most
> recent call last):
> [Thu Jun 18 05:20:58.600474 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112,
> in get_response
> [Thu Jun 18 05:20:58.600479 2015] [:error] [pid 8795] response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Thu Jun 18 05:20:58.600484 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/dist-packages/django/contrib/auth/decorators.py", line
> 22, in _wrapped_view
> [Thu Jun 18 05:20:58.600489 2015] [:error] [pid 8795] return
> view_func(request, *args, **kwargs)
> [Thu Jun 18 05:20:58.600493 2015] [:error] [pid 8795] File
> "/usr/local/lib/python2.7/dist-packages/geonode/services/views.py", line
> 127, in register_service
> [Thu Jun 18 05:20:58.600498 2015] [:error] [pid 8795] return
> _register_harvested_service(url, name, user, password, owner=request.user)
> [Thu Jun 18 05:20:58.600502 2015] [:error] [pid 8795] File
> 698, in _register_harvested_service
> [Thu Jun 18 05:20:58.600507 2015] [:error] [pid 8795] csw =
> CatalogueServiceWeb(url)
> [Thu Jun 18 05:20:58.600511 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 80, in __init__
> [Thu Jun 18 05:20:58.600515 2015] [:error] [pid 8795] self._invoke()
> [Thu Jun 18 05:20:58.600520 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/dist-packages/owslib/csw.py", line 598, in _invoke
> [Thu Jun 18 05:20:58.600533 2015] [:error] [pid 8795] self.response =
> urlopen(req, timeout=self.timeout).read()
> [Thu Jun 18 05:20:58.600537 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/urllib2.py", line 127, in urlopen
> [Thu Jun 18 05:20:58.600542 2015] [:error] [pid 8795] return
> _opener.open(url, data, timeout)
> [Thu Jun 18 05:20:58.600546 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/urllib2.py", line 404, in open
> [Thu Jun 18 05:20:58.600550 2015] [:error] [pid 8795] response =
> self._open(req, data)
> [Thu Jun 18 05:20:58.600553 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/urllib2.py", line 422, in _open
> [Thu Jun 18 05:20:58.600557 2015] [:error] [pid 8795] '_open', req)
> [Thu Jun 18 05:20:58.600561 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/urllib2.py", line 382, in _call_chain
> [Thu Jun 18 05:20:58.600565 2015] [:error] [pid 8795] result =
> func(*args)
> [Thu Jun 18 05:20:58.600569 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/urllib2.py", line 1214, in http_open
> [Thu Jun 18 05:20:58.600573 2015] [:error] [pid 8795] return
> self.do_open(httplib.HTTPConnection, req)
> [Thu Jun 18 05:20:58.600577 2015] [:error] [pid 8795] File
> "/usr/lib/python2.7/urllib2.py", line 1184, in do_open
> [Thu Jun 18 05:20:58.600581 2015] [:error] [pid 8795] raise
> URLError(err)
> [Thu Jun 18 05:20:58.600584 2015] [:error] [pid 8795] URLError: <urlopen
> error [Errno 111] Connection refused>
> [Thu Jun 18 05:20:58.670305 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] mod_wsgi (pid=8795): Exception occurred processing
> WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
> [Thu Jun 18 05:20:58.670344 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] Traceback (most recent call last):
> [Thu Jun 18 05:20:58.670368 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] File
> "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206,
> in __call__
> [Thu Jun 18 05:20:58.670512 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] response = self.get_response(request)
> [Thu Jun 18 05:20:58.670531 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194,
> in get_response
> [Thu Jun 18 05:20:58.670557 2015] [:error] [pid 8795] [remote
> self.handle_uncaught_exception(request, resolver, sys.exc_info())
> [Thu Jun 18 05:20:58.670583 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236,
> in handle_uncaught_exception
> [Thu Jun 18 05:20:58.670604 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] return callback(request, **param_dict)
> [Thu Jun 18 05:20:58.670619 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in
> _wrapped_view
> [Thu Jun 18 05:20:58.670703 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] response = view_func(request, *args, **kwargs)
> [Thu Jun 18 05:20:58.670720 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/views/defaults.py", line 46, in
> server_error
> [Thu Jun 18 05:20:58.670785 2015] [:error] [pid 8795] [remote
> http.HttpResponseServerError(template.render(Context({})))
> [Thu Jun 18 05:20:58.670801 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 140, in
> render
> [Thu Jun 18 05:20:58.671217 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] return self._render(context)
> [Thu Jun 18 05:20:58.671237 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 134, in
> _render
> [Thu Jun 18 05:20:58.671260 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] return self.nodelist.render(context)
> [Thu Jun 18 05:20:58.671275 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 840, in
> render
> [Thu Jun 18 05:20:58.671306 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] bit = self.render_node(node, context)
> [Thu Jun 18 05:20:58.671320 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 854, in
