[GeoNode-users] migrate geonode 2.4 to another server
Alessandro Burastero
alessandro at acrotec.it
Tue Mar 31 04:16:45 PDT 2015
i've truncated the base_link table and then i've run the geonode
updatelayers command (and also updatelayerid)... but the base_link table
remains empty
Alessandro
On 31/03/15 11:39, Paolo Corti wrote:
> I have no way to test this right now but I believe that truncating the
> base_links table and running the updatelayers command should fix this.
> Before doing this action do a backup and try it on just one layer
> (removing the links related to only that layer from the base_links
> table)
> You may also need to run the updatemaplayerip command.
> p
> On Tue, Mar 31, 2015 at 11:08 AM, Alessandro Burastero
> <alessandro at acrotec.it> wrote:
>> Hi guys
>> i need to migrate my geonode 2.4b22 to another server (same os: ubuntu 14-04
>> and same geonode version)...
>> I tried doing it in this way:
>> - copy the geoserver data, styles and workspace directory in the new server
>> - domp via pg_dump and restore via psql the geonode database
>> the result is that geonode recognize all layers but it cannot view them
>> because all links in the layer metadata contains the old server address...
>> haw can i solve it?
>> thanks in advance
>> Alessandro
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users
