[GeoNode-users] Styling a raster layer
John Jediny
john.jediny at gmail.com
Mon Mar 2 19:32:29 PST 2015
That plus sometimes the layer won't transfer the "no data" value to sld w/
SLD4raster; use the 'identify' tool to find the value for the red in the
pic you sent and set that value to = 0.0 opacity/transparency directly in
geoservers sld editor. Reference geoservers sld for raster tutorial for
formatting help
On Monday, March 2, 2015, Ramesh De Silva <desilvarami at gmail.com> wrote:
> Dear Vivien,
> Many thanks for your directions. The first solution itself worked
> smoothly. Really appreciate your help.
> Kind Regards
> Ramesh
> On Tue, Mar 3, 2015 at 2:52 AM, Vivien Deparday <vivien.deparday at gmail.com
> <javascript:_e(%7B%7D,'cvml','vivien.deparday at gmail.com');>> wrote:
>> Hi Ramesh,
>> this is very likely an issue related to GeoWebCache not clearing the
>> cache properly even after the styles have been changed. There are a couple
>> bug reports about it in github.
>> First solution, go to GeoServer admin menu and on the left to the "Tile
>> Layer" Menu and empty the cache from there for the layers you want. If it
>> still doesn't work, you can fin the actual files of the tiles on the
>> harddrive of the server and manually delete them, with this last resort, it
>> should work for sure.
>> Best,
>> Vivien
>> On Mon, Mar 2, 2015 at 1:57 PM, Ramesh De Silva <desilvarami at gmail.com
>> <javascript:_e(%7B%7D,'cvml','desilvarami at gmail.com');>> wrote:
>>> Hi Paolo,
>>> Thanks for the directions. I created the SLD file using QGIS SLD4raster
>>> plugin and uploaded to GeoServer. Then I assigned the style to my raster
>>> layer. Now I can see the legends. Even the thumbnail got updated. But map
>>> is still the same. Please have a look at following layer.
>>> http://203.159.29.10/layers/geonode:lc_10m_elvtif
>>> Same thing happens in vector layers as well. Please have a look at
>>> http://203.159.29.10/layers/geonode:tha_adm1 . Here also I added the
>>> SLD file in GeoServer level and assigned it to the data layer . I can see
>>> the legends as well as thumbnail got updated after adding the SLD. But map
>>> doesn't change.
>>> I did clear the browser cache assuming this is a caching issue. But it
>>> is still the same. Also I tried from a different PC.
>>> By the way, if I preview these layers in GeoServer Layer Preview, I can
>>> see the thematic map. Please let me know, if I need to do anything more in
>>> order to make it effective in GeoNode level.
>>> Many thanks.
>>> Kind Regards
>>> Ramesh
>>> On Mon, Mar 2, 2015 at 9:15 PM, Paolo Corti <pcorti at gmail.com
>>> <javascript:_e(%7B%7D,'cvml','pcorti at gmail.com');>> wrote:
>>>> You will need to edit the GeoServer style directly from the GeoServer
>>>> admin.
>>>> A nice tool to use to generate the sld for rasters is the SLD4raster
>>>> QGIS plugin.
>>>> It can even upload the style to GeoServer from QGIS.
>>>> regards
>>>> p
>>>> On Mon, Mar 2, 2015 at 1:56 PM, Ramesh De Silva <desilvarami at gmail.com
>>>> > Hi,
>>>> > I need to label different colors appearing in a raster layer. It
>>>> seems I can
>>>> > not do this using the style editor as there is no attribute table
>>>> associated
>>>> > with the raster layer.
>>>> > Is there a way to label these classes represented by different colors?
>>>> > Kind Regards
>>>> > Ramesh
>>>> > _______________________________________________
>>>> > geonode-users mailing list
>>>> > geonode-users at lists.osgeo.org
>>>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Paolo Corti
>>>> Geospatial software developer
>>>> web: http://www.paolocorti.net
>>>> twitter: @capooti
>>>> skype: capooti
Cell: 973-931-0580
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150302/899f17b8/attachment.html>
More information about the geonode-users
