[GeoNode-users] geonode 2.4 dev layers not displayed: CLIENT_RESULTS_LIMIT = ;
Simone Dalmasso
simone.dalmasso at gmail.com
Mon May 4 07:17:59 PDT 2015
Ok, yes it looks to me some interferences in the templates.
Ciao
2015-05-04 16:15 GMT+02:00 Jesus <gesusjl at gmail.com>:
> Hi Simone.
> As you say I need to figure out if there's any interfering template or app
> causing the problem. in the meanwhile i remove the {{CLIENT_RESULTS_LIMIT}}
> template tag from search_scripts.html in "production server" and substitute
> with a numeric value. Not doing so makes javascript break (not default
> value is provided)
> I will let you know if i find out the cause of the problem.
> Thanks!
> Jesús
> On 05/04/2015 12:38 AM, Simone Dalmasso wrote:
> Hi Jesus, I cannot replicate this.
> The CLIENT_RESULTS_LIMIT is defined in the settings as you said but also
> is passed from the context_processor to the client see
> https://github.com/GeoNode/geonode/blob/master/geonode/context_processors.py#L62 that
> defaults it to 10 if not found in settings. And is used here
> https://github.com/GeoNode/geonode/blob/master/geonode/templates/search/search_scripts.html#L26
> All this is done server side so it should not be a javascript error. Did
> you by the way changed in the template? Seems that the server is not
> interpreting the {{ CLIENT_RESULTS_LIMIT }} and this could be caused by
> the presence of a {% verbatim %} block around it.
> 2015-05-03 20:21 GMT+02:00 Jesus <gesusjl at gmail.com>:
>> Hi all,
>> Layers and maps not appear in geonode 2.4 dev.. firebug console raise an
>> javascript error
>> SyntaxError: expected expression, got ';'
>> I tried uploading local_settings.py with
>> CLIENT_RESULTS_LIMIT = 100
>> but no result. Maybe a javascript bug or something else to check around?
>> No apache errors
>> Thank you,
>> Jesús
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150504/13faacd8/attachment.html>
More information about the geonode-users