> render_node
> [Thu Jun 18 05:20:58.671337 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] return node.render(context)
> [Thu Jun 18 05:20:58.671352 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 53,
> in render
> [Thu Jun 18 05:20:58.671461 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] result = self.nodelist.render(context)
> [Thu Jun 18 05:20:58.671478 2015] [:error] [pid 8795] [remote
> render
> [Thu Jun 18 05:20:58.671499 2015] [:error] [pid 8795] [remote
> [Thu Jun 18 05:20:58.671511 2015] [:error] [pid 8795] [remote
> render_node
> [Thu Jun 18 05:20:58.671529 2015] [:error] [pid 8795] [remote
> [Thu Jun 18 05:20:58.671541 2015] [:error] [pid 8795] [remote
> 155, in render
> [Thu Jun 18 05:20:58.671559 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] return self.render_template(self.template,
> context)
> [Thu Jun 18 05:20:58.671571 2015] [:error] [pid 8795] [remote
> 137, in render_template
> [Thu Jun 18 05:20:58.671588 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] output = template.render(context)
> [Thu Jun 18 05:20:58.671599 2015] [:error] [pid 8795] [remote
> render
> [Thu Jun 18 05:20:58.671616 2015] [:error] [pid 8795] [remote
> [Thu Jun 18 05:20:58.671628 2015] [:error] [pid 8795] [remote
> _render
> [Thu Jun 18 05:20:58.671644 2015] [:error] [pid 8795] [remote
> [Thu Jun 18 05:20:58.671655 2015] [:error] [pid 8795] [remote
> render
> [Thu Jun 18 05:20:58.671671 2015] [:error] [pid 8795] [remote
> [Thu Jun 18 05:20:58.671683 2015] [:error] [pid 8795] [remote
> render_node
> [Thu Jun 18 05:20:58.671699 2015] [:error] [pid 8795] [remote
> [Thu Jun 18 05:20:58.671711 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py",
> line 24, in render
> [Thu Jun 18 05:20:58.671771 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] request = context["request"]
> [Thu Jun 18 05:20:58.671789 2015] [:error] [pid 8795] [remote
> "/usr/lib/python2.7/dist-packages/django/template/context.py", line 56, in
> __getitem__
> [Thu Jun 18 05:20:58.671871 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] raise KeyError(key)
> [Thu Jun 18 05:20:58.671894 2015] [:error] [pid 8795] [remote
> 193.16.120.81:5732] KeyError: 'request'
> *[2] **ArcGIS WMS as Base Map in GeoNode *
> I managed to achieve this by using a *cascaded WMS from Geonodes
> Geoserver instance*. I can query the geoserver and add the wms to my map
> as layer.
> *How to get it displayed in the list of basemaps?*
> mit freundlichen Grüßen
> Florian Hoedt
> B.Sc. Florian Hoedt
> Hochschule Ostwestfalen-Lippe / Campus Höxter
> FB 9 Landschaftsarchitektur und Umweltplanung
> An der Wilhelmshöhe 44
> 37671 Höxter
> Tel.: 05271-687-7478
> E-Mail: florian.hoedt at hs-owl.de
> www.hs-owl.de/fb9
> *Von:* GC-54 [mailto:nepanode at gmail.com <nepanode at gmail.com>]
> *Gesendet:* Donnerstag, 18. Juni 2015 00:04
> *An:* Florian Hoedt
> *Cc:* geonode-users at lists.osgeo.org
> *Betreff:* Re: [GeoNode-users] Implementing GeoNode for University
> Geonode 2.4 beta has "remote services" feature which allows admins to
> register remote WMS/ESRI REST/CSW services from the admin menu... I'd
> suggest this for the #1 but know the limitations -
> https://github.com/GeoNode/geonode/issues/2064.
> For #2 I'd suggest putting in a wildcard for allowed proxy while testing
> out in your local_settings.py file within your geonode_project:
> When ready for production you'll want to enter each IP address
> ['192.168.1.1', '_________', 'localhost'] of the servers you'll be
> registering remote services from. Do you have access over these ArcGIS
> servers? if so I'd suggest enabling their WMS service for each resource
> your'e registering and setting its default projection to ESPG:3857. That
> way legend/getfeatureinfo/query will work for those services when
> registered remotely. Otherwise all you'll get from registering from ESRI
> REST is the map export which is essentially a tiling service.
> On Wed, Jun 17, 2015 at 9:33 AM, Florian Hoedt <florian.hoedt at hs-owl.de>
> wrote:
> Hello Internet,
> Thanks for the variety of info about the usefullnes of Geonode for an
> organisation like my university!
> I spent the last couple of days to install geonode on a server and am able
> to get to the web interface. Some things bother me though:
> 1. How can I harvest other CSW? I have a GeoNetwork running which does an
> excellent job there - is it possible to just use that as input for geonode?
> 2. I want to add our ArcGIS Server with its REST point to the list of
> servers, so the users could use the add layer button from the map view to
> query the datasets there. But I get this error:
> *>> DEBUG is set to False but the host of the path provided to the proxy
> service is not in the PROXY_ALLOWED_HOSTS setting*
> Seems like I should change some settings.
> Thanks in advance
> Florian Hoedt
> B.Sc. Florian Hoedt
> 37671 Höxter
> www.hs-owl.de/fb9
> geonode-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150624/c37037f5/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150624/c37037f5/attachment-0001.jpg>
More information about the geonode-users
